Adding OEM Toyota Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020SX, Apr 22, 2020.
  1. Apr 22, 2020 at 12:29 PM
    2020SX
    2020SX [OP] New Member
    Isaac
    2020 White Tundra SR5 SX 4WD CrewMax
    Front tint matched to rear, Xpel Ultimate Plus PPF on front end, door cups, door edges, and b pillars
    I recently purchased a 2020 Tundra SR5 SX. It has the normal black mirrors on it (heated, power adjustable, non power fold, no turn signal). I was wondering if its possible to add factory OEM tow mirrors to it, and if they're plug and play? I've heard some people say that these trucks are all wired the same, meaning that the turn signal would work even though my current mirrors don't have it. I'm unsure if this is true, and this is my first Toyota. The part numbers I would use are 87910-0C221 and 87940-0C221. Any help or info would be appreciated!
    Maxi13 and specter208 like this.
  2. Apr 22, 2020 at 4:39 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    Yes, you can purchase and install the OEM tow mirrors and the power adjust mirror and heat feature will work. The clearance light and turn signal on the outer edge of the tow mirror will also work. I purchased the power fold OEM tow mirrors and installed them on my 2020 SR5 and they work fine. The power fold function will work once I get the harness from @KTJO 4x4 . She's finalizing the harnesses now.
    The part numbers you listed look correct. And yes, you just remove the hold mirror, install the new mirrors and then plug your mirror harness into the new mirrors. There's nothing to do aside from that, unless you want to purchase the power fold version, which are almost twice as much, and then get the harness from KTJO 4x4 when it's available.
  3. Apr 22, 2020 at 7:38 PM
    2020SX
    Isaac
    Do you have to buy the power fold mirrors to have the turn signal/running lights as well as the power adjustments and heat to work? Or can you buy the non power fold? Also does it work with the blind spot monitor and all the Toyota Safety Sense stuff? Just plug and play? And does the fact that your truck is a TRD and my truck is an SX change anything?
  4. Apr 22, 2020 at 7:46 PM
    chrisbusnut
    Pasadena, CA
    You only need the power fold mirrors if you want the power fold feature, but you will have to buy the aftermarket harness (when it’s available) to get the power fold to work. Only Platinum and 1794 models have factory power fold. The rest of the features work with your truck when you plug the mirrors in. Keep in mind, though, that the Toyota tow mirrors do not have the BSM feature. There is a way around that, however you will have to buy and install LEDs in the truck and wire them into the mirror harness.
    I’m not familiar with the SX, but your truck is an SR5, right? If you have BSM, then it sounds like your truck is similar to mine. Mine is the SR5 with TRD Off Road pkg.
  5. Apr 22, 2020 at 7:59 PM
    2020SX
    Isaac
    Oh so the blind spot monitors won't work if I get the Toyota factory tow mirrors? And yes its an SR5. The SX package is just an appearance package more than anything
  6. Apr 22, 2020 at 8:04 PM
    chrisbusnut
    Pasadena, CA
    There are no blind spot monitors on the OEM tow mirrors. If you want to maintain those, you will need to buy the aftermarket tow mirrors, or install the LEDs. If you do OEM tow mirrors, you will have to turn BSM off, otherwise you will get an error message.
    I installed LEDs and wired them in, so my BSM works. The LEDs are inside the truck now, not in the mirrors.
  7. Apr 22, 2020 at 8:08 PM
    biebs96
    PA
    You can add an LED in line (in place of the indicator on the factory mirror glass) in the sail panel.
    Illuminated..
    You can even ask @chrisbusnut ... it works!
  8. Apr 22, 2020 at 8:09 PM
    biebs96
    PA
  9. Apr 22, 2020 at 8:14 PM
    chrisbusnut
    Pasadena, CA
    Definitely! :thumbsup:
    biebs96[QUOTED] likes this.
  10. Apr 23, 2020 at 5:08 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Does the SX have BSM? My base SR5 doesn't and, like the OP said, SX is just an appearance package.
  11. Apr 23, 2020 at 6:02 AM
    2020SX
    Isaac
    Come to think of it I'm not sure it does. It has Toyota Safety Sense P: Pre-Collision System w/ Pedestrian Detection, Dynamic Radar Cruise Control, Lane Departure Alert, Automatic High Beams. How would I know if it has blind spot monitors?
  12. Apr 23, 2020 at 6:14 AM
    2020SX
    Isaac
    Come to think of it I'm not sure it does have blind spot monitors. It has Toyota Safety Sense P: Pre-Collision System w/ Pedestrian Detection, Dynamic Radar Cruise Control, Lane Departure Alert, Automatic High Beams. How would I know if it has blind spot monitors?
  13. Apr 23, 2020 at 7:15 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That sounds like everything mine has. The only thing I can think of is if you have BSM, you should have little yellow lights somewhere in or near the mirrors.
  14. Apr 23, 2020 at 8:00 AM
    2020SX
    Isaac
    I don't see any lights or anything obvious. I'll wait to see if @chrisbusnut chimes in and can inform me where to look. Does your truck have BSM @Cpl_Punishment?
  15. Apr 23, 2020 at 8:11 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I’m not sure about Tundras but mine look like this CE6831E9-EB47-4BD0-9CC2-3915F33DBEF5.jpg the little triangle lights up if it detects a something in my blind spot
  16. Apr 23, 2020 at 9:04 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It does not. Not a feature I was interested in, especially if it costs extra.
  17. Apr 23, 2020 at 9:15 AM
    chrisbusnut
    Pasadena, CA
    @2020SX , if your truck has BSM, you'll see green "BSM" and "RCTA" lights on your dash. You would also have parking sensors in your front and rear bumpers, and then the little icons with LEDs behind them in (I think) the top left hand corner of the driver's mirror/right top corner of the passenger mirror. Those light up when you're driving and someone approaches in your blind spot.
    If you don't have the parking sensors, which are obvious on the truck (front and rear bumper), then you most likely don't have BSM and don't need to worry about it. If that's the case, then the tow mirrors should have no impact on your TSS.
  18. Apr 23, 2020 at 9:17 AM
    chrisbusnut
    Pasadena, CA
  19. Apr 23, 2020 at 9:20 AM
    2020SX
    Isaac
    It doesn't have parking sensors in the front or rear bumpers and there's no lights on the mirrors that I can see. So in that case, if I buy those part numbers I posted above, in theory I should be able to plug them in and mount them with no modification and have the heat, power adjustment, and turn signal, parking lights work? Is that correct? Assuming LDA is different than BSM
  20. Apr 23, 2020 at 9:22 AM
    chrisbusnut
    Pasadena, CA
    That's correct. Plug and play. The clearance light and blinkers will work, as will heat and power adjustment. You just don't have wiring for dimming, power fold (both Platinum and 1794 features) or BSM.
    Cpl_Punishment likes this.
  21. Apr 23, 2020 at 9:48 AM
    2020SX
    Isaac
    Okay sweet. I don't really mind that they're not power fold or dimming. Just as long as they're plug and play and that the heat, power adjust, and turn/marker lights work is without modification is all im looking for
  22. Apr 23, 2020 at 10:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Thanks, @chrisbusnut! While I'm not the OP, I'm also interested in this mod and will probably do it when I start shopping for a travel trailer.
  23. Apr 23, 2020 at 11:04 AM
    2020SX
    Isaac
    The thing thats making this so confusing for me is that I asked Micah from Sparks Toyota if they would fit and he said "They will bolt on and plug in without an issue, but if you are not wired for all of the features they may not work. Most of the new trucks are not wired for the running lights and turn signals."
  24. Apr 23, 2020 at 12:13 PM
    chrisbusnut
    Pasadena, CA
    If that's the case, then I'm not aware of it. My understanding is that all trucks are wired for the clearance lights and turn signals in the tow mirrors.
    You might want to check with @Roman at Cool Springs Toyota. That's where I get all of my parts.
  25. Apr 23, 2020 at 12:34 PM
    2020SX
    Isaac
    I sent him a message on here. I will see if he responds
  26. Apr 23, 2020 at 12:45 PM
    Firefly
    Firefly New Member
    2019 Quicksand TRD
    Since I've been considering this same mirror change on my 2019 SR5, I'm curious what the "stick-out" distance is on the tow mirrors when they're not fully extended. I keep thinking I'll see a set of tow mirrors on another Tundra and I'll measure how far out from the truck body they are. So far I haven't seen one parked where I could check the mirror with a tape measure. My stock mirrors leave me just a few inches to spare on each side of my garage door opening.
    For you folks that have the tow mirrors, is the outside edge further away from the truck body than on the stock mirrors?
  27. Apr 23, 2020 at 12:59 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I have OEM tow mirrors. If you measure from the window they stick out 15.25", and that accounts for the marker light. They fold in to about 6.25".
    Firefly[QUOTED] likes this.
  28. Apr 23, 2020 at 1:13 PM
    Firefly
    Firefly New Member
    2019 Quicksand TRD
    Thank you for the measurement. I appreciate it! :)
    The stock mirrors are just a squeak over 14 inches, straight out from the glass. It looks like I'll gain about an inch and a quarter on each side.
    I can live with that. I should get my order in to Roman before the end of the month. I think they are still offering free shipping until the end of April.
  29. Jun 2, 2021 at 2:03 PM
    rob4x4tv
    rob4x4tv New Member
    Rob
    2020 Gray SR5
    Bilsteins, airbags, Transferflow fuel tank
    Do these mirrors extend out for towing and slide back in for regular driving? What is the length when they are extended?
  30. Jun 2, 2021 at 9:30 PM
    19TurdPro
    2019 Tundra TRD Pro
    They slide out another 3.5 inches.
    BravoDeltaRomeo likes this.
