Rotors for a Rock Warrior.
Discussion in 'General Tundra Discussion' started by RockWarrior2k10, Apr 21, 2020.
  1. Apr 21, 2020 at 10:44 PM
    RockWarrior2k10
    RockWarrior2k10 [OP] New Member
    2010 Tundra Rock Warrior
    Bull bar with led light bar, 35in tires, more to come.
    I've got a little shake/shimmy in my steering when braking and a very slight pull to one side. I was wonder what its indicative of and how to fix it. I'm thinking rotors. With it being a rock warrior is there anything I need to know specifically?
  2. Apr 21, 2020 at 10:51 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Nope same as other models. Get them turned is the cheapest. Take off and take to an auto parts shore that has a lathe. Will have to call around. You could replace with new rotors but $$. Also check for uneven wear on the pads and if they need changed as well.
    WFD473 likes this.
  3. Apr 21, 2020 at 10:52 PM
    RockWarrior2k10
    Any advantage over plain rotors if I swap to drilled and slotted?
  4. Apr 21, 2020 at 11:04 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Drilled rotors are prone to cracking
  5. Apr 21, 2020 at 11:05 PM
    RockWarrior2k10
    Well that's not good. Thank you for the advice.
  6. Apr 21, 2020 at 11:06 PM
    RockWarrior2k10
    Any good brands if I have to replace?
  7. Apr 22, 2020 at 7:12 AM
    csuviper
    Broomfield, CO
    StopTech, Power Stop, EBC
    RockWarrior2k10[OP] likes this.
  8. Apr 22, 2020 at 7:22 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I put Centric Premium or Raybestos EHT's on most vehicles that come into my garage. Need them coated rotors living in the rust belt. 3 Tundras on Raybestos EHT pads and rotors. No complaints.
  9. Apr 22, 2020 at 8:41 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Suggestion....try an Italian brake job and see if that helps. Rust and glaze can build up and cause shimmy, pulsing, etc. 5-6 hard brake applications without stopping (slow to about 5mph) may help.
    smslavin likes this.
  10. Apr 22, 2020 at 9:06 AM
    RockWarrior2k10
    Does that really work? Ive never heard of that?
  11. Apr 22, 2020 at 9:17 AM
    frichco228
    Frank
    Virginia
    If your rotors are not warped, but have glaze and rust, yes. It is the same process as seating the brakes- burnishing the brakes.
    If you pull a wheel you can see how your rotors look. If they are cruddy it could help. Even a tiny amount of crud or rust will be felt when applying the brakes.
  12. Apr 22, 2020 at 9:31 AM
    RockWarrior2k10
    That makes sense now. I'll give them a look (once I get sockets big enough lol) anything I should know before getting it in the air and going for it?
  13. Apr 22, 2020 at 11:34 AM
    frichco228
    Frank
    Virginia
