Changing oil filter without changing oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTund16, Apr 21, 2020.
  1. Apr 21, 2020 at 8:35 PM
    TTund16
    TTund16 [OP] New Member
    Has anyone ever done this?
    a friend with a new Tundra asked me that question. He wants to change the filter of his new truck at 500 miles but not the oil.
    Without getting into pros and cons of it and why he wants to do that ... He was wondering if lots of oil will be gushing out of not.
    I've never changed any filter on any car without changing the oil. Meaning I drain the oil first and then change the filter ... So I have no idea what will happen for sure. My understanding is that it depends on the car.
  2. Apr 21, 2020 at 8:48 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I haven’t tried this on the Tundra. However, if you take a shop vac and put the hose over the fill you can cause enough suction to remove the drain bolt without draining the oil. May work on the filter.
    I would assume though with the Tundra setup it would just be the oil in the canister that would come out under normal conditions.
    TTund16[OP] likes this.
  3. Apr 21, 2020 at 8:53 PM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    I don’t see a reason why you can’t change only the filter. You’ll lose some oil at the filter housing of course but, most of the oil remains in the pan.
  4. Apr 21, 2020 at 9:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You lose a little under a quart. I see his point about the break in fears. Why not just change oil too if he is that worried, i always do a 1k mile change too
    TTund16[OP] and 1lowlife like this.
  5. Apr 21, 2020 at 10:10 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    There's is a drain on the oil filter cap that you remove before the canister. Once you take that off you can use the tool that Motovix has or the little piece that comes with OEM toyota filters to drain the oil from the filter. Then remove the filter without losing too much oil but definitely enough that you would need to add some. While you're under there you might as well just change the oil too though. While you're at it you can get that crap 0w20 out of there and put in some 5w30.
    Hbjeff and TTund16[OP] like this.
  6. Apr 22, 2020 at 4:24 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Makes me wish Toyota had the same design on the Tundra as they did with the 4.0 in the Tacoma. Just open the hood, spin off the old filter, spin on the new one, clean up what came out in the catch area, and good to go.
    10TundraSR5 and tAcomaPueblo like this.
  7. Apr 22, 2020 at 7:22 AM
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    Interesting. I had considered that same thing, but went with the 0-20. I think next change Ill def go with 5w20 or 5w30.
    glowblue and Joe333x[QUOTED] like this.
  8. Apr 22, 2020 at 8:17 AM
    glowblue
    glowblue From time to time
    VA
    What are the main benefits of going with 5W-30? Better lubrication? I've also read engines run quieter on 5W-30, but you lose some MPGs...I'm curious in the thinking behind using 5W-30.
    I've been reading a lot about the Toyota 0W-20 specification and many theories as to why Toyota specs this type of oil for our trucks, topic for a different discussion.
  9. Apr 22, 2020 at 8:24 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    PREACH!!!!!
    Jaypown[QUOTED] likes this.
