First scratch
Discussion in 'Detailing' started by k11white37, Apr 21, 2020.
  1. Apr 21, 2020 at 12:56 PM
    k11white37
    k11white37 [OP] New Member
    Kyle
    2020 Army Green TRD Pro
    Well it finally happened! I got my first scratch and it’s a doozy man... what is the best way to fix this? Appears to be all the way thru the paint. Not sure if lint correction or just polishing will do the trick
  2. Apr 21, 2020 at 1:31 PM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    No need to fix. It’ll blend in with the rest soon.
  3. Apr 21, 2020 at 1:44 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    If you can feel it with your fingernail, then it’s gone deep into the clear coat. Be cautious on trying to buff or polish out because it's easy to burn through the clear coat. Unfortunately, the “correct” fix, if it’s through the clear coat, is to completely re-clear the entire panel from edge to edge. Try Scratch-X and carefully polish, maybe you can get it to become less noticeable. Good luck.
    devdomski likes this.
  4. Apr 21, 2020 at 1:46 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Put a bandaid on it.
  5. Apr 21, 2020 at 1:49 PM
    G10dra
    G10dra Not a New Member
    :itllbuffout:
  6. Apr 21, 2020 at 1:50 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    i know how you feel..
    Tundyfundy likes this.
