Issue Filling Up My Gas Tank
Discussion in 'General Tundra Discussion' started by keenanduran1, Apr 13, 2020.
  1. Apr 20, 2020 at 1:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I was worried that'd happen to me. I disabled the valve, can't recommend that though 'cause It's potentially dangerous. But, since you fixed it once and know what the problem is, maybe a stealership can repair/replace your tank under warranty?
  2. Apr 20, 2020 at 1:45 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Like several have said , your charcoal canister is most likely saturated, the vent tube connects to it directly from the filler neck , when the canister is saturated it’s basically like blocking of the vent hose , when you fill your truck with fuel the air in the tank displaced by the fuel has no where to go and causes positive pressure kicking the filler hand to kick off !
    831Tun likes this.
  3. Apr 20, 2020 at 1:53 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    If it the roll over valve it might be under the emissions related component warranty??
  4. Apr 20, 2020 at 6:19 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    He already dropped his tank, popped the valve open and fixed the problem once. Given the age of his truck, the fact that he doesn't "top off", and the fact that the valve failure is a known problem, it's very unlikely the canister is fouled. I'd say it's the valve again and hopefully Toyota will fix it.
  5. Apr 20, 2020 at 6:26 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Got it
    831Tun[QUOTED] likes this.
  6. Apr 20, 2020 at 7:01 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    You would think that would fall under an emissions related components
  7. Apr 20, 2020 at 8:10 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Right??? I took my truck in and they denied me warranty work. OK, my local dealership is criminally bad..... I do mean criminal. And, my truck is truck is modified beyond what people recognize here in NorCal. But it's still, in my mind, it's part of the emissions system and I now know of a dozen or so trucks that have had this issue.
    I agree with you, Toyota should fix it.
  8. Apr 20, 2020 at 8:21 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    What would nice is if they could redesign the part so you could just replace it for a $100 instead of a new fuel tank for a $1000
  9. Apr 20, 2020 at 8:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    How many miles do you have @831Tun ?
    It surprised me a little, I think I have this right - emissions warranty is only 80k on our Tundras?
    831Tun likes this.
  10. Apr 20, 2020 at 8:43 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    I’m pretty sure they are claiming it’s not an emissions related part , since it’s the fuel tank and not related to the evap system directly . Any evap system parts would be considered emissions components! That’s my educated guess .
  11. Apr 20, 2020 at 8:50 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  12. Apr 20, 2020 at 8:51 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    This kind of surprises me. Figured I'd be much longer.
  13. Apr 20, 2020 at 8:53 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    There out is under the what is not covered part ! I’m sure they have a reason under that ! It’s a corporate mind set !
  14. Apr 20, 2020 at 8:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    What?
  15. Apr 20, 2020 at 9:00 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    D77B42DC-CF12-4BA5-8F85-1712137375D2.jpg Toyota corps “ out” falls under the above mentioned “what is not covered’. They always have an out that way !
  16. Apr 20, 2020 at 9:03 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Don’t get me wrong Toyota is an amazing auto manufacturer an the have top notch design and engineering as well , but the lawyers and bean counters run the show ! Just like all ginormous corporations !
  17. Apr 20, 2020 at 9:07 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    So OP could have issues yes being he has new parts installed. Had he not just thrown parts at it, he would have had a much better chance being covered. Maybe he should throw all his original shit back on and take it in, obviously provided he falls under warranty still.
    Post was also for @831Tun as he appears to be having warranty issues.
  18. Apr 20, 2020 at 9:13 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    It’s possible maybe if he did that and went to a different dealer ?? Hell who knows . Toyota’s are hands down one of the best manufacturers on the planet but at the end of the day there bottom line may make you a causality!
  19. Apr 20, 2020 at 9:15 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Some body on this site should make a roll over valve replacement kit !
    keenanduran1[OP] and 831Tun like this.
  20. Apr 20, 2020 at 9:20 PM
    #50
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I have about 50k
    14burrito[QUOTED] likes this.
  21. Apr 20, 2020 at 9:27 PM
    #51
    55kcement
    Troy
    Sonora ca
    Currently none
    I’d find a different dealer and take it in again !
  22. Apr 20, 2020 at 9:31 PM
    #52
    14burrito
    2014 SR5 CM 4x4 5.7
    Walk in with your warranty card and ask wtf.
  23. Apr 20, 2020 at 9:39 PM
    #53
    55kcement
    Troy
    Sonora ca
    Currently none
  24. Apr 20, 2020 at 10:22 PM
    #54
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Mine has been serviced at Toyota dealerships only. Brought it in when it was one month over the 36 month warranty, but under in miles. They said they wouldn’t cover it, but also couldn’t replicate the problem. 6 months later it popped its ugly head up again.
    I’m about ready to start searching scrap yards.
