Rear Shock Mounting Location
Discussion in '1st Gen Tundras (2000-2006)' started by taranovich92, Apr 20, 2020.
  1. Apr 20, 2020 at 1:11 PM
    taranovich92
    taranovich92 [OP] 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Yokohama Geolander AT 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate.
    I noticed a few months ago that the body of the rear shock on the driver side of my truck was making contact with the side of the bucket that the top of the shock mounts in under the bed of the truck. That was of course bad for several reasons, I thought to myself that maybe it was because there is a 1.5" block in the back that could possibly change some angles but it still didn't make much sense to me. So I replaced my rear bump stops the other day and just figured I would pull this rear shock out while I'm in there and see whats going on. The boot on the Bilstein 5100 was all torn up from making contact with metal, so I had to replace that boot as well. So after having the shock out from under the truck I noticed that the bucket where the shock mounts has two holes that both look like they are meant to hold the top of the shock. One hole looks almost perfectly round and the other is shaped slightly more like an oval. When remounting the repaired shock I simply just mounted it in the other spot so now it sits at a different angle and doesn't make contact with anything like it's supposed to be and now matches the angle that the passenger side rear shock sits at. I will include some pictures, I was just curious why the driver side would have two mounting holes that both look like they're meant to hold the shock and the passenger side only has one available mounting hole up top. In the pictures my shock was for some reason mounted in the hole on the right instead of the hole on the left and as a result you can see where everything was making contact. image001.jpgimage003.jpg
    Tundra2 likes this.
  2. Dec 18, 2020 at 12:36 AM
    Minjin
    Minjin New Member
    PA
    2005 RCLB 4x4
    Bumping this. I just purchased a Tundra and ran into the same issue. Is the left hole correct?
  3. Dec 18, 2020 at 3:56 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Good eye on this to the OP. I have no idea, but would like to hear from someone that does.
  4. Dec 18, 2020 at 3:56 AM
    Fred
    Hand Protectors
  5. Dec 18, 2020 at 5:13 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Looking at my rebuild posts, it appears I used the inboard hole, which is where the original shock was located...?
    Scroll down through this post and look at the photos of my rear frame area
    My 2001 TRD Access Cab Rebuild/Repair/Modify Thread
    I did use stock shocks, though..
  6. Dec 18, 2020 at 6:16 AM
    It should go in the rear hole, I just tightened the upper bushings on both of my rear shocks.
  7. Dec 18, 2020 at 7:56 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i'll have to look.. never noticed. i did my shocks while the bed was off
  8. Dec 18, 2020 at 1:44 PM
    Fred
    Hand Protectors
    I’ll crawl under tomorrow, but a cursory look this morning looks like the 2002 has a different bracket design? I’ll know more tomorrow when I’m wearing my Ghettique Apparel.
  9. Dec 18, 2020 at 3:14 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    My ex wife just slapped your face.
  10. Dec 18, 2020 at 5:01 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Don’t forget gloves for those hands....
  11. Dec 18, 2020 at 5:53 PM
    Minjin
    Minjin New Member
    PA
    2005 RCLB 4x4
    Alright, I got under there to move the shock. It only took five minutes. First disappointment, the shock nut was finger tight. The PO said he put new shocks on earlier this year. Second, the shock condition. Boot is obviously shot and needs to be replaced. The threaded area of the shaft is bent for some reason. And there is quite a dent/wear area at the top of the shock body. I don't know if it will actually have any effect since the piston probably doesn't get that close to the end but I guess I can email Rancho and find out. I'll drive it tomorrow and I'm expecting that the clunk I noticed will be gone.
  12. Dec 20, 2020 at 7:43 AM
    Fred
    Hand Protectors
    Yeah. Crawled under yesterday and looks like my shock is in the rear most hole. Stoked.
    Darkness and FrenchToasty like this.
  13. Dec 20, 2020 at 7:58 AM
    It’s nice knowing you’ve had it in the right hole all these years, right?
    Darkness and Tundra2 like this.
  14. Dec 20, 2020 at 8:13 AM
    Fred
    Hand Protectors
    I wonder what that other hole is for?
    I yeah I’m glad I don’t have to fix something unnecessarily done wrong. 4Wheel Place did a nice job on my truck suspension.
    Darkness likes this.
  15. Dec 20, 2020 at 8:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Weight saving speed hole.
    Probably.
    Darkness and Glock 40 like this.
  16. Dec 20, 2020 at 8:19 AM
    Fred
    Hand Protectors
    Yeah. Its aerodynamic.
    Tundra2[QUOTED] likes this.
  17. Dec 20, 2020 at 8:20 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Black Tundras have a third hole.
    Sandy01, Darkness and Tundra2[QUOTED] like this.
  18. Dec 20, 2020 at 8:31 AM
    Just FYI, that boot really isn't necessary. Many don't even come with it. But the other things you mentioned are concerning. Rear shocks are pretty cheap. I would probably just replace them.
  19. Dec 20, 2020 at 8:38 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    100% correct. A lot of people frown on them, especially mudders. They can hold moisture and do more harm than good if not properly weeped on the bottom. They aren't necessary.
  20. Dec 20, 2020 at 9:07 AM
    Minjin
    Minjin New Member
    PA
    2005 RCLB 4x4
    Alright, I'll consider replacing that one shock. I am curious to hear back from Rancho on their opinion (I emailed them). The truck really doesn't ride very well but it has been many years since I have owned a pickup so it could just be that I need to adjust my standards. I've been reading lots of threads here and Rancho doesn't seem popular at all. I know that shocks are one of the biggest players in terms how how good the ride will be so I might just swap all of them out for something else.
    If you guys are curious, I can take some pictures of the truck and give an overview. Thanks for everyone's help.
  21. Dec 20, 2020 at 9:12 AM
    Honestly you are very unlikely to improve the ride by replacing the rear shocks. Leaf springs have a lot more impact. Replacing your front shocks might also help depending on what you have up there.
  22. Dec 20, 2020 at 9:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its pretty common for diy jobs to go this way for rear shocks on these trucks.
    Regardless I agree with @FirstGenVol 100%. Install the shock without the boot for now and order up a new pair of rear shocks.
    With the bent shaft end it will still get you by but could break any time now that its being aligned properly. From how far up the body of the shock went, up enough to smash itself on the bracket, and how short the shaft looks when discounting the threaded section, I would say the piston inside will have limited movement from the dent in the body.
