2017 tundra axle boot leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Master_tundra, Jan 27, 2017.
  1. Jan 27, 2017 at 12:58 PM
    Master_tundra
    Master_tundra [OP] New Member
    2017 MGM limited
    I have 2017 tundra and when I was installing my suspension I noticed grease on my frame. I inspected the axle boot and notice a very small slit next to the clamp. Any suggestion on patching the slot, don't really feel like dealing with the dealership because they probably just blame the lift.
  2. Jan 27, 2017 at 3:27 PM
    Master_tundra
    2017 MGM limited
    I'm gonna order the boot and put some black rtv on it for now. Hopefully it seals until I am able to tackle this job.
    driverdog likes this.
  3. Jan 30, 2017 at 9:42 AM
    apabon86
    apabon86 New Member
    ALEJANDRO
    before buying go to the dealer and make the claim, you should cover the warranty regardless of the suspension,
    NewImprovedRon, ToyMD and Law323 like this.
  4. Jan 30, 2017 at 3:38 PM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    Unless the dealer can prove it was caused by the suspension work you did it is warranty.
    ToyMD likes this.
  5. Jan 30, 2017 at 6:33 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    TRDFerguson, 15whtrd and ColoradoTJ like this.
  6. Jan 30, 2017 at 6:41 PM
    On a 17', lift or not, dealership time.
  7. Feb 10, 2017 at 3:24 PM
    ToyMD
    ToyMD New Member
    2014 Tundra SR5 DC
  8. Feb 10, 2017 at 4:44 PM
    Master_tundra
    2017 MGM limited
    Took it in to the dealership and they said it looks like something hit the boot, so they can't warranty it. I already ordered the part and just gonna do it myself
  9. Feb 10, 2017 at 6:03 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Crazy that they are taking that stance. Warranty until proven guilty if within the 3/36.
    driverdog and 15whtrd like this.
  10. Feb 10, 2017 at 6:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Ya key word "looks" like something hit the boot. Yeah and you "look" like you're not an asshole. At this point maybe it's better they don't touch the truck. When work can be done myself I always do it. I haven't even used one free oil change.
    Good luck OP
    MS22, Sas, TheBeast and 2 others like this.
  11. Aug 19, 2019 at 2:16 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm running into this same scenario now. I replaced my stock suspension with some TRD Pro Bilsteins, double-checked everything on a week by week basis for a while, then yesterday I noticed some weeping on the spindle and grease coming out of the boot. It also "looks" like something hit the front of the CV boot strap, so I don't know what my chances are for the dealership to fix it. Guess I'll be taking it in to see what they say...
  12. Aug 19, 2019 at 3:16 PM
    Master_tundra
    2017 MGM limited
    Did the dealer replace your suspension? The dealer did not warranty the CV boot.
    I ended up using some black RTV seal and it’s still holding up. I bought the boot, just in case it starts leaking.
    15whtrd likes this.
  13. Aug 19, 2019 at 3:18 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I did the suspension install myself - and was pretty sure we were careful with the CV boots and abs/brake lines and everything. I'll be taking it in tomorrow morning to get it looked and and cross my fingers that they're cool about it...
  14. Aug 19, 2019 at 3:43 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s funny! I was just thinking why wouldn’t something like rtv or liquid tape work. I’ve even thought about doing something like that with ball joints and the slip joint on the back of the transmission. Just using a needle on the grease gun to fill it back up and then sealing the hole with RTV or something similar.
  15. Aug 19, 2019 at 3:53 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    When you replace your CV boots you might want to look at the SDHQ CV boots. That's what I did and you can tell the difference from the OEM ones. They are a lot more flexible and just overall better quality than stock.
    TRDFerguson likes this.
  16. Aug 19, 2019 at 4:08 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That's a good call. Their boot replacement kit is about the same price as OEM, just without the grease... but they're right up the road from me, so that's probably just a wash in shipping for me.
    pdiddy[QUOTED] likes this.
  17. Aug 20, 2019 at 12:01 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I suppose if the dealership tells me the CV boot repair isn't covered I'll just have to look at other options...
  18. Aug 20, 2019 at 12:15 PM
    matthew1992ya
    matthew1992ya New Member
    Matthew
    Louisiana
    2015 sr5 4x4 tundra
    Level sequoia wheels I like factory mods don't care to much for aftermarket
    I mean iv work at Toyota for 5 years and seen them come torn right out of the box several times so I don't see why they can't warranty it we do
  19. Aug 20, 2019 at 2:21 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, these guys at my dealership were totally cool about it and did all the work under warranty. Pretty awesome. Waiting on my keys and I'll be heading home with a fresh CV boot
    pdiddy likes this.
  20. May 7, 2020 at 3:41 PM
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Can't believed this is still and issue... it's 2020, truck was drop at the dealer because of this exact same issue... some grease on the boot o_O returned home run a search and what are the odds... I'm here reading about the same issue... :facepalm:Got a call some minutes ago, dealer rep saying they will check if it's covered by warranty... those damn boots are FRAGILE!! Aside from SDHQ any other good replacement options?
    PS. got an OME lift
  21. May 8, 2020 at 4:54 PM
    1794-BlackTundra
    Sergio
    Well... Dealer said the tear could have happened from something hitting the boot therefore warranty department refused the replacement :facepalm:So I tell them 'are there scratches or physical evidence that lead us to thing there was an impact?' to what the rep responds 'No, but the place where the boot sits it's fairly exposed ' Fu&#%$ing morons!!!! :mad: If the component (any component) it's exposed wouldn't make sense to have stronger materials???
    This boot issue it's clearly either manufacturing or material defect!
    Dealer says they can replace it (upon payment) and obviously it's more than a normal amount for the service. I'll just get 3rd party boots and get this repaired at my cost, it will be even cheaper!
    Why should I pay more money to the dealer for the same cheap ass boot?? :argue: Chances are will happen again! Same conditions, same result!
