  1. Apr 19, 2020 at 11:37 AM
    #2071
    Outbound
    Aaron
    Northern Alberta
    Bilstein 5100 set at 4th (iirc) notch to level the truck.
  2. Apr 19, 2020 at 11:39 AM
    #2072
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is your truck on jack stands or is it sitting at normal ride height? That's an awfully steep upper arm angle.
  3. Apr 19, 2020 at 11:52 AM
    #2073
    Outbound
    Aaron
    Northern Alberta
    It was nn jack stands, which are on the frame in line with the side mirror. It's back on the tires now:
    Darkness[QUOTED] likes this.
  4. Apr 19, 2020 at 11:53 AM
    #2074
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That’s why it’s like that unloaded. This is why the uniball arms are great. That ball joint is your limiting factory in wheel travel right now.
  5. Apr 19, 2020 at 11:57 AM
    #2075
    I really with the PO of my truck did total chaos or the likes, instead went with Spc, oh well
  6. Apr 19, 2020 at 12:00 PM
    #2076
    empty_lord
    05 rollover special
    The SPC works too. the uniball just works slightly better for this setup. anything is better than stock joints on a lifted truck
  7. Apr 19, 2020 at 12:01 PM
    #2077
    empty_lord
    05 rollover special
    whenever it comes time to replace my uniballs i'll be converting my camburgs to ICON delta joints, The big issue with uniballs is theyre exposed to the elements. they do not last as long before getting sloppy
  8. Apr 19, 2020 at 12:01 PM
    #2078
    empty_lord
    05 rollover special
  9. Apr 19, 2020 at 12:02 PM
    #2079
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    And no one wants sloppy balls
    amiright?
    bmf4069, NUDRAT[OP], Darkness and 2 others like this.
  10. Apr 19, 2020 at 12:02 PM
    #2080
    I like that the TC at least have zerks for the bushings. And it’s easy enough to spray some triflow to stop the uni-squeak
  11. Apr 19, 2020 at 12:03 PM
    #2081
    empty_lord
    05 rollover special
    the camburgs have the grease fittings too. personally id buy camburgs before the TC, reason being theyre typically cheaper.
    i had total chaos on the tacoma. now icons. and the camburgs on the tundra. theyre all of equal quality, just buy whats cheaper.
    bmf4069 and FrenchToasty[QUOTED] like this.
  12. Apr 19, 2020 at 12:04 PM
    #2082
    empty_lord
    05 rollover special
    Icons Uniball misalignment spacer is the nicest though. too bad they dont offer uppers for 1st gen tundras
  13. Apr 19, 2020 at 12:13 PM
    #2083
    The spacer allows further travel or droop correct? Allows the tube of the uniball home to clear more of the spindle/bolt?
  14. Apr 19, 2020 at 12:39 PM
    #2084
    Outbound
    Aaron
    Northern Alberta
    I'll have to research my options for longer travel UCA's for when I do my front end rebuild. I'm not going crazy with it, so something like Icon isn't in the cards. Those SPC/Mevotech ones at RockAuto have caught my eye though.
    bmf4069 likes this.
  15. Apr 19, 2020 at 1:08 PM
    #2085
    Yeah and shipping a winch would cost a fortune. I'll probably just order a new one and be done with it. Thanks.
  16. Apr 19, 2020 at 1:48 PM
    #2086
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  17. Apr 19, 2020 at 1:58 PM
    #2087
    empty_lord
    05 rollover special
    its just a smaller design. same travel as the others, but you can run a top dust cover to let them last longer.
  18. Apr 19, 2020 at 1:59 PM
    #2088
    empty_lord
    05 rollover special
    amazing what they could do with a slide rule and draft paper.
    the sr-72 is looking to be impressive. but it wont have that same human designed history behind it being done with computer aid.
    CodyP[QUOTED] and Darkness like this.
  19. Apr 19, 2020 at 3:01 PM
    #2089
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    SPC should help the angle. That's quite a bit of lift you have, be sure to keep an eye on your cv joints.
    If rust is a problem where you live I would probably pick SPC over a uniball arm.
    Outbound[QUOTED] likes this.
  20. Apr 19, 2020 at 3:08 PM
    #2090
    empty_lord
    05 rollover special
    son of a bitch im in love with this color on this car.
    bmf4069 likes this.
  21. Apr 19, 2020 at 3:17 PM
    #2091
    Outbound
    Aaron
    Northern Alberta
  22. Apr 19, 2020 at 3:30 PM
    #2092
    empty_lord
    05 rollover special
  23. Apr 19, 2020 at 3:42 PM
    #2093
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'm here. Just been busy with work and the extra amount of life with my wife working from home and me hanging out with the kid and working on the yard. I also had to do a wheel bearing. Not as bad as I'd expected, but not exactly fast for me.
    I got some time this week to go to the desert twice. Once for a work video and once for fun and testing my new 6.5 Grendel pistol. Shoots good and still is probably safe for a shot of two without earplugs. The Tundra worked well as usual and I got almost 16mpg on the last tank.
    bmf4069, chrisb, Brown Bear and 6 others like this.
  24. Apr 19, 2020 at 3:57 PM
    #2094
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    bmf4069, chrisb, Brown Bear and 2 others like this.
  25. Apr 19, 2020 at 4:53 PM
    #2095
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Anybody else turn their phone upside down
    Then realize it's not the floor?
  26. Apr 19, 2020 at 4:53 PM
    #2096
    empty_lord
    05 rollover special
    Nope. Just you
    chrisb and Darkness[QUOTED] like this.
  27. Apr 19, 2020 at 4:54 PM
    #2097
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Unfortunately he is not alone....
    empty_lord[QUOTED] and Darkness like this.
  28. Apr 19, 2020 at 4:56 PM
    #2098
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Let's hope somebody flips their computer over so we can feel way better :D
  29. Apr 19, 2020 at 4:56 PM
    #2099
    empty_lord
    05 rollover special
    Man I’m torn.. cut my drums or replace... I have brand new ones, but the 02 taco needs a rear brake job and it’s staying drum... they were for the 01 but also fit the tundra..
  30. Apr 19, 2020 at 4:57 PM
    #2100
    empty_lord
    05 rollover special
    If anyone here is allowed flipping jokes its me!
