Does this plug look original?
Discussion in '2nd Gen Tundras (2007-2013)' started by bleach, Apr 19, 2020.
  1. Apr 19, 2020 at 11:16 AM
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I'm trying to figure out if the plugs have ever been changed. None of my records mention any plug changes. To me this plug looks too good to have 136K miles on it but I'm not familiar with plug wear characteristics on newer engines like my Tundra.
  2. Apr 19, 2020 at 11:21 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Yea that’s OEM
    bleach[OP] likes this.
  3. Apr 19, 2020 at 11:31 AM
    bleach
    DJ
    Battle Ground, WA
    I checked the part number and you can buy the exact plugs so I'm aware they're OEM. Based on condition is this a 136K mile plug?
  4. Apr 19, 2020 at 11:48 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Thinking no. Maybe 50-75 k miles.
    Probably changed from originals.
  5. Apr 19, 2020 at 12:36 PM
    bleach
    DJ
    Battle Ground, WA
    I'm thinking that too. They seem too good for high mileage. The engine runs fine.
    I've pulled to check the original plugs on our '06 Acura MDX when it had around 50K and they looked much better than these.
    The 4.7L has a change interval of 120K. I'd be curious to see what OEM plugs look like then.
  6. Apr 19, 2020 at 12:47 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    I changed the plugs in my brothers 09 Tundra 5.7L last summer at 140k. They were original and looks almost identical for wear as the OP.
  7. Apr 19, 2020 at 1:06 PM
    bleach
    DJ
    Battle Ground, WA
    The plugs did have a little resistance removing them plus the threads have crud on them.
    I'm trying to debate whether it's worth shelling out around $90 for a set plugs. I need to keep from needlessly spending any money as I much as I can right now.
  8. Apr 19, 2020 at 1:37 PM
    ninjajay
    Spoolston, TX
    Chances are good that it’s original, unless you have knowledge of the previous owner or maintenance history that would tell you otherwise
  9. Apr 19, 2020 at 3:11 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    At that mileage, change your plugs.
