Has this happened to anyone
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheBronze1, Apr 17, 2020.
  1. Apr 17, 2020 at 10:47 AM
    TheBronze1
    TheBronze1 [OP] New Member
    Al.
    Maryland
    2017 bronze mica 1794
    bed cover, upgraded stereo system, light bar in hood and front grill, bed lights, switch back lights by step bars
    I have the morimoto headlight motor that a member was selling for converting from year 17 to year 18 led headlight on my 1794. Yesterday my led daytime running lights stopped working on the passenger side and I found one of the harness connector wire broken (see pics) that yellow wire is so brittle. Is there a way to fix this or should I get a new harness. Or does anyone make a different style harness that's plug and play where I dont have to move any wires. I know I'll have to switch these wire back I had to move when I first got the morimoto setup
  2. Apr 17, 2020 at 12:40 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    That’s easy to fix just De pin the connector and replace it with a new wire I do that in my shop all the time cause corrosion
    NewImprovedRon likes this.
