Rack moving
Discussion in 'Suspension' started by supermotobobby, Apr 15, 2020.
  1. Apr 15, 2020 at 1:08 PM
    supermotobobby
    supermotobobby [OP] New Member
    Bobby
    2022 Tundra Platinum 4x4
    Hey all, is it normal for my rack to be moving when I turn the steering wheel?
  2. Apr 15, 2020 at 1:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Steering rack? The steering rack should not move in its mounts but it does move hydraulically to assist in turning.
  3. Apr 15, 2020 at 1:19 PM
    supermotobobby
    Bobby
    So without actually measuring it, it looks like it is moving 1/4 to 1/2" in the mounts.
  4. Apr 15, 2020 at 1:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  5. Apr 15, 2020 at 1:23 PM
    supermotobobby
    Bobby
    Thanks for the help!
  6. Apr 15, 2020 at 1:27 PM
    Kung
    KG, VA
    Oh. OH! You mean the STEERING rack.
    15whtrd, Sunnier and shellshock like this.
  7. Apr 15, 2020 at 4:42 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I love a bouncy rack
    TheBeast likes this.
  8. Apr 15, 2020 at 9:16 PM
    supermotobobby
    Bobby
  9. Apr 15, 2020 at 10:05 PM
    state48overland
    state48overland New Member
    Erick
    Gilbert, AZ
    2011 & 2017 Tacoma DCSB 4WD; 2007 FJ Cruiser
    Long Travel Build: 2011 DCSB 4WD Total Chaos (+2 long travel, heimed uca, race lca, front shock hoop, rear shock relocation hoop with sua kit, spindle and coil bucket gusseted, bed stiffeners), 34"s Nitto Ridge Grapp's, SCS SR8 gun metal, Pelfrey (front/rear/4 skid plates-exhaust re-route, sliders), Rigid LED, Kings (coilovers, triple bypass front, piggy back double bypass rear, hydro-bumps), Superbumps (front), Deaver(sua pack), Harrop rear locker, 4.56 Nitros, Single piece double cardan driveshaft, VLEDs DRLs, GTR 3 LED headlights, Diff breather/relocation x 3, pinch weld, cmc, AGM battery, Bulldog winch (synthetic rope) 9500lb, ext. stainless brake lines, Fumoto, Factor55 flatlink, YWM, fog light mod, LED conversion interior/exterior, de-badged, all 4 stock fenders and flares trimmed 2.5", Safari snorkel, anytime rear camera mod, exhaust chop, spare tire mount chop to fit 34", strapped at all 4 corners.. Mid-Travel build: 2017 DCSB 4WD 34"s BFG KO2, SCS Ray 10s matte black, Diff breather/relocation x 3, sPOD dual Bantam set up, Prinsu, Diamondback, Pelfrey (front, rear, skids, gas, exhaust re route), Sliders, Baja Designs(30" Onx 6 HP, 2 x 30" S8, XL80s, Squadron Sports, S2s x 6), Kings (3.0 IBP fronts, 3.0 double bypass rear, hydro bumps), Eibach 16" x 650lb coilover spring swap, ICON RXT leaf pack-set @ option 2, Total Chaos (Stock length heimed uca & lca, strapped front, sway bar delete, spindle and coil bucket gussets), ext. stainless brake lines, EXE TPAM, EXE bedside compressor mount, AGM-group 31-Pelfrey battery cage, pinch weld, cmc, Factor55 flatlink, X2O 10,000lb winch(synthetic rope), LED conversion interior/exterior, Superbumps, Nitro 4.88s, exhaust chop, spare tire mount chop to fit 34". Mid-Travel build: 2007 FJ Cruiser 35" Nitto Ridge Grapps. SCS SR8 matte black, Demello flat front bumper steel, Expedition One Rear gate/bumper, cmc, pinch welds, fender flare delete, ICON coilovers w/remote resi and rear, Metal Tech LT LCA rears, 12,500lb winch + synthetic rope, Factor55 thimble, full belly/gas tank steel skid plates, Rigid leds, full interior and exterior led upgrade, led flasher upgrade, Total Chaos (UCA, spindle gussets), frame gussets, rear sway bar delete, 4.88 Nitro gears, Diff breather/relocation x 3, Fumoto, exhaust chop,
    Could be the rack is shot ---especially with bigger tires---sometimes can be cured with these...we change out about 2 a month. Usually 35" tires plus a 100k mileage is the recipe for the stock bushings to wear down faster.
    https://state48overland.com/collect...dra-2007-power-steering-rack-poly-bushing-kit
    14burrito likes this.
  10. Apr 15, 2020 at 10:13 PM
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    Actually mine is doing the same thing! I was quoted $300 for installation of new poly bushings and an alignment. I have 35 inch tires.
  11. Apr 15, 2020 at 10:39 PM
    TheBeast
    TheBeast The Beach
    who doesn't :D
    tightywhitey[QUOTED] likes this.
  12. Apr 16, 2020 at 6:26 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I got quoted $300 as well
  13. Apr 16, 2020 at 6:56 AM
    timsp8
    NY
    How hard are these to install? Can you reach them easily or have to remove a lot of stuff?
  14. Apr 17, 2020 at 4:14 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Would also like more info. Saw some mixed info on install. I have the bushings waiting to be installed but have looked over the job a couple times and haven’t wanted to start it.
    I know you need a set
    Of pickle forks to get old bushings out.
  15. Apr 17, 2020 at 5:28 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    It's a pita, but can be done, if you have the right tools for the job, and persistence. Oem bushing are two halves, upper and lower. Remove rack bolts, remove steering wheel spline input shaft bolt to have more freedom of movement of rack. I use straps to pull rack forward for more room to work and pounding. Lower bushing, I used open end wrench ground down to look like a tie rod removal tool. Lots of pounding on bushing to wedge it out. Not easy to remove, rusted oem sleeved bushing. Once popped out, use my old tire iron, aka chisel and more pounding upwards on upper bushing to pop it out. Top poly bushing install is easier than bottom. For lower, more pounding upwards, to pound lower bushing in. Be ready to do a lot of pounding. Be warned once removed old bushing will be destroyed, so no going back, complete the mission. May take all day if not longer.
