NSV Light Bar question
Discussion in 'Lighting' started by silber, Dec 29, 2019.
  1. Dec 29, 2019 at 2:01 PM
    silber
    silber [OP] New Member
    2016 Black Tundra 1794
    Dirty Deeds exhaust, 6 inch lift, Grind wheels, Amp Research steps, NSV light bar, TRD Pro front and rear sway bars, FRAC harness.
    Hi. Can anyone proviso e help. I want to depin a wire from the NSV 12 pin harness and can’t for the life of me figure out how to depin a wire. Thanks in advance
  2. Dec 29, 2019 at 4:00 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Post some pictures of your plug and I will help you.
    Ely010606 likes this.
  3. Dec 29, 2019 at 5:46 PM
    silber
    EBB1E0B3-ECF7-4EA5-8BCA-591B1353A6DB.jpg D0A89B97-1654-42DD-9888-55783774A418.jpg Here is the plug I need help with.
  4. Dec 29, 2019 at 6:18 PM
    denver kid
    denver kid New Member
    what you need is a pin pusher, a tool to push one or two tabs on pin in to release pin. tool is used on opposite side without wire.I have got pin pushers at radio shack or a electronic wiring store. try contacting NSV to see whay style they use. than try Amazon its not hard to do.
  5. Apr 12, 2020 at 11:46 AM
    CementDragon
    CementDragon New Member
    2017 Tundra TRDpro Crew Max (Cement)
    AJT Design Chrome Delete NSV Lightbar Undercover Swing Cases Ridgelander Tonneau
    @silber i assume you figured it out but it’s not posted in this thread. I completed the entire install with no problems until I tried to do one of the simplest tasks; plug a pin into a connector. Like a complete bone head, I plugged Pin #9 into the hole for Pin #6! I have de pinning tools but can’t figure out how to release the pin style from the 12 pin connector. Can you (or anyone) HELP? Thanks!
  6. Apr 13, 2020 at 7:18 PM
    CementDragon
  7. Apr 13, 2020 at 9:19 PM
    Mgmtundra
    Mgmtundra MGM Crew
    Good luck with depinning, all I can chime in with is it’s difficult when it’s cold. I struggled and eventually called in a second set of hands to make it happen for the gray wire mod. Looks so easy on YouTube
  8. Apr 16, 2020 at 11:15 AM
    CementDragon
    HulkSmurf14, egibson606 and Ely010606 like this.
  9. Jul 20, 2024 at 2:00 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just so everyone knows, when owning a gen 2 bar that was re-wired to defeat the strobe...the greatest discovery was made...I was swapping out my bulge for one that did have broken tabs...I added some more strength with JB Weld on the tabs that are known to break when anything breaks on the bulge...I figured I might as well try the pin #8 to empty pin #3...definitely a tricky depinning but, the video works for this; I now have the strobe feature in-lieu of the boring "DRL" look ...I feel like drinking now!! Cheers!!
