Hello everyone. Well since last post I decided to stay out of the gas pedal. So I get 12.6 mpg
Discussion in '2nd Gen Tundras (2007-2013)' started by Krisfordman, Apr 11, 2020.
  1. Apr 11, 2020 at 1:59 PM
    Krisfordman
    Krisfordman [OP] New Member
    Kris
    2008 Tundra SR5 4x4 lifted
    So the throttle response is awesome. My yota will diff pull.
    I have another question.
    I had a turn signal light blow. So I replaced all the turn signals with LED turn signal lights. Now all turn signals will flash fast. How do I slow them down and return them back to a normal fast?
    Thanks
    Kris
    Inquiringone likes this.
  2. Apr 11, 2020 at 2:00 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I believe you need resistors on them due to the fact they take a lot less power to run than incandescent bulbs .
    omgboost, Tundyfundy and Inquiringone like this.
  3. Apr 11, 2020 at 2:01 PM
    Krisfordman
    Kris
    Do you recommend a size resistor?
  4. Apr 11, 2020 at 2:08 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I’m not sure myself but one of these great people will answer
  5. Apr 11, 2020 at 3:40 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  6. Apr 11, 2020 at 5:18 PM
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    @Headlight Revolution has a kit specifically for LED lights and such I believe, might require some extra wiring but can give you some cool results from their videos I've seen on Youtube and from others.
  7. Apr 11, 2020 at 5:24 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    On each side, one 3 ohm, 50W resister connected across hot and ground wires of each rear turn signal bulb. Mount resister to the steel bulkhead behind the tail light because it gets hot. Resisters available cheap on Amazon.
    FrenchToasty, omgboost and Tundyfundy like this.
  8. Apr 11, 2020 at 5:35 PM
    Krisfordman
    Kris
    So the 4157 ck and 3157ck anti hyper flash bulbs would work? No codes on the dash shows. There has to be a LED bulb that’s already built in.
  9. Apr 11, 2020 at 7:51 PM
    JohnLakeman
    If your turn signals are flashing faster than before, it's because your LEDs are just plain old LEDs which will require additional resistance added to the circuit to flash at the proper rate.
  10. Apr 16, 2020 at 1:24 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    omgboost likes this.
  11. Apr 16, 2020 at 4:18 AM
    Sunnier
    Sunny
    San Diego, CA
    That’s great! Welcome.
  12. Apr 16, 2020 at 4:24 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    This is correct. I’ve installed them on all four corners as well as for headlights. Mount it onto the steel flanges away from anything that will melt. I used two small self tapping sheet metal screws each resistor. If you don’t want to do all that work the easiest way to fix this is to get that 2020 Tundra. Problem solved!
  13. Apr 16, 2020 at 4:56 AM
    JohnLakeman
    Why would you need resisters for the headlights? And on a pre-2018 truck, you only NEED to add one 3ohm/50W resister per side...unless you're using vleds with proprietary vled resisters. If you're using a resister at each bulb, you'll need 6ohm/50W resisters.
  14. Apr 16, 2020 at 4:58 AM
    Tundyfundy
    Bay Area, CA
    I had vled with proprietary resistor as well as led front and rear turns.
    I’ve since upgraded to 2018 LED headlights.
    Krisfordman[OP] likes this.
  15. Apr 16, 2020 at 5:02 AM
  16. Apr 16, 2020 at 5:03 AM
    VLeds V6 Tritons is what you want for the DRL's.
  17. Apr 16, 2020 at 5:04 AM
    Krisfordman
    Kris
    Do you have some pics of what aftermarket headlight kit you bought? Tundyfundy? Thanks Kris
  18. Apr 16, 2020 at 5:36 AM
    JohnLakeman
    Vleds were recommended to me, but when I researched them, I found the Vleds "system" expensive and complicated.
    There were additional components (a proprietary resister for each bulb) and heavy proprietary cable harnesses and special screw-together junctions which are bulky. The Vled cable harnesses are additional to the existing Tundra harness which you must have anyway, and if you're converting to 2018+ Pro headlights, then you need the @iHacker harness as an adapter. Space behind the Tundra headlights didn't appear generous enough to stow all that stuff regardless how good the leds were. Obviously, Vleds will fit because some owners have them, but just stuffing all those "special" resisters and cables back in there is not my style. My electrical has to be routed and secured with tie straps, and the Vled resisters, cables, and special junctions weren't going to help with that.
    To convert early Gen3 Tundra to 2018+ Pro style headlights, I decided the best course was OEM Tundra wiring harness, direct to @iHacker adapter harness, direct to 2018+ headlamp housing, with generic LED turn signal bulbs front and rear and 3ohm/50W resister behind each tail light. That formula worked for me with no installation problems, and continues to provide ultra bright front and rear turn signals.
    iHacker likes this.
