2020 TRD PRO ~ Removing Dual climate panel
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by freedomoftime, Apr 13, 2020.
  1. Apr 13, 2020 at 2:57 PM
    freedomoftime
    freedomoftime [OP] Real Estate Advisor
    Buddy
    Washington State
    2020 Tundra TRD PRO Army Green
    AMP Power Step Running Boards - 10.23.19 Tinted front windows to match back - 10.20.19 Tinted windshield (70) - 10.20.19 Flag Decals on front quarter panels (matte black) - 10.23.19 Tailgate insert with USA flag - 10.23.19 Nitto Grappler G2s 285/65/18 - 10.20.19 Toyota factory Tri-Fold Tonneau Cover - 10.20.19
    Hey friends.
    Can someone please send me a great video that shows how to remove my dual climate control panel and also the one for the “push start” button?
    I’m changing the knobs and haven’t found a really good one yet. Thanks!
  2. Apr 13, 2020 at 3:32 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The black piece below it need to be pried out first then you can pry out the climate panel. I think you just need a small pry tool.
    freedomoftime[OP] likes this.
  3. Apr 13, 2020 at 3:57 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    The piece with all your USB plugs needs to come out first. Pry down, then pull straight out. The climate panel just pulls straight out.
    On my Tundra, the panel where the break controller pops out with a pry tool, but I don't have push to start. Use a plastic pry tool, be gentle.
  4. Apr 13, 2020 at 8:57 PM
    freedomoftime
    Buddy
    Washington State
    Thanks for the feedback everyone!
  5. Apr 13, 2020 at 9:13 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  6. Apr 13, 2020 at 9:46 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    As others stated, pry the bottom center piece with a plastic pry tool.
    Or stick your thumbs in the 12v plugs and pull it out.
    The bottom piece and the climate control should come out as 1 piece.
    After it is out, you can separate them.
    No need to do anything to the console.
    The little panel with your push start can be pulled 2 ways.
    1. remove door sill, remove the kickplate, remove the two bolts that hold the bottom panel in, and remove that panel. Pull your panel out.
    2. Just pry the top of the bottom panel back enough to pull the panel you need out.
  7. Apr 15, 2020 at 10:57 AM
    freedomoftime
    Buddy
    Washington State
    This is great info, thank you!
    1lowlife[QUOTED] likes this.
