Upgrading tires and wheels - Fit Check and Advice
Discussion in 'Wheels & Tires' started by Bloomjtundra, Apr 12, 2020.
  1. Apr 12, 2020 at 4:59 AM
    Bloomjtundra
    Bloomjtundra [OP] New Member
    Josh
    2011 Tundra DC 4x4
    I’ve got 18x8, 60mm offset stock steel wheels now. Looking to go with 18x9 Enkei ST6 with 30mm offset.
    Thinking of putting on 285/75r18 tires.
    Would I need to trim for this setup?
    Truck has not been leveled but I’m planning to do that as well using Bilstein 5100 or Rancho RSS999 quick lifts.
    my goal is to end up with a level truck that looks better than OE but not interested in giving up day to day practicality. Will be used by my wife a lot so don’t want to get too crazy with height.
  2. Apr 12, 2020 at 5:08 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    should be no trimming at all but maybe heat up the plastic in front
  3. Apr 12, 2020 at 5:26 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    My truck is a 2019 crewmax with 285/75r18 Falken Wildpeak AT3W. I ended up using my stock rims on 2.25” lift in front 1” lift rear. Had to remove front spat. Also have some sway bar rubbing I can live with.
    I attempted to run it with 1.25” spacers. This would roughly equal a +30 offset wheel, and I was going to have to do a lot more trimming of the front fender well, but then probably wouldn’t have rubbed the sway bar.
    Bloomjtundra[OP] likes this.
  4. Apr 12, 2020 at 6:01 AM
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    I'm running a 295/70R18 on 18x9 12mm offset, 2.25" front lift. Light trimming of front bumper plastics/ mud guard (behind fog lights) & a little plastic trim on opposite side by body mount. No BMC, mudflaps removed...no drama. I'd imagine with the slight increase in diameter of a 285/75, you may need to do a little more plastic "massaging", but that may be negated by your higher offset wheel (closer to stock). Good luck with your new meats:thumbsup:
    edgewardoe and Bloomjtundra[OP] like this.
  5. Apr 12, 2020 at 4:04 PM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    I’m leaning toward a more tame option given tire size availability in the brand/model I want BFG KO or Michelin AT2. 275/70R18 or the next is 305/65 which probably more aggressive than I care to get given all the ancillary work to make it fit right and the costs. Potentially could do 20’s in the Michelin’s. Need to decide on wheels first.
