iDatalink Maestro Kenwood Connections
Discussion in '2.5 Gen Tundras (2014-2021)' started by ghill687, Apr 11, 2020.
  1. Apr 11, 2020 at 10:47 AM
    ghill687
    ghill687 [OP] New Member
    2017 Tundra TSS Off Road
    I purchased the Maestro paired with a Kenwood DMX906s. On the Maestro wiring diagram it doesn’t give clear instructions. only shows up with a pioneer stereo. I’m a little confused on the rca aux inputs since there is no aux input on the back of the radio. Do I just use an rca to aux adapter and plug it into the av-in? Also, there are two connection points for the Maestro(the 4-pin connector and a 3.5mm jack)but the instructions just show the 4-pin. Again though, it’s shows a pioneer in the diagram, which only has the 4-pin. I would imagine I would hook both up? If anyone has any information on this I would greatly appreciate it!
  2. Apr 11, 2020 at 11:55 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You don't use the 3.5mm jack at all.
    You only use the 4 pin.
    The AUX in the dash won't work anymore.
    The only yellow RCA you hook up is the backup camera.
    You can connect your phone wirelessly, thru Bluetooth, or thru the USB.
    Make sure you have the Toyota USB adapter to use the USB in the dash to your HU.
    Maestro Acc-USB-TO2
    https://www.amazon.com/Maestro-Acc-USB-TO2-Factory-Adaptor-Vehicles/dp/B077YS81M4
    AZBoatHauler likes this.
  3. Apr 11, 2020 at 12:03 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    If you don't know, you can flash the Maestro yourself as long you have a cable to connect it to your computer.
    It is some kind of common mini USB.
    I used the Weblink Desktop, you can download it here.
    Click on 'flash your module'
    https://maestro.idatalink.com/
    If you flash it yourself you can choose specific functions of the steering wheel buttons.
    I have the same HU and the only thing I don't like about it is, you cannot use the steering wheel buttons to go thru the XM presets.
    You can either change the channel, or switch preset banks (of 6 stations).
    My Pioneer I could select the presets up and down in order.
  4. Apr 11, 2020 at 12:10 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    The only yellow RCA you will connect is the backup camera, unless you have a dash cam or headrest screens, etc...
    The AV IN 3.5mm jack of the HU is not used.
    The AUX IN RCAs of the Maestro are INPUTS into the Maestro, for the OUTPUTS of your HU.
    You can see only the 4 pin connector is used.
  5. Apr 11, 2020 at 12:13 PM
    ghill687
    Thank you for the info! I just did the flash so now I’ll get her all wired in. Do you know what can be used in the av-in port on the back of the radio?
