!!Addictive Desert Designs Group Buy!!! 2nd & 3rd gen CLOSED
Discussion in 'Marketplace - Other' started by Tundyfundy, Apr 6, 2020.
Thread Status:
Not open for further replies.
  1. Apr 9, 2020 at 6:50 AM
    #61
    coTony
    Tony
    Montrose, CO
    How thick is the metal you used for this rear bumper?
    Rica25 likes this.
  2. Apr 9, 2020 at 8:14 AM
    #62
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    1. The winch mount is integrated to the bumper. I'm talking about the actual bumper mounting plates that attaches it to the truck chassis frame.
    2. It will rub off the paint and powder coat. It will not damage the bumper but will rust if you don't take care of the powder coat. The body panel below the headlight will get damage 1st. It might even shove it up to the headlight.
    3. IDK. My only experience was with stealth fighter model.
    At the end of the day, I would follow what Toyota did for gaps for all model. Sometimes, Toyota knows what they are doing, lol.
  3. Apr 9, 2020 at 8:16 AM
    #63
    matictundra
    Franco
    AZ
    11 gauge (.120") steel. For comparison, OEM is about .080". I also spec out stronger material than OEM, about 1.25X to 1.5X stronger.
  4. Apr 9, 2020 at 8:23 AM
    #64
    matictundra
    Franco
    AZ
    I like the look of the bumper. The welds are not the best. I provided solution to them, it's actually very simple, but ADD didn't want to hear it.
  5. Apr 9, 2020 at 7:50 PM
    #65
    18" TRD Off Road Wheels
    Thanks for all the info. I appreciate your time on this. I wasn't particularly concerned with bumper damage, but rather body damage to the panels under the headlights. Sounds like this may be an issue. I'll have to see about talking with other owners of the various ADD bumpers, and to see if other stealth owners have had rubbing issues when off road. I don't plan to do a lot of off roading, but I don't want to be barred from something because of my bumper.
  6. Apr 9, 2020 at 8:25 PM
    #66
    Vizsla
    Vizsla pretend2send
    Call ADD and talk to Cole, he is a friend of mine and can set you straight.
  7. Apr 9, 2020 at 9:38 PM
    #67
    I might have to do that later in the month. What you should do is call Cole and tell him to get ADD set up as a vendor on here. :evil:
    Tundyfundy[OP] and Rica25 like this.
  8. Apr 9, 2020 at 9:54 PM
    #68
    rattail00
    rattail00 New Member
    Northwestern WA
    2017 Toyota Tundra SR5 Crewmax
    Is the group buy still available? I’d like pricing if it is.
  9. Apr 9, 2020 at 10:17 PM
    #69
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    PM pricing please
  10. Apr 9, 2020 at 10:18 PM
    #70
    55kcement
    Troy
    Sonora ca
    Currently none
    I really like both bumpers they seem to follow the body lines nicely
  11. Apr 9, 2020 at 11:50 PM
    #71
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    PM'd
  12. Apr 9, 2020 at 11:51 PM
    #72
    Tundyfundy
    Bay Area, CA
    PM'd
  13. Apr 10, 2020 at 9:28 AM
    #73
    coTony
    Tony
    Montrose, CO
    Is the pricing not public?
  14. Apr 10, 2020 at 9:37 AM
    #74
    Tundyfundy
    Bay Area, CA
    At the request of ADD, correct.
    jewsNbrews likes this.
  15. Apr 10, 2020 at 10:07 AM
    #75
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Agreed. I guess I should also get some pricing.
    jewsNbrews and Tundyfundy[OP] like this.
  16. Apr 10, 2020 at 10:24 AM
    #76
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    PM pricing please.
    Tundyfundy[OP] likes this.
  17. Apr 10, 2020 at 10:27 AM
    #77
    Tundyfundy
    Bay Area, CA
    PM’d
  18. Apr 10, 2020 at 10:28 AM
    #78
    Tundyfundy
    Bay Area, CA
    PM’d
  19. Apr 10, 2020 at 10:50 AM
    #79
    Jay77
    Jay77 New Member
    2017 White Tundra SR5
    4" lift 22" Fuel wheel w/33s Puddle light LED head lights JL audio stealth box 2x10 subs
    Dude thanks for the update, this will help! I just placed the order on Thursday, for the stealth front/back bumpers. I am pumped to get them on!
  20. Apr 11, 2020 at 12:36 AM
    #80
    For the life of me I cannot find squat for reviews, pics, or videos on the ADD Honeybadger front bumper for a Tundra. Lots of shit for Fords and Tacos, but not the Tundra. Nothing but the basic stock photos, or shots of the first one they did on the light blue jacked up Tundra for SEMA, and those don't help because it's been tweaked since then. Just look at the small light bar opening in the front of the bumper and you can see they've changed it.
    I can't find an install video, shots that aren't looking up at the truck from below, nothing. Killing me, because is LOOKS like it might sit in front of the panel under the head lights. If it does, then it might not have the same rubbing issues as the Stealth Fighter bumper when the truck twists and flexes.
    The pic below shows where I am looking, but I can't tell if that piece has been trimmed (doubt it because the instructions say nothing about trimming) or how close the bumper sits to it. I still think the Stealth has a cleaner look, but I don't know if I want to deal with having to rework it to make it function the way it should from day one.
    Plus, I need to find out if any of these bumpers are compatible with my RCI Offroad skid plate. I don't want to have to go chopping that up, or bending it to make it work for a bumper.
  21. Apr 11, 2020 at 1:18 AM
    #81
    TXTundra2722
    2015 Black Tundra
    Just a leveling kit without a BMC on that little Tundy, right?
    :transformer:
    Rica25 and Tundyfundy[OP] like this.
  22. Apr 11, 2020 at 1:21 AM
    #82
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    I got my ADD Stealth Fighter bumpers after a 4 car pile up that I was sandwiched in between of. Figured if I was gonna do it, that was the time. Auto Anything gave me a nice discount on both bumpers and lights but I’d still be interested in getting a PM with the price list. I still need some other things.
    And yes, it needs some tweaking for proper install. Don’t believe them when they say it was an isolated incident. Lol
    here’s mine
    I plan to remove the stealth fighter end logos and have that part powder coated white.
  23. Apr 11, 2020 at 1:25 AM
    #83
    FancyPants
    Amber
    Oregon
    I have the Victory 4x4 skid plate that I need to install still but it (and the RCI one) will need trimming in order to work with my ADD stealth fighter bumper.
  24. Apr 11, 2020 at 1:29 AM
    #84
  25. Apr 11, 2020 at 2:13 AM
    #85
    Tundyfundy
    Bay Area, CA
    PMd
    FancyPants[QUOTED] likes this.
  26. Apr 12, 2020 at 7:50 PM
    #86
    SmokinGunner
    SmokinGunner New Member
    Gunner
    OREGON
    2017 Tundra CrewMax SR5 TRD Off-Road MGM
    Firestone airbags, Gator FX3 Tonneau Cover, Ionic Nerf Bars. 2017 Outback 250 URS Arctic RV
    PM'd for Stealth Fighter pricing
    Tundyfundy[OP] and FancyPants like this.
  27. Apr 12, 2020 at 8:48 PM
    #87
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Correct
  28. Apr 12, 2020 at 9:27 PM
    #88
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    Please send me a price. I really want that stealth bumper!!
  29. Apr 12, 2020 at 9:30 PM
    #89
    Double Badass
    James
    Arizona
    What light bar did you go with in your bumper? What part of Arizona I'm in Chandler
  30. Apr 13, 2020 at 9:28 AM
    #90
    Tundyfundy
    Bay Area, CA
    PMd
Thread Status:
