  1. Apr 10, 2020 at 5:58 PM
    #6691
    Boltzfan213
    Boltzfan213 New Member
    2012 black crew max
    3 inch lift, bully dog platinum tuner, fender flares, k&n cold air intake, flowmaster 40 series.
    K&n cold air intake, flow master 40 series muffler, bully dog gt platinum tuner, trac rack sliding rack system, 34" mastercraft, 18" fuel vapor 569 rim's, ruff country fender flares.
    D4x4TRD, Rica25, Prostar 190 and 5 others like this.
  2. Apr 10, 2020 at 7:39 PM
    #6692
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    0C162888-D88C-44A5-90D0-497BA9E6E259.jpg Finally got my Prinsu roof rack installed!!
    D4x4TRD, ToastyStew, Rica25 and 9 others like this.
  3. Apr 10, 2020 at 7:54 PM
    #6693
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I started my front brake endeavor.
    After a nice wobble when brakes applied to some crappy aftermarket rotors I went back OEM.
    Put some power stop pads in there too.
    Once I was in there I saw that some of the seals around the caliper pistons were dried out and cracking.
    So I order refurbished OEM calipers
    all new brake tubes
    Stop tech stainless hoses.
    Front brakes should be butter smooth next weekend
  4. Apr 10, 2020 at 10:30 PM
    #6694
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    Was that straight plug and play? No tweaking or harness issues? Looks good!
  5. Apr 10, 2020 at 10:43 PM
    #6695
    TheBeast
    TheBeast The Beach
    looks great..spying some Morimotos headlights too ;)
    #covid19projects
    Rica25 and alwzdfiant[QUOTED] like this.
  6. Apr 10, 2020 at 11:19 PM
    #6696
    kgb4187
    kgb4187 New Member
    From behind they're the same, just remove the housing like when you change the bulbs and put it in the new one.
    If you want to overdo it you can put all new bulbs in and replace the tailgate damper since you'll have the light out.
    sensei[QUOTED] likes this.
  7. Apr 11, 2020 at 7:48 AM
    #6697
    War Machine
    War Machine SSEM # 5 3MW
    Changed out the headlights this morning.
    bdogg76, toyofan87, D4x4TRD and 9 others like this.
  8. Apr 11, 2020 at 8:34 AM
    #6698
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    Those look great! Do you have a link?
  9. Apr 11, 2020 at 8:52 AM
    #6699
    alwzdfiant
    Heck yea, couldn’t pass up on that 20% off sale!
    Rica25 and TheBeast[QUOTED] like this.
  10. Apr 11, 2020 at 1:01 PM
    #6700
    War Machine
    Just cheap ones from Amazon. We’ll see how they hold up. Great fit though.
    AJP Distributors Replacement Front Driving Black Housing Clear Lens Signal Reflector Headlights Headlamps Assembly For Toyota Tundra 2007 2008 2009 2010 2011 2012 2013 07 08 09 10 11 12 13 https://www.amazon.com/dp/B071QY8M62/ref=cm_sw_r_cp_tai_miIKEb61CKDM9
    Rica25 likes this.
  11. Apr 12, 2020 at 9:21 AM
    #6701
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Got a bit more on the roof rack last night. I added a couple more pieces, and got the majority of it’s welded. Happy Easter meester
    D4x4TRD, BigSkyTaco, Rica25 and 7 others like this.
  12. Apr 12, 2020 at 9:28 AM
    #6702
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Looking good! Did you add the extra for space, looks or to stiffen it up?
    Mountun Goat[QUOTED] likes this.
  13. Apr 12, 2020 at 9:30 AM
    #6703
    Looking good!
  14. Apr 12, 2020 at 9:31 AM
    #6704
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks. Bit of both. The two vertical posts under the top rail I added for stiffening. The two horizontal ones I put in the uprights are more for looks/function. I wanted to add these to keep it evenly split up and it will work for a grab handle if I’m climbing up over the side of the box. :headbang: Getting close!
    Kerch71 and TruckyTruck[QUOTED] like this.
  15. Apr 12, 2020 at 9:32 AM
    #6705
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks man, I’m having fun!
  16. Apr 12, 2020 at 12:30 PM
    #6706
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I was going to plasti dip the emblem last week but taping off steering wheel and putting up a back drop would of took forever IMO. I used MGM touch up paint. Turned out good.
  17. Apr 12, 2020 at 12:41 PM
    #6707
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Finally got around to painting the instrument panel trim black. The silver had to go:
    Also replaced silver climate control knobs with black and red AJT Designs knobs. Think they look pretty sweet!
    I posted here because the cab of my truck is a 2nd gen 07. Rest of it is 3rd Gen 15. It's been called a transgender Tundra. Yes, I'm comfortable with that. :thumbsup:
  18. Apr 12, 2020 at 12:48 PM
    #6708
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    After reading some threads on here I removed the front sway bar.
    Wow, what an improvement. Such a better ride.
    Took it on the freeway and some graded dirt without ill effect.
    Your mileage may vary....
    BigSkyTaco, Rica25, f.pecan and 5 others like this.
  19. Apr 12, 2020 at 2:49 PM
    #6709
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :headbang:
    Best free mod around!
    Rica25, TheBeast, TG705 and 1 other person like this.
  20. Apr 12, 2020 at 2:52 PM
    #6710
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :headbang:Lookin good. Love your truck so I guess I’m a bit of a Cisgender according to the inter web:eek::transformer:
    Yes, I’m comfortable with that.
    Rica25, Kerch71[QUOTED] and f.pecan like this.
  21. Apr 12, 2020 at 7:52 PM
    #6711
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Diff and transfer case fluid change.
    Im seriously running out of maintenance things to do on the Tundra!
    BigSkyTaco, Kerch71, TheBeast and 3 others like this.
  22. Apr 13, 2020 at 3:12 AM
    #6712
    Kerch71
    Mechanicsville VA
    Man, that looks righteous! Can't wait to see it on your truck. Really like the design.
    Mountun Goat[QUOTED] and Rica25 like this.
  23. Apr 13, 2020 at 7:22 AM
    #6713
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks a lot! I’m pretty excited to get it mounted also.
    Kerch71[QUOTED] likes this.
  24. Apr 13, 2020 at 9:38 AM
    #6714
    TheBeast
    TheBeast The Beach
    running out of mods to do.....I might do an oil change this week...lol #covid19projects
    TG705, Mountun Goat and Prostar 190 like this.
  25. Apr 13, 2020 at 10:18 AM
    #6715
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I have been wanting to do this. Will that emblem pop off, or did you paint it in place:eek2:
    Ron12345 and Rica25 like this.
  26. Apr 13, 2020 at 10:33 AM
    #6716
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Haha me too. Took my UCAs apart yesterday to clean and grease them even tho they didn’t need it. Currently waiting for my ADS rear bumps to come in
    Rica25 likes this.
  27. Apr 13, 2020 at 10:34 AM
    #6717
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    :headbang:
    Rica25 and Mountun Goat[QUOTED] like this.
  28. Apr 13, 2020 at 11:07 AM
    #6718
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :fistbump::headbang:
    TG705[QUOTED] and Rica25 like this.
  29. Apr 13, 2020 at 12:12 PM
    #6719
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I painted it in place. The masking wasn’t too hard and I didn’t feel like messing with my airbag to see if it would come off.
  30. Apr 13, 2020 at 12:13 PM
    #6720
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Agreed, I masked mine as well.
    Rica25 likes this.
