Need Help Removing Exhaust Tip...
Discussion in '2.5 Gen Tundras (2014-2021)' started by TacomaLC, Apr 9, 2020.
  1. Apr 9, 2020 at 11:07 PM
    TacomaLC
    TacomaLC [OP] New Member
    Chip
    T-town
    2020 Tundra Voodoo 2000 Tundra LTD Red (rest in pieces)
    De-chroming: Swapping the chrome exhaust tip on my Platinum for the black tip that comes on a TRD Pro.
    My problem is the last 3-4 inches of the exhaust pipe flares out (maybe a 1/4 to 1/2 inches in diameter. Due to deformation or expansion, the existing exhaust tip is now too narrow to fit over the expanded section. The illustration depicts this expanded flange and the spacers used to secure both the existing tip and the new one.
    Has any one successfully gotten the old tip off? If so, how? Any suggestions are welcome. Thanks!
  2. Apr 9, 2020 at 11:17 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Take a piece of wood, thick wood and put it against the pipe end of the top and whack it off. It will take a while, and a lot of elbow grease but keep whackin till it’s off.
    Dashpp, gabex35, SIXSEVENONE and 5 others like this.
  3. Apr 9, 2020 at 11:21 PM
    TacomaLC
    Chip
    T-town
    That may do it. I'll give it a shot tomorrow.
  4. Apr 9, 2020 at 11:21 PM
    AZBoatHauler
    So.Arizona
  5. Apr 9, 2020 at 11:32 PM
  6. Apr 10, 2020 at 12:07 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Ask me how I know! :anonymous:
    GODZILLA[QUOTED] likes this.
  7. Apr 10, 2020 at 1:04 AM
    I refuse to ask you about any of your experiences "whacking" anything off. o_O
  8. Apr 10, 2020 at 1:06 AM
    AZBoatHauler
    So.Arizona
  9. Apr 10, 2020 at 1:26 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Hey in all seriousness, the flared portion is not a deformity, flaw, or expansion in the tailpipe, it comes that way from the factory. You’ll notice some trucks without an exhaust tip still have that flared portion of the tailpipe, and if you buy a replacement tailpipe you’d see the same thing. The only way to remove the existing tip is to cut off that flared section. You may find this thread to be helpful:
    https://www.tundras.com/threads/anyone-added-exhaust-tip-to-stock-tailpipes.3930/
    NewImprovedRon likes this.
  10. Apr 10, 2020 at 1:45 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    You need to get the spacer out before that tip can come off.
    Rob's Inferno likes this.
  11. Apr 10, 2020 at 4:26 AM
    Take the spacers out, stick a large screwdriver in there and bend it outwards all around you will be able to pull it off.
  12. Apr 10, 2020 at 4:39 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    If there is a bolt on there they will come off. Loosen the bolt and the spacers will come out and the tip will come off. If there is no bolt they are welded and they are coming off. As far as the pro/TRD dual exhaust those tips are welded on and I have not seen them for sale. You can get flat black ones that attach with the two spacers and the bolt.
  13. Apr 10, 2020 at 4:45 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    The spacer is held in with the ring that was tightened down to install the tip. There is no way to get any screwdriver in there to loosen it, trust me!!
    The piece of wood at the end of the tip up the pipe tube and whack the crap on it till it comes off. I swear I must’ve took an hour before it even started budging and slowly started creeping off the pipe.
  14. Apr 10, 2020 at 5:44 AM
    I removed mine with a screwdriver. Loosen the tip remove the spacer, place screwdriver where spacers were and bend it up ALL around the diameter of the tip and then pull it off. :muscleflexing:
    Black@Blue19 likes this.
  15. Apr 10, 2020 at 5:51 AM
    xtyfighterx
    Ty
    North Idaho
    I’ve done it to mine plenty of times? Idk Maybe im magic.
    takenthe clamp off and move the tip get the spacer out and it will come off take a little force but every time I’ve done mine it wasn’t an hour of work. It’s defiantly a tight fit but I don’t see why you would have to cut the end of your tailpipe off to get the tip off to install another.
    Jim LE 1301 likes this.
  16. Apr 10, 2020 at 6:35 AM
    xtyfighterx
    Ty
    North Idaho
    Exactly what I did. Maybe we just have too many brain cells? Wait no such thing.
  17. Apr 10, 2020 at 6:39 AM
    Maybe they tried using a phillips head screwdriver!:facepalm:
  18. Apr 10, 2020 at 6:48 AM
    xtyfighterx
    Ty
    North Idaho
    Has to be it. You would be surprised how many people don’t know what a screwdriver is tho.
  19. Apr 10, 2020 at 6:53 AM
    :rofl::rofl::rofl:
  20. Apr 10, 2020 at 2:29 PM
    TacomaLC
    Chip
    T-town
    I guess I need to clarify: From the beginning I removed all mounting hardware (Spacer and fully removed clamp) I've tried to gently pry with a FLAT HEAD screw driver. I was just wonder if any one had a "trick" but I think it's just a brute force and hammer kind of thing. And when I spoke of deformation I was referring to the tip section where it is secured and possibly over tightened.
    BTW, I Just put on my new skid plate and was unimpressed with Toyota's QC. Missing clips and fasteners for the original skid plate. Wonder what else is done poorly. My Indiana assembled truck was muy bueno!
  21. Apr 10, 2020 at 2:32 PM
    Don't be gentle. Put the screwdriver in and pry it all around. It will be out of shape but if you or someone else uses it again once you put the spacers and clamp back on it will take the round shape again.
    Don't give up.
    This is the best way and less damaging.
    TacomaLC[QUOTED][OP] likes this.
  22. Apr 10, 2020 at 2:42 PM
    TacomaLC
    Chip
    T-town
    That skid plate install was a bitch solo and not using a full lift. got a little claustrophobic under there. I'll work on the exhaust soon.
    Also, anyone thinking about the TRD skid plate it's a no brainer. one is thin gauge steel and the other is 1/4 Al plate. Here's the difference in coverage area:
  23. Apr 10, 2020 at 3:49 PM
    xtyfighterx
    Ty
    North Idaho
    A jack helps on that install. Looks great I need one
  24. Apr 2, 2022 at 6:09 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Update: Got it off…just wedged with screw driver and pulled.
    Lol, I am struggling with this now. Have it soaking in some penetrating oil. Was using a flat head to pry without much success. Will step up to a bigger screw driver. If all else fails, cut off wheel to the chrome I guess
  25. Apr 2, 2022 at 1:29 PM
    :thumbsup:
