Advice needed please
Discussion in '2.5 Gen Tundras (2014-2021)' started by tttrdpro, Apr 9, 2020.
  1. Apr 9, 2020 at 10:30 AM
    tttrdpro
    tttrdpro [OP] Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Hey guys, I screwed up this morning going through an unfamiliar to me drive thru to pick up breakfast. I’m no body work/paint expert. Can anyone tell me how to fix this? If it can be fixed? Alternately if I’m better off with a new one, should I replace the one with OEM or go with a particular set of aftermarket flares. Any help/advice will be greatly appreciated. Truck is a 2019 Pro. I’ve already washed the area. Thanks in advance 5342338A-20A8-46F3-A2AA-45F9AA7592C7.jpg
  2. Apr 9, 2020 at 10:36 AM
    Did you try buffing it out? Doesn't look that bad in the picture.
  3. Apr 9, 2020 at 10:39 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    My thought as well. Is it coloration on top of the paint, or did it go into the paint? If it's on top, it'll buff off. If it took paint off, it'll need some R&R.
  4. Apr 9, 2020 at 10:41 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    It should clean up fairly well. Do you have a da polisher?
  5. Apr 9, 2020 at 10:43 AM
    mr_lasseter
    mr_lasseter New Member
    Magic eraser?
  6. Apr 9, 2020 at 10:45 AM
    ToyoMafia
    Magic carpet.
    I would start with a light buff and shine approach before I get out the magic eraser. My wife closes the garage door on her back bumper all the time and I just hit it with the polisher bam problem fixed
    Tundyfundy and tttrdpro[OP] like this.
  7. Apr 9, 2020 at 10:46 AM
    TheTripleLindy
    TheTripleLindy New Member
    I have had a lot of luck with WD-40 on paint that does not belong. Take a could clothe and your arm is going to be very tired.
    tttrdpro[OP] likes this.
  8. Apr 9, 2020 at 10:47 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Thanks guys, I’ll try to buff it out when I can get my hands on a buffer. I guess I just figured with my luck, I was automatically screwed. Not that having to repair/replace a fender flare is any big deal, I guess I’m a bit on edge because of all the covid 19 crap going on. Hope everyone and their families stays well and safe.
    Jim LE 1301 and ToyoMafia like this.
  9. Apr 9, 2020 at 10:48 AM
    Wallygator
    I wouldn't bother with spending too much money or time on this. That should buff out. Chalk it up as a learning experience, meaning I doubt you will make that mistake again. It probably could have been a lot worse.
    Tundyfundy likes this.
  10. Apr 9, 2020 at 10:49 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Thanks Triple, I’ll give the wd-40 a shot.
  11. Apr 9, 2020 at 11:12 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Rubbing compound and a damp cloth should get the paint off with a little elbow grease. Then follow up with a polish or wax to even it out. Easy peasy.
    AZBoatHauler likes this.
  12. Apr 9, 2020 at 11:15 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Part out. How much for the wheels?
  13. Apr 9, 2020 at 11:31 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    Something similar happened to my last tundra in 2018. I went through a drive through banking machine and rubbed against a yellow post. I nearly fainted when I saw the damage cause the truck was like a week old.
    Anyway, I used a micro fibre towel and tartar toothpaste and it all came off one shot. I know it sounds retarded but it worked for me. I’ll post a pic when I was half way taking the yellow paint residue off.
  14. Apr 9, 2020 at 12:45 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    The damage doesn’t look bad. I would definitely do this, $5 can of rubbing compound on a damp micro fiber and it should come right off. Some lady hit my mercedes bumper and left all types of scuff marks and it all came off with some rubbing compound and elbow grease.
    Inquiringone likes this.
  15. Apr 9, 2020 at 12:51 PM
    808Guy
    808Guy New Member
    Midwest
    2020 White Tundra SR5 CrewMax
    3" ReadyLift
    If it doesn't work out sell it to me. Also, do you have your oem color matched bumper to sell?
  16. Apr 9, 2020 at 12:54 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    :itllbuffout:... :popcorn:...Good luck.
  17. Apr 9, 2020 at 1:01 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Magic Eraser
  18. Apr 9, 2020 at 3:03 PM
    GreyGhost15
    GreyGhost15 New Member
    2015 MGM TUNDRA SR5 CREWMAX 4X4
    https://www.tundras.com/threads/big-easy-build.66540/#post-1731305
    mcguires scratch x with a buffer
