Cleaning engine and engine compartment.
Discussion in 'Detailing' started by lone_wolf, Apr 5, 2020.
  1. Apr 5, 2020 at 12:25 PM
    lone_wolf
    lone_wolf [OP] New Member
    Frank
    Cape Coral, FL.
    2018 Tundra SR5
    Stripes. cap, alarm, marker lights, reflectors.
    Good day, I hope you're doing okay with all this mess!
    Years ago I was led to believe that cleaning the aforementioned wasn't good. Is this still true? If it's doable what's the best way to do it? I know they used to have spray engine cleaner for it.
    Thank you!
  2. Apr 5, 2020 at 12:37 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I avoid but if you 'have' to, wrap in plastic/secure all electrical items, connections (that's where water gets in and then shorts out when you turn ignition on) and so for. Certainly avoid high pressure.
    Might want to consider some kind of spray on, foamy stuff that "self-rinses",sort of....Luck.
    lone_wolf[OP] likes this.
  3. Apr 5, 2020 at 12:41 PM
    lone_wolf
    Frank
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks, that's what I remember from the past. I think I'll just wipe off what I can.
  4. Apr 6, 2020 at 7:46 PM
    briarpatch
    briarpatch New Member
    YardBird and Inquiringone like this.
  5. Apr 6, 2020 at 8:04 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
  6. Apr 6, 2020 at 8:27 PM
    Johnsonman
    Austin
    Sequoia
    If I'm not mistaken I believe auto dealers have the used ones cleaned with steam, might check that possibility out. I'd clean mine but it goes off-roading every other weekend, so it would be an endless task, besides I like dust...
    Rex Kramer likes this.
  7. Apr 6, 2020 at 11:33 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Hey man! With all newer cars now a day, the engine bay is pretty safe for water! I have a 17 tundra and to clean it I just hit it with a pressure washer. The key is not to be too close, give it distance and always be moving, and not to focus all the water on one spot for a certain time! If that makes sense!
    Inquiringone likes this.
  8. Apr 7, 2020 at 3:59 AM
    timsp8
    NY
    I live in an area that gets snow and a lot of road salt and pressure spray my engine and underneath frequently and haven’t had any issues. I just did it yesterday with water only to get dirt/dust off. I’ve used some cleaners and some will leave a film on the plastic parts and discolor them so watch which ones you try.
  9. Apr 7, 2020 at 9:19 AM
    lone_wolf
    Frank
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks all for your replies!
  10. Apr 7, 2020 at 10:52 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Resized_20191026_101926[13882].jpg I jumped on mine while it was new and stayed on top of it, so it stays clean.....but it's a "garage queen" too!:D
    Sean492, YardBird, 19h341 and 5 others like this.
  11. Apr 7, 2020 at 3:30 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Did you replace the foam in front of the radiator (that deteriorates over time) with that flap? Homemade or aftermarket?
    Hammerdog likes this.
  12. Apr 7, 2020 at 3:38 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    I spray simple green or spay nine on a cold engine and then rinse with a regular Garden hose hose sprayer , todays engines and connection are all weather proofed , just done concentrate on any one spot to long with the water . I’ve been doing this for 15 yrs or more and never had an issue , the key is only on a cold engine .
    Creatures 1982 and lone_wolf[OP] like this.
  13. Apr 7, 2020 at 3:39 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Sorry I had a typo , spray nine .
  14. Apr 7, 2020 at 3:53 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Nothing like a clean garage queen.
    You might be able to make a:sandwich:
    There.
    :blahblah::blahblah: I need to do mine too.
    YardBird and lone_wolf[OP] like this.
  15. Apr 7, 2020 at 4:04 PM
    lone_wolf
    Frank
    Cape Coral, FL.
    2018 Tundra SR5
    Wish I had a garage it would fit in to but I still manage to keep "Otis" clean like he lived in one. My last two trucks were Toyota's and had them each for 16 years. Plan to keep this one that long and get my next one when I'm 81.
  16. Apr 7, 2020 at 4:20 PM
    Inquiringone
    Ter
    NorCal 408
    :mudding:
    This is my second 16 I’ve bought in 4 years. I’m hoping this is my last Tundra to buy, unless I Win the lottery ...:mudding:
  17. Apr 7, 2020 at 4:29 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Simple Green twice a year..50k miles, looks new.
    Flyinryank, bleach, WFD473 and 6 others like this.
  18. Apr 7, 2020 at 4:38 PM
    lone_wolf
    Frank
    Cape Coral, FL.
    2018 Tundra SR5
    Looks great. Simple Green and cold engine.
    YardBird and TRD423[QUOTED] like this.
  19. Apr 7, 2020 at 4:42 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  20. Apr 7, 2020 at 6:44 PM
    19h341
    19h341 New Member
    Scott
    League City
    19 MGM crew
    Tint, scs ray 10s, bfg 275/70/18
    I’ve always had a dirty engine bay because I was scared to get it wet. Definitely doing this to me and the wife’s car
    BTBAKER, lone_wolf[OP] and YardBird like this.
  21. Apr 7, 2020 at 7:03 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    That’s what I do.
  22. Apr 8, 2020 at 2:38 AM
    CMB
    CMB New Member
    Cecil County MD.
    Just used a piece of rubber strip I had laying around.
  23. Apr 8, 2020 at 4:07 AM
    War Machine
    War Machine SSEM # 5 3MW
    jtwags, ToyoMafia and lone_wolf[OP] like this.
  24. Apr 8, 2020 at 4:34 AM
    11CMGray
    11CMGray New Member
    This is just my 2 cents. I work at dealership and have probably degreased and pressure washed close 10k engines. Never covered anything up, but I make sure I try and to avoided the alternator,l and intake as much as possible. That being said...I cover those parts up on mine (just in case lol)
    Warm up the engine, if it's pretty dirty I use some simple green. Spray off and dry. I then wipe the hard plastics with a non greasy spray(usually for interior dashes).
  25. Apr 9, 2020 at 4:57 PM
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    My foam strip also separated recently.What's the purpose of that anyway?
  26. Apr 10, 2020 at 3:00 AM
    CMB
    CMB New Member
    Cecil County MD.
    My guess is,one of the Tundra engineers, had a boyfriend in the foam rubber industry :D
    War Machine likes this.
  27. Apr 10, 2020 at 3:49 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    What did you use to paint your engine cover and what battery hold down do you have?
  28. Apr 10, 2020 at 3:54 AM
    CMB
    CMB New Member
    Cecil County MD.
    Engine cover paint is Krylon Fusion For Plastic.I bought the Battery Clamp from Coup, he's a vendor on the forum.
  29. Apr 10, 2020 at 3:59 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Awesome, is that a red light on the radiator support?
  30. Apr 10, 2020 at 4:10 AM
    CMB
    CMB New Member
    Cecil County MD.
    The red light you see is my underhood light switch.These pics were taken before I bought the CAI and went crazy with masking tape and spray paint!:oldglory:0623151347.jpg 0424190427[2965].jpg
