Man Fills Wife’s Car with Concrete
Discussion in 'Off-Topic Discussion' started by bleach, Apr 6, 2020.
  1. Apr 6, 2020 at 1:10 PM
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
  2. Apr 6, 2020 at 3:17 PM
    Outbound
    Aaron
    Northern Alberta
    @War Machine, what's the best product to use to clean that car out?
  3. Apr 6, 2020 at 3:19 PM
    timsp8
    NY
    I bet she is over her car’s payload.
  4. Apr 6, 2020 at 3:22 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Reminds me of a guy on here asking about a gas tank schematic after his girlfriend poured sugar in his gas tank. Lol
  5. Apr 6, 2020 at 3:49 PM
    War Machine
    War Machine SSEM # 5 3MW
    @Jim LE 1301 is the expert at handling hardened materials.
  6. Apr 6, 2020 at 3:50 PM
    Outbound
    Aaron
    Northern Alberta
  7. Apr 6, 2020 at 4:03 PM
    bleach
    DJ
    Battle Ground, WA
    A little more about what happened with the car. You'll need someone to translate.
    Another one where a guy fills a Lada with concrete and then tries to drive it. Dubbed in English.
    Tacogrande and Cpl_Punishment like this.
  8. Apr 6, 2020 at 5:14 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    bleach[OP] likes this.
  9. Apr 7, 2020 at 8:12 AM
    Kung
    KG, VA
    In Russia, concrete hits your car!
  10. Apr 7, 2020 at 9:48 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    TNT or C4 would do it
  11. Apr 7, 2020 at 9:55 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Believe mythbusters did a test to see how much explosive is needed to demolish a cement truck that has solidified.
  12. Apr 7, 2020 at 9:59 AM
    bleach
    DJ
    Battle Ground, WA
    Concrete engine mod.:der:
    P-Factor likes this.
  13. Apr 7, 2020 at 10:57 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Better than acid on the face. Geez who does that???
