Code P1126
Discussion in 'General Tundra Discussion' started by weeks2x4, Nov 9, 2018.
  1. Nov 9, 2018 at 7:08 AM
    weeks2x4
    weeks2x4 [OP] New Member
    Christina
    2002 Toyota Tundra
    4.7 V8
    I have a 2002 Tundra with almost 300,000 miles on it. For her age she runs well except for the last few weeks. I've noticed that it seems to not be accelerating like it should or is sometimes (for lack of better description) sluggish. Then 2 days ago the check engine light came on and I had it checked and it was a P1126 code. I know I should check the magnetic clutch circuit for a short or bad connection but I'm a chick and don't know where that is lol. any help would be appreciated. Also if I end up needing to replace the throttle body all together where could I find a genuine 2002 tundra part so I can install in myself? (can't afford a mechanic)
  2. Nov 9, 2018 at 7:46 AM
    @Roman parts guy, hope y'all get issue fixed soon
    Roman likes this.
  3. Nov 9, 2018 at 9:21 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    TXRailRoadBandit73 likes this.
  4. Nov 9, 2018 at 10:00 AM
    weeks2x4
    Christina
    2002 Toyota Tundra
    4.7 V8
    Thanks, that looks like a reasonable price
    Roman likes this.
  5. Nov 9, 2018 at 1:17 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Hello and welcome to the party!
    This might not fix all the issues your having but have you ever tried cleaning your MAS sensor?
    I find that with high mileage vehicles that the MAS sensor is always over looked..
    I my experience I have been able to "bring back some life" into high mileage vehicles. The MAF detects how much air is coming in and determines how much fuel is needed.. When you take it out you wont really be able to see the dirt with the naked eye and it'll "look" clean.
    Try cleaning the MAF and the throttle body to see if that helps.
    Once completed you might want to "RESET" the ECU by disconnecting the battery for about a minute or so. Should take about 50 miles fo your ECU to learn/adjust.
    Cheap and easy to do and might be the answers to your issues.
    Take pictures if/when you do this!! I'd like to see how dirty the throttle body is..
    These are the cleaning agents you'd want to use.
    https://www.walmart.com/ip/CRC-MAF-...XasvjHeGdDMAsA3I1FiK_fk_6CyQDg5BoC_3sQAvD_BwE
    Video of MAF cleaning
    https://www.youtube.com/watch?v=lbI-GQObduk
    Throttle Cleaning
    https://www.youtube.com/watch?v=a3exL-VH3Hg
    Hope this helps..
    Keep us posted
    intellexualist likes this.
  6. Apr 5, 2020 at 3:46 PM
    snowyming2006
    snowyming2006 New Member
    2002 Toyota Sequoia
    Thanks challenge1. I had a P1126 code. Instead of spending hundreds of $$ on replacing the throttle body assembly.
    Cleaned the MAF, reset the ECU (removed battery terminal for about a minute).
    No more check engine light!
    Filthyphil and Challenger1 like this.
  7. Apr 5, 2020 at 3:57 PM
    Challenger1
    Andy
    That’s great news!
    Glad I was able to help!
