  1. Apr 4, 2020 at 5:55 PM
    TundraMash
    TundraMash New Member
    Tyler
    '17 Black Tundra SR5 4x4
    17 inch Icon Six Speed, BFG 285/75, ReadyLift 3/2 spacer lift, Bilstein 5100s in rear, Remote lock tailgate, leather wrapped steering wheel, driver side grab handle, LED headlights, LED interior lights, plastidipped dash components and grill, factory remote start, AJT climate knobs,
    What roof rack do you have?
    14srAKH likes this.
  2. Apr 4, 2020 at 6:00 PM
    AZBoatHauler
    So.Arizona
    Best interior I’ve seen. Nicely done!
  3. Apr 4, 2020 at 6:17 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Finally did Raptor liner to the truck bed.
    georgiey22, ElNopal, GHOST and 10 others like this.
  4. Apr 4, 2020 at 6:18 PM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    It doesn’t come with the light bar but you can add any 40” curved bar or up to 10 cubes if you like doing a lot of wiring. Lol
    I love the bumper. I also have the stealth rear bumper. I wanted something that wasn’t bulky but wasn’t just steel tubing.
    I actually just installed a Warn winch a few days ago and rescued a guy stuck on the beach earlier today.
    I can post some more pictures for you tomorrow.
  5. Apr 4, 2020 at 6:20 PM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    No sir waiting on my government check getting the morimotos they had a package deal with the fogs
  6. Apr 4, 2020 at 6:21 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Rhino Rack
    I can take some pictures for you tomorrow, if you’d like.
    14srAKH and jewsNbrews like this.
  7. Apr 4, 2020 at 6:32 PM
    Blue Thunder
    Washington
    Waxing is done. I've been on my feet for 8 hours and everything hurts. Nothing a beer won't cure
    And a present came in the mail that I forgot I ordered...Will snap these on the fogs tomorrow.
  8. Apr 4, 2020 at 6:36 PM
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    Thanks brother
  9. Apr 4, 2020 at 6:55 PM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    Tow hooks are finally red which added at least 6 horsepower and a much needed foam canon bath.
    E833A01B-2A02-4918-BB0F-191875905018.jpg 5EC8DE5F-3837-494A-B8E1-A82908F448BA.jpg B7A842C9-3AF5-4617-A89D-5384BCF8D6D9.jpg 2731203E-6CD6-4B7D-BD82-E8163EAFDBD8.jpg
    yoshi82, Redwinger, ElNopal and 16 others like this.
  10. Apr 4, 2020 at 6:56 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Couple hours on a nice sunny day. You need to drill some holes in the bottom of each cupholder for eh wires to go through. Took off the shifter handle and popped the cupholder center dash section out. Drilled the holes and then parallel combined the 3 LED ring lights into 2 plugs. I ran a dimmable hot from the dash (It took me about an hour to find a way to route the dimmable hot wired from mid dash under head unit to the center cupholder area. I took a ground from the 12V Center console socket and plugged the dimmable hot and ground into the other plug end on the LED lights wired in parallel. closed up the center panels and it worked. fine. I do have one problem, the dash dimmable lit switches have voltage that decreases as the dash light dim. Not sure how that's possible and that's the line I used. Fortunately the cupholder lights stay well lit on all but the brightest dash setting (which turns off the cupholders). I may just hook up the hot from the 12V plug in the center console and have the cupholder fully lit when the truck is on. I also did not peel the tape on the back of the LED cupholder light disks. I want to be able to remove them for cleaning and gravity seems to hold them in place just fine. I was careful to drill the holes in the bottom of the cupholder so the wires fed straight down and didn't bind under the LED disk.
    Overall I really like them and it's an easy install.
    ElNopal and 2010bigdog[QUOTED] like this.
  11. Apr 4, 2020 at 7:16 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Got it a little dirty today (took the back roads to get dinner while the main road was closed due to a gas leak).
    ElNopal, Fotnot, Ostrich and 10 others like this.
  12. Apr 4, 2020 at 7:18 PM
    Actually looks cool. That would make a cool picture with a sunset or mountains in the background....before you wash it. :thumbsup:
    GODZILLA and jewsNbrews like this.
  13. Apr 4, 2020 at 7:39 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Cleaned up the battery.
    Fotnot, Ostrich, NAFlash and 5 others like this.
  14. Apr 4, 2020 at 7:51 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I social distanced
  15. Apr 4, 2020 at 7:51 PM
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    285’s or 295’s?
  16. Apr 4, 2020 at 7:54 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    DoctorBAH[QUOTED] likes this.
  17. Apr 4, 2020 at 7:56 PM
    :wave:
    Samoan Thor[QUOTED] likes this.
  18. Apr 4, 2020 at 8:04 PM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    285/70-18
    Ron_Pro[QUOTED] likes this.
  19. Apr 4, 2020 at 8:09 PM
    DoctorBAH
    DoctorBAH New Member
    Big D
    2017 Tundra Limited 4x4 - black
    - Billstein 5100 Ride-Height Adjustable front shocks, set to ‘level’ the truck (raised the front approx. 2-inches). - K&N Cold Air Intake (#77-9036KP) - Bakflip G2 tri-fold hard tonneau. - Flowmaster, Series 44, 2-in/2-out. - Slightly bigger 275-60/20 Firestone Destination All-Terrain (33-inch). - Husky X-Act Contour Floor Liners. - GTR Lighting Gen 3 LED Ultra Series headlight bulbs. - GTR Lighting switchback LED bulbs for DRL, Blinkers and Parking lights. - Philips X-tremeVision LED Fog Lights - Vehicle OCD™ (Organized Console Device) ($25 Amazon, awesome). - The Stubby radio antenna. - Philips Bright White Vision LED Back-up Light (921/T16) (12789LPB2) for rear high mount cab lights (awesome). - SYLVANIA 168 T10 5W White LED Bulbs for tag/license plate lights. - Carbon Fiber Door Sill Protectors. - TRDbeast door handle decals and center console emblem. - Tailgate letter inserts, carbon fiber. - Blacked-out chrome “TUNDRA” on front doors. - Tow Hooks painted red (+5 hp).
    what did you pour onto the metal connections? Looks like syrup. Obviously something to prevent corrosion or buildup.
  20. Apr 4, 2020 at 9:23 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Here is all the upgrades from last year including the first one from today.
    1. padded arm rest with real leather cover was Today
    • LED bed light wired floor lights from VLEDs
    • Steering wheel leather cover
    • Android Stereo with front camera, GPS camera, 2nd touch screen and volume knob. Also my own choice of BT microphone
    • Sound Proof the crap out of all the doors and walls
    • LED Headlights and front Steel bumper by Rough Country
    • Roof lights LED solar
    • Alpine amp
    • Interior Lights by VLED front and rear mirrors and interior ceiling lights
    • Shift Knob Ebay leather very nice.
    • Pro Comp Wheels with OEM tires
    • OEM Towing Mirrors
    • Snug Top Rebel Camper Shell and Fender Flares unpainted.
    • Door speakers and dash speakers upgraded
  21. Apr 4, 2020 at 9:41 PM
    I dig those mats, and really like rear coverage. Can you recommend a good place to get some?
    SiberianTundra likes this.
  22. Apr 4, 2020 at 9:43 PM
    Sleeper16plat
    Near Vancouver
    battery corrosion preventative
    goes on like spray paint, I taped the area around the terminals before spraying
  23. Apr 5, 2020 at 12:38 AM
    TundraJake
    TundraJake New Member
    Jake
    2016 Tundra TRD Pro MGM
    The girlfriend and I got out to the river to do something she’s been wanting to do for awhile, tie dye.
    TUNDRA375, ElNopal, equin and 7 others like this.
  24. Apr 5, 2020 at 5:26 AM
    Cthulhu
    Dang @SiberianTundra you've been busy...looks righteous!!
  25. Apr 5, 2020 at 6:40 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    From a distance it looks like the wood paneling they used to put on station wagons!
  26. Apr 5, 2020 at 8:14 AM
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    nothing too exciting, added 10-15 horse power with the toyota vintage stickers on the grill, and got a little dirt on the tires at my buddies land.
  27. Apr 5, 2020 at 8:20 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks! I didn't get the third cup holder option just the two and I believe another member said he just ran them to the power in the center console if im not mistaken
    rebmo[QUOTED] likes this.
  28. Apr 5, 2020 at 8:25 AM
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Looks awesome, where did you get those items?
  29. Apr 5, 2020 at 8:29 AM
    Blue Thunder
    Washington
    Wait...I see you still have the stock front and rear mud flaps. I thought 275s were the widest you could run on stock rims w/o any rubbing issues. Have you had to do any trimming or had any rubbing issues?
  30. Apr 5, 2020 at 8:33 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
