Front alignment
Discussion in 'Suspension' started by jrod, Jan 22, 2017.
  1. Jan 22, 2017 at 6:09 PM
    jrod
    jrod [OP] New Member
    2007 limited crewmax
    Hi,I recently purchased an 07 Tundra,just got it lift 2 1/2 in front and 1" rear ,20"x12.5 rims on 33 tires and I just notice my front pass side tire sticks out a good inch more than the driver side. Went for a wheel alignment and there's no issues. I wonder if anyone here has had this issue before? Thanks
  2. Jan 23, 2017 at 7:00 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Ya'll think that could be coming from the driver side lean on our trucks making it look like the passenger side is further out? Or is that just an issue on the Gen 3?
    jrod[OP] likes this.
  3. Jan 23, 2017 at 9:15 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Previous wreck? I had an issue with a previous car, shop tried to give it back to me with the rear wheel sticking past the fender 1/4" or so, said they couldn't find anything wrong with it. Ended up being a cracked hub housing.
  4. Jan 23, 2017 at 10:51 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I think I've read about the rear axle being off-centered sometimes which would cause the wheels sticking out further on one side...but I don't recall reading about the front axle being that way.
    jrod[OP] and joonbug like this.
  5. Jan 23, 2017 at 6:14 PM
    jrod
  6. Jan 23, 2017 at 6:27 PM
    jrod
    At first I thought it was involved in a wreck but I put it up on my friends lift and we could not find any damage plus all the front body parts have matching vin #'s. and guys thanks for the advices this is my first Tundra and I'm new on this forum has well
  7. Jan 23, 2017 at 6:50 PM
    Welcome from CO jrod. I have an 07 with zero issues as far as what you are describing. Can't think of any reason why you would have a 1" offset unless something isn't quite kosher.
    Source??? I haven't heard of this.
  8. Jan 23, 2017 at 6:51 PM
    Zharris
    Zharris Merica!
    I know the rear axle is longer than the front. Never heard about it being off center.
  9. Jan 23, 2017 at 7:02 PM
    Longer????
  10. Jan 23, 2017 at 7:06 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas!! Hope you get everything you want from this site!! It has a lot to offer.
  11. Jan 23, 2017 at 7:07 PM
    Zharris
    Zharris Merica!
    Yeah. Found that out when I put those spacers on my truck. Just looking at them the rear axle is probably about 2-3 inches longer than the front axle. They used to do it to help with tracking on the 4x4 trucks. I'm assuming it's done for the same reason by Toyota. Every other manufacturer makes the front axle longer than the rear though as far as I know. I know Chevrolet and ford has longer front than rear axles. But it's only by a few inches.
  12. Jan 23, 2017 at 7:43 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Nowhere official, that's the problem, I've yet to find an answer. But just about every single Toyota forum has threads about it. Google it, you'd be surprised, and it's been talked about for many years. I just chalk it up to one of those quirks without an answer, just like the Tundra lean
  13. Jan 23, 2017 at 7:46 PM
    Climate change is not official either but, and lots of threads about it too. I've yet to find the answer. (No junk science)
    rons23 likes this.
  14. Jan 26, 2017 at 5:31 PM
    jrod
    I did read about it too,that's how I found this forum
