Trailer electronic brake control.
Discussion in '2nd Gen Tundras (2007-2013)' started by NitroX, Mar 28, 2020.
  1. Mar 28, 2020 at 10:39 AM
    NitroX
    NitroX [OP] New Member
    Stu
    2013 Tundra extended cab
    I have a 2013 Tundra and while testing the EBC forum that there is no power at the black wire plug over the L kick panel. The one that plugs into the "plug n play harness for the controller.
    Before I start adding wiring to feed the controller I'd like to know if there a fuse missing or do I need to cut and splice in a 20a C/B
  2. Mar 29, 2020 at 8:12 AM
    NitroX
    Stu
    Never mind... I found the problem!
    ColoradoTJ likes this.
  3. Mar 29, 2020 at 9:55 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Blown Fuse?
  4. Mar 30, 2020 at 5:37 AM
    NitroX
    Stu
    That's what I kept telling myself... check the basics. There has to be a fuse or a CB. I looked and looked for a wiring diagram, but everything kept showing the diagram I already had... the brake assist pigtail. I checked another Tundra site and found what I was looking for the schematic for the pigtail at the kick panel. There are a number of fuses in this panel that show TOW and I visually checked them all... keyword visually. The fuse wasn't blown, but it had zero continuity. Found at last and all works as designed.
    All was not lost, however, I also found a great hack to move my trailer wiring plug from under my bumper to next to the license plate. :cheers:
  5. Mar 30, 2020 at 6:57 AM
    mrmachinist
    mrmachinist New Member
    Louisiana
    2013 Tundra Crewmax 4x4
    6112/5100 shocks, 1” lift shackles, Tuff Country UCA, B&W gooseneck hitch, firestone airbags w/ daystar cradles, RB-10 running boards, front receiver hitch, winch wiring front and rear.
    Glad you gout it fixed. I moved my plug a while back and it’s a much better location.
  6. Mar 30, 2020 at 7:42 AM
    NitroX
    Stu
    I agree. Some of the ramps around here make it impossible to dunk my boat without submerging the plug in saltwater... not good.
  7. Mar 30, 2020 at 8:31 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    got a photo of said new location?
  8. Mar 31, 2020 at 4:36 AM
    NitroX
    Stu
    The directions are somewhere in this thread but this was my picture.
    You can probably search it
    TunaDr and Failure2comply like this.
  9. Mar 31, 2020 at 11:24 AM
    FWD Tundra
    Washington
    Yes sometimes fuses look good until you use a VOM on them to get the true story. When ever I have a fuse issue I take out the VOM. It may have developed a crack from corrosion.
