08 tundra starts then dies immediately
Discussion in '2nd Gen Tundras (2007-2013)' started by Colton, Mar 22, 2020.
  1. Mar 22, 2020 at 1:05 PM
    Colton
    Colton [OP] New Member
    Colton
    08 tundra starts then dies. Happened about five times in the last month . The first time I added gas because it was low that worked. The last few time if I keep the peddal matted when I start it it will eventually turn over. I though fuel pump but I went to the parts store and it came back unserviceable. I'm guessing it's in the tank. Any help would be greatly appreciated thanks
  2. Mar 22, 2020 at 1:09 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    When it happens try hitting the bottom of the tank with a rubber mallet, then try to start, if it starts then it’s possible the fuel pump is dying a slow death . Don’t hit it vey hard just enough to shock the pump a little .
    Rica25 and Colton[OP] like this.
  3. Mar 22, 2020 at 1:13 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Hook a fuel pressure gauge up to the test port in the engine compartment to see if you have fuel pressure ??
  4. Mar 22, 2020 at 1:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The fuel pump computer on the drive side frame rail behind the tank is known to go bad and cause this too.
  5. Mar 29, 2020 at 1:16 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Where's your fuel gauge??? I ask this because my '07's gauge is off by a 1/4 tank, which means I run out of gas at that point, or the 58 miles remaining marker.... you can try the starter relay fuse to make sure its good... Additional testing if you switch your key to on with the radio off, you should hear a sort of whine that would mean the pump is spraying.... You can confirm by removing an injector with a rag on it and ensuring its spraying....
    Rica25 and chugs like this.
  6. Mar 29, 2020 at 9:58 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    This has happened to me about 3 times. I thought it was a fuel system problem, but I tracked it down to an AC inverter I run in the truck. I sometimes let it run while the engine wasn't. Don t do that anymore. I run it only when engine is on now, and starting problem has nt happened since.
    Rica25 likes this.
  7. Mar 30, 2020 at 4:26 AM
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    I had a similar issue on my 07, long cranks, if it fired up it would choke & stumble. Cleaned MAF & Throttle Body.....GTG. I'd recommend that along with disconnecting the negative batt terminal & holding brake for 30 sec or so. Let us know what you find.
    Rica25 likes this.
  8. Mar 30, 2020 at 10:18 AM
    lonelydriver
    lonelydriver New Member
    have you done any work to the truck? check the intake / MAF
    Rica25 likes this.
  9. Mar 30, 2020 at 8:12 PM
    el_taco
    el_taco New Member
    Check MAF and clean it.
    Rica25 likes this.
  10. Mar 30, 2020 at 8:28 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Mashing the pedal on a fuel injected car while starting will turn off injectors car won’t start it’s a safety just like you cant redline in Park or Neutral that’s why you hear the fuel pump turn on for 2 seconds then off with the key on.
    definitely check MAF and TB for carbon build up use MAF safe cleaner if you have a scanner you can check IAT and see if it’s reading ambient temp if not that can be an issue as well. I worked on a Toyota that had a bad IAT sensor it had a hard start and wen finally was running I would get hard engagements and hard shifts IAT was reading -39 degrees on a 70 degree day good luck partner Keep posting we will figure out the problem
    baraynavab and Rica25 like this.
  11. Mar 30, 2020 at 9:16 PM
    Rica25
    Ricardo
    Tulare
    Mine did that for a while after adding an intake. The throttle body was getting to much gunk. Removed intake and put stock one back and cleaned throttle body and has been good since
    773_eddie likes this.
