14 tundra headlight problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by Striker, Mar 22, 2020.
  1. Mar 22, 2020 at 10:08 AM
    Striker
    Striker [OP] New Member
    Brandon
    14 tundra 1794
    Leveling kit, led lights and light bar
    Drivers side headlight, high and low beam won't work. Changed fuses and lights. I checked the relay as well. Turn signal and all other lights work perfect. What next????
  2. Mar 22, 2020 at 10:19 AM
    TXTundra2722
    2015 Black Tundra
    Have you tried putting a volt meter on the driver and passenger side and setting what you're getting?
  3. Mar 22, 2020 at 10:28 AM
    Striker
    Brandon
    14 tundra 1794
    Not yet but I will let you know when I do
  4. Mar 22, 2020 at 5:01 PM
    Striker
    Brandon
    14 tundra 1794
    I just did. I have 4.5 v from center pin but nothing from other 2. Also, the white epoxy in tundra wiring harness is not hard. It's almost a gel. I'm pretty sure that is not normal. I have 18 v in fuse
  5. Mar 22, 2020 at 6:01 PM
    TXTundra2722
    2015 Black Tundra
    Any mods or additions at all? Count nothing too small. Are you the original owner?
  6. Mar 22, 2020 at 6:04 PM
    Striker
    Brandon
    14 tundra 1794
    Yes. Original owner. I have a 3" leveling lift, had hids but drivers side went out. Had hids for almost 2 yrs. Figured it just burned out. Put plug and play LED LIGHTS in today and still didn't work. Checked everything and found epoxy turned to jelly on harness for some reason
  7. Mar 22, 2020 at 7:18 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Are you using a motocontrol?
  8. Mar 22, 2020 at 7:24 PM
    Buildn
    Medina, Ohio
    I had HID’s that used a motocontrol off the battery which caused the problems you are having with the HID’s and now the LED’s.
    I took out the motocontrol and bought a plug n play harness from @iHacker on here for my Toyota LED headlights. Problem solved.
  9. Mar 22, 2020 at 8:22 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I'm pretty sure that's dielectric grease, not epoxy that you are seeing.
    BlueRibbon4x4 likes this.
  10. Mar 22, 2020 at 10:25 PM
    TXTundra2722
    2015 Black Tundra
    I second the above comments
  11. Mar 23, 2020 at 3:00 AM
    Striker
    Brandon
    14 tundra 1794
    Thanks. I'll take out the hid control and try. I'll keep y'all updated
  12. Mar 28, 2020 at 6:38 PM
    Striker
    Brandon
    14 tundra 1794
    I took out the mono control and still led doesn't work on drivers side
  13. Mar 28, 2020 at 6:48 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Which headlights are you running
  14. Mar 28, 2020 at 6:48 PM
    Striker
    Brandon
    14 tundra 1794
    Plug and play
  15. Mar 28, 2020 at 6:49 PM
    xtyfighterx
    Ty
    North Idaho
    New headlights all together or just new bulbs in stock headlights
  16. Mar 30, 2020 at 5:13 PM
    Striker
    Brandon
    14 tundra 1794
    I had dealership test it. Turns out it was faulty LED. I already have a new one in thanks for your help
