Headlamp adjustment
Discussion in 'Lighting' started by Frankstb, Mar 28, 2020.
  1. Mar 28, 2020 at 8:27 AM
    Frankstb
    Frankstb [OP] New Member
    Frank
    2018 Silver Limited 4WD
    RC 1.75” leveling kit BFG K2s 275/60/20
    My right headlight on my 18 tundra seems to be pointed downward too much. Is there a way to adjust it? Thanks!
  2. Mar 28, 2020 at 8:34 AM
    There is a white plastic screw or nut, I'm sure someone else will chime in to verify this, that you can turn, but it can easily be messed up, so be careful
    15whtrd likes this.
  3. Mar 28, 2020 at 8:37 AM
    Frankstb
    Frank
    I have seen what ur talking about. Has a flat heat screw top on it? I assume turning right or left would lower/raise the light? I could not find anything about in the manual. Have u adjusted it before?
  4. Mar 28, 2020 at 8:39 AM
    I don't know what the procedure is whether left or right you're going to have to play with that, but yes, that is a screw to turn
    Frankstb[QUOTED][OP] likes this.
  5. Mar 28, 2020 at 8:49 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty sure it’s a Phillips head. I would Google how to properly adjust headlights. Usually you pull up a certain distance to a wall and mark the level of the beams with tape. There’s a specific way they should be adjusted. I adjusted mine when I lifted the truck. But they were correct from the start so I just moved both sides evenly.
  6. Mar 28, 2020 at 9:26 AM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Phillip's head, the slot and metal toothed adjusting wheel is finicky on what size Phillip's screwdriver can be used.
    Turning the screwdriver clockwise raises the headlight.
    15whtrd likes this.
  7. Mar 28, 2020 at 10:20 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I adjusted mine I have the auto level head light and the next day it was back to the same as before. Passanger headlight is about 1 or 2 lower then driver side.
  8. Mar 28, 2020 at 5:40 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    @Vince Did you set the dial to "0" before aiming?
    It shouldn't be out of adjustment, unless there is something else is causing the leveling motor to drop on the passenger side.
  9. Mar 28, 2020 at 6:08 PM
    Vince
    Vince New Member
    Vincent
    Yes the dial was on 0 adjusted it up and the next day it set itself back.
  10. Mar 28, 2020 at 6:11 PM
    BrandonL812
    Brandon
    That is very strange. Something weird is causing the leveling motor to reset itself and not hold where you set it.
  11. Mar 28, 2020 at 6:12 PM
    Vince
    Vince New Member
    Vincent
    Ya thought so too I kind of wondering if it's just a weaker headlamp beam to make it look lower
  12. Mar 28, 2020 at 8:22 PM
    BrandonL812
    Brandon
    You can unplug the harness to the leveling motor on the passenger side and see if the aim adjustment stay put. When you pull up to a wall, does both beam look similar? As far as light output i mean. Same beam pattern and hotspot..
  13. Mar 29, 2020 at 7:34 PM
    Vince
    Vince New Member
    Vincent
    No that's what makes me think it is the beam.
  14. Mar 29, 2020 at 7:36 PM
    BrandonL812
    Brandon
    Hard to really know unless you can find a spare headlight and swap it out to see.
