Suggestions on spacers
Discussion in 'Wheels & Tires' started by Balrz, Mar 26, 2020.
  1. Mar 26, 2020 at 7:10 AM
    Balrz
    Balrz [OP] New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    Guys I would like to add some spacers to my stock wheels just to give it that look where it’s sitting an inch outside the fender. Any suggestions? I do not want to lift or level it right now..
    Tundyfundy likes this.
  2. Mar 26, 2020 at 7:11 AM
  3. Mar 26, 2020 at 7:15 AM
    Balrz
    Ryu
    What size give me just an inch outside the fender? I got stock 18” trd off-road rims
  4. Mar 26, 2020 at 7:24 AM
    I think 1.25.
    Hopefully someone more knowledgeable will chim in.
  5. Mar 27, 2020 at 7:11 PM
    Lee4x2Tundra
    Lee4x2Tundra New Member
    Isaac
    2017 White Tundra TSS
    I’m getting ready to order these, from what I hear and read they will make them stick out pass the fenders about half an inch. Could be wrong tho.
  6. Mar 27, 2020 at 7:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Measure your tires to the fender' or where you want the tire to be. Order spacers accordingly. I wouldn't exceed 2" spacers.
    Also make sure you torque them per instructions.
    Tundyfundy and Lee4x2Tundra like this.
  7. Mar 27, 2020 at 7:54 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have BORA wheel spacers 1.25". I have the BFG KO2 33" tire which is one up size from stock. Pretty sure its the same width, and my tires are dead even with the sides.
    I would say if you want them to stick out around an inch go with 2". What you need is a "Hubcentric" spacer. As long as you get spacers from a reputable company like spider trax or BORA, and they are hubcentric you will be winning.
    EDIT: You will also need to install correctly and torque as well as retorque. Don't be cavalier. 2" spacer is probably max as mentioned above.
  8. Mar 28, 2020 at 2:39 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I ordered a set on 1.5” from www.wheeladapterusa.com
    I haven’t installed them yet but they are quality man! Hubcentric, grade 10 mugs pressed In and super fast shipping. min addition, made in the USA!
