  1. Mar 27, 2020 at 6:10 AM
    biebs96
    PA
    Added these...
    ...to the clamps on my tonneau cover.
    NOT for any type of load bearing usage, but mainly for a place to clip things or hang the grocery bag handles on.
    Had them sitting in the garage for months for another project that they were too big for.
  2. Mar 27, 2020 at 6:24 AM
    07tacoswb
    07tacoswb New Member
    2016 Super White Tundra Crewmax XSP-X
    Got my new wheels and tires. Hostile Alpha 20x10 -19 in Asphalt with 33x12.5r20 Nitto Ridgegrapplers.
  3. Mar 27, 2020 at 6:53 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I want to do a 6 inch lift so bad. Sick rig man
    Double Badass[QUOTED] likes this.
  4. Mar 27, 2020 at 7:14 AM
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    Brother I've been so happy with this lift and it looks and drives awesome!! It's a 7 inch coilover pro comp with amp steps, I put 0airbags in the rear for two reasons 1: the front coilovers make the front sit just a bit higher than the rear and it was driving me crazy. 2: when pulling my toy hauler or my jeep it would level the rear.
    Ted4311[QUOTED] likes this.
  5. Mar 27, 2020 at 7:24 AM
    Double Badass
    James
    Arizona
    Question does anyone have the stealth fighter winch bumper made by Addictive desert design? I've been really considering changing my stock bumper to it but not sure yet because I really do like the stock bumper. So my question is how do you like it?
    sd_cavbluetundra likes this.
  6. Mar 27, 2020 at 7:27 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes but I cut the nub off and worked just fine.
  7. Mar 27, 2020 at 7:28 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I like ADD but I'm not a fan of the super exposed front tire look.
  8. Mar 27, 2020 at 7:56 AM
    Stonehide
    Stonehide New Member
    2020 Cement DC Limited 4x4
    Nope! Just crawled under the truck and got her done. Would have been a lot less painful with a lift though.
  9. Mar 27, 2020 at 7:57 AM
    18" TRD Off Road Wheels
    If you don't have a lift you can just use a couple ramps to lift the passenger side of the truck. Gives you plenty of room to work. :thumbsup:
    Stonehide[QUOTED] likes this.
  10. Mar 27, 2020 at 7:58 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Yea they do. And about half the price of an ARB.
    AZTundra[QUOTED] likes this.
  11. Mar 27, 2020 at 8:08 AM
    Stonehide
    Oh, and I highly recommend wearing gloves. My knuckles got sliced up a bit wrenching around the heat shields over the exhaust. Edges on those things are reallll sharp.
    GODZILLA[QUOTED] likes this.
  12. Mar 27, 2020 at 8:11 AM
    But chicks dig scars....
    Gloves are definitely a good idea.:fistbump: I hit the bolts with PB Blaster the day before install, and then again first thing and let them sit while I installed my skids. The older your truck is, the more crucial this step is.
    ezdog and Stonehide[QUOTED] like this.
  13. Mar 27, 2020 at 9:49 AM
    Double Badass
    James
    Arizona
    A somewhat agree but it's great for approach angles if you use your truck offroad alot
    texasrho83[QUOTED] and GODZILLA like this.
  14. Mar 27, 2020 at 10:28 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Sweet, that's what I'll do.
  15. Mar 27, 2020 at 1:00 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Have had this rolling around my head a few weeks after installing the wireless charger. The switch is just a basic SPST rocker that I use in my day to day job and of course same with the wire and connectors. I will post pics but all you want to do is break a power wire, real straight forward. Please ask any questions other than what switch, that one the for a heat well at Taco Bell. Any SPST switch will work cause you don't have any amp load to worry about.
    FYI don't believe all the cop shows where they disarm the bomb cutting the correct color wire. Wires don't care what color they are!
    Redwinger, Fotnot, rockjockey and 9 others like this.
  16. Mar 27, 2020 at 1:08 PM
    So that's why I'm loved.:thumbsup:
  17. Mar 27, 2020 at 2:51 PM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    So I'm confused why you need the switch? Because it turns on every time when the truck is started?
  18. Mar 27, 2020 at 2:54 PM
    So you can turn it off. If you are going to put something else in that spot, or if the light is too bright at night (some have said this), but that's all I can think of.
    ElNopal likes this.
  19. Mar 27, 2020 at 3:23 PM
    biebs96
    PA
    GAknight, NAFlash, ElNopal and 4 others like this.
  20. Mar 27, 2020 at 3:24 PM
    TomC843
    Tom
    Charleston, SC
    Yes. I also knew I could do it for zero cost and I set stuff there without thinking and read it could damage a charger that cost $175.
    chinadog[QUOTED] likes this.
  21. Mar 27, 2020 at 3:35 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I added some OEM LED fog lights in black to match the headlights. Can't see them very well but they look great on or offIMG_7578.jpg .
    Fotnot, NAFlash, Ostrich and 8 others like this.
  22. Mar 27, 2020 at 4:05 PM
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    I installed the rear sway bar today. The truck drives nice with both the front and back installed. Very easy installation.20200327_161757.jpg
    Watson, khunk, GAknight and 13 others like this.
  23. Mar 27, 2020 at 4:34 PM
    rdrasher
    rdrasher New Member
    2020 sr5 dbl cab
    I just push the little charging button in the middle once to turn it off and then once again to turn it back on(while the truck is running).
  24. Mar 27, 2020 at 4:35 PM
    I'm low tech and don't have one, so it's all speculation on my part. :p
  25. Mar 27, 2020 at 4:39 PM
    rdrasher
    rdrasher New Member
    2020 sr5 dbl cab
    Isn't that whats below the "R" of the TRD logo? Mine looks exactly the same as yours and is a button for on/off.
  26. Mar 27, 2020 at 4:41 PM
    Sorry, I wasn't clear. I don't have a charger.
  27. Mar 27, 2020 at 4:47 PM
    rdrasher
    rdrasher New Member
    2020 sr5 dbl cab
    My bad. I didn't realize I misread the quote thread. :confused:
  28. Mar 27, 2020 at 5:45 PM
    AKLA98
    AKLA98 New Member
    Liam
    Anchorage, AK / Boulder, CO
    2019 MGM TRDOR Double Cab
    TRD PRO Grille, Colormatched Mirror Caps, Rear Bumper Caps, Husky X-Act Floor Mats, 20% VLT Front Tint, BAJA Designs Squadron Sport Fog Lights, LockerDown Console Vault
    Upgraded the interior incandescent lights to LED’s. Purchased individually through superbrightleds for a better deal than prepackaged kits.
    Fotnot, GAknight, NAFlash and 8 others like this.
  29. Mar 27, 2020 at 5:46 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Finished up the installation of the Yeti battery pack to power my fridge. Pretty much just stuck it into a clear plastic container with secure lid and found one big enough that all the extra power adapters, cables and small solar panel can fit in there as well. Nice part is if I need to move the fridge out of the truck I can pull this out at the same time while keeping everything powered on and then transport them together.
    Also worked out well since it fits right behind the fridge and if I slide the fridge forward I can see the LCD display on the Yeti :)
    twistedcricket, jpod, Fotnot and 9 others like this.
  30. Mar 27, 2020 at 6:21 PM
    AZTundra
    Paul
    Phoenix, AZ
    Hoping to find time this weekend to install mine as well.
