Wheel Spacers - Pro/Con
Discussion in 'Wheels & Tires' started by wingnutted, Mar 3, 2020.
  1. Mar 3, 2020 at 6:38 PM
    wingnutted
    wingnutted [OP] New Member
    Seattle
    2006 Black Tundra TRD Double Cab
    Any one out there running wheel spacers to adjust for offset? Any significant problems that you've had when using?
  2. Mar 3, 2020 at 6:45 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    I'm running spider trax 1.25" wheel spacers with stock trd off-road wheels. Had them on for about 5k miles, and zero negative effects. Just make sure to use some blue loc tite and torque them, I torqued mine to 110 ft/lbs. Rechecked after 1k miles and they were all still torqued to original.
    AZTundra likes this.
  3. Mar 3, 2020 at 8:13 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    I have them on my truck for about 2 yrs now, no issues at all. Just get a good quality wheel spacer and you'll be fine.
  4. Mar 3, 2020 at 8:24 PM
    Sunnier
    Sunny
    San Diego, CA
    I’m using BORA. Everything I’ve read says you’re best to stick with BORA or Spidertrax.
  5. Mar 3, 2020 at 8:55 PM
    TXTundra2722
    2015 Black Tundra
    True... another quality part that you don't want to cheap out on..... or you might be driving one day and find yourself racing your wheel and tire:mudding:
    wingnutted[OP] likes this.
  6. Mar 3, 2020 at 8:57 PM
    wingnutted
    Seattle
    Yeah, ordered 1.25" Spidertrax, I guess we'll see
    Tundyfundy and easleycrawler like this.
  7. Mar 26, 2020 at 5:30 PM
    AZTundra
    Paul
    Phoenix, AZ
    Got any pictures down the side of the truck showing how much the tires stick out? I'm debating adding some spider trax spacers 1.25" to push the stock trd wheel out just a tad to clear the new upper control arms that were installed. I'm getting a minor rub at full lock. This is a cheaper solution right now compared to new rims.
  8. Mar 26, 2020 at 5:49 PM
    easleycrawler
    Travis
    This is the only pic I have, I'll get a pic of exactly what you're looking for tomorrow. You have to think about the tire size as well, mine are stock size, 275/65, with a wider tire, it will stick out a little more.
  9. Mar 26, 2020 at 5:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the pic! That helps. I'm running 295/70/18 Cooper's. :thumbsup:
    easleycrawler[QUOTED] likes this.
  10. Mar 27, 2020 at 6:30 AM
    easleycrawler
    Travis
    Here you go.
    AZTundra[QUOTED] likes this.
  11. Mar 27, 2020 at 8:23 AM
    AZTundra
    Paul
    Phoenix, AZ
    Nice. That looks perfect to me. Last question, are you running them on the rear also or just the front? Do you think it would be noticeable or look weird if only running on the front? My shop just recommended doing the front only to clear the UCA's and leave the rear alone.
  12. Mar 27, 2020 at 8:29 AM
    easleycrawler
    Travis
    Yes, I'm running them front and rear. If I were you, I'd definitely run them front and rear, just to make everything look even. Just running them on the front, would look like the Chevy hd trucks look sometimes, if you ever noticed, the front ends are wider on the hd gm trucks, it's really noticable with aftermarket wheels, it just doesn't look right to me.
  13. Mar 27, 2020 at 8:30 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Plenty of folks run them without issue but I never would consider them. Risky in my opinion.
    Have seem them fail on hotrods and imports...but that was many years ago. Perhaps they are made better now.
  14. Mar 27, 2020 at 8:34 AM
    easleycrawler
    Travis
    Rear view.
  15. Mar 27, 2020 at 8:38 AM
    easleycrawler
    Travis
    This is why you spend a little more and get a quality product, spider tracks or Bora, they are hub centric for our trucks. Also, back in the day, wheel spacers was an actual spacer, once put on, the lugs get shorter, hence the problem with the breaking/falling off, not enough threads left for the lug nut.
    If you really think about it, what we are running, could be called and adapter, since it doesn't make the lugs shorter and it gives us five new lugs that the wheels bolt to.
    TXTundra2722 and AZTundra like this.
  16. Mar 27, 2020 at 8:50 AM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. I've seen several trucks around here like you described and that's what I was trying to avoid. I'll just go with front/rear then assuming it fixes the rubbing issue on the front end after they are test fitted. Thanks again @easleycrawler .
  17. Mar 27, 2020 at 8:50 AM
    TXTundra2722
    2015 Black Tundra
    True, I haven't heard any stories about these name brands failing like you heard 20+ years ago
    easleycrawler likes this.
  18. Mar 27, 2020 at 8:56 AM
    easleycrawler
    Travis
    No problem. It's gonna cost a little more for all 4, but the end result, you will be happy and not have to order and wait on shipping twice.
