Wasp
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_1, Mar 25, 2020.
  1. Mar 25, 2020 at 11:13 AM
    1kTyy_1
    1kTyy_1 [OP] New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    I believe there is a wasp nest behind my mirrors on my '01 tundta. How should I go about removing all wasp and protecting my truck from future wasp?
  2. Mar 25, 2020 at 11:18 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    They have a tendency to come back even after you kill them off. I had that issue with an old truck I have. I would spray the infested areas with a foam type wasp spray. It took a good soaking to get rid of them for a longer period of time.
  3. Mar 25, 2020 at 11:28 AM
    MS22
    MS22 New Member
    02 Tundra 4x4
    WD40 works very good.
  4. Mar 25, 2020 at 12:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No no no. He has an ‘01 not an ‘02 +. Use a wasp spray. Then once they are dead pop the mirror off and clean it out. Simple
    Are you allergic?
    TX-TRD1stGEN likes this.
  5. Mar 25, 2020 at 1:01 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    This is what I had in my 94 F150. I drove it to another part of my property and wondered why I had wasps buzzing in the cab. I opened the passenger door and found that. There was another big nest at the leading edge of the door by the fender. Wasps also like the post holes in the tops of the bed. I'd think I'd got them but then there would be more coming from somewhere else.
  6. Mar 25, 2020 at 6:29 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The extermination kit is a two part affair.
    First you need a Japanese giant hornet.
    Then, you need a hive of Japanese honey bees, to get rid of the Japanese giant hornet.
    Rex Kramer, SC T100, bleach and 4 others like this.
  7. Mar 25, 2020 at 7:06 PM
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    Spray the nest with a wasp spray in the late evening to ensure all the wasps are there.
    NewImprovedRon likes this.
  8. Mar 25, 2020 at 7:30 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    FirstGenVol, SC T100, bleach and 4 others like this.
  9. Mar 25, 2020 at 7:34 PM
    artsr2002 and Y0TA PR0[QUOTED] like this.
  10. Mar 26, 2020 at 4:57 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Put some plastic grocery bags over the mirrors when not using. That’ll restrict them. I have to do that every spring since male robins pick a fight with the one in the mirror and crap all over the door. Pests!
    CodyP and NewImprovedRon like this.
  11. Mar 26, 2020 at 7:12 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    This guy was just trolling us right?
  12. Mar 26, 2020 at 9:13 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    TXRailRoadBandit73 likes this.
