Tires rubbing
Discussion in 'General Tundra Discussion' started by Bc1984, Mar 25, 2020.
  1. Mar 25, 2020 at 3:35 PM
    Bc1984
    Bc1984 [OP] New Member
    Justin
    2016 tundra pmts
    So what are you guys doing that are running 35s with a 6 inch lift about tires rubbing.
  2. Mar 25, 2020 at 3:42 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Be a bit more specific like where. But probably remove mud flaps, do a body mount chop, bumper spacer, trim and/or mold plastic with a knife and/or heat gun.....or buy smaller tires. lol
  3. Mar 25, 2020 at 3:45 PM
    Bc1984
    Justin
    2016 tundra pmts
    Lol know mud flaps are gone already ther hitting the plastic cover thought about trying to do the heat gun method
  4. Mar 25, 2020 at 3:48 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If it's the plastics behind the bumper, you can either get the shim kit from @Coachbuilder1 or redrill the bolt holes for the plastic and push that forward about .5 to .75 inch.
  5. Mar 25, 2020 at 3:50 PM
    Bc1984
    Justin
    2016 tundra pmts
    Ok nice was trying to avoid taking it out completely so I’ll have to try that
  6. Mar 25, 2020 at 4:13 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  7. Mar 25, 2020 at 4:24 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Dremeled mine now I have access to the fog lights easier to. I would of tried the heat gun if I knew about it 5 years ago
  8. Mar 25, 2020 at 4:26 PM
    Bc1984
    Justin
    2016 tundra pmts
    Nice gonna try that if the heat gun doesn’t work but all in all I’ve only had the lift on for about 3 hours lol
  9. Mar 25, 2020 at 4:28 PM
    07KingTundra
    07KingTundra New Member
    Scott
    07 Tundra Limited
    King, Icon, General
    you must have some weird offset wheels if your tires are rubbing with 35'' tires on a 6'' lift. I have maybe 2.5" lift and my 35's don't even come close to rubbing. I just had to remove the mud flaps and move the front fender liner forward like discussed above.
  10. Mar 25, 2020 at 4:31 PM
    Bc1984
    Justin
    2016 tundra pmts
    doesnt do it all the time but I think I’ll be fine when I move the liner forward some
  11. Mar 25, 2020 at 6:25 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Yea...I have to finish up trimming to fit mine, but I have a lil bigger than 35s, almost 13 wide, and -19 offset. Offset is what did me in the most
  12. Mar 25, 2020 at 6:26 PM
    Bc1984
    Justin
    2016 tundra pmts
    Not sure what my offset is but definitely gonna work on it tomorrow and get her dialed in
    Fotnot likes this.
