Toytec HIDs in Spyder Lights - Help needed
Discussion in 'Lighting' started by Bogardian, Oct 27, 2017.
  1. Oct 27, 2017 at 4:21 PM
    Bogardian
    Bogardian [OP] New Member
    Blake
    2017 SR5 CrewMax
    Tundra Team,
    I installed Spyder Lights to my 17 Tundra a few weeks ago, and decided to purchase the ToyTec 35w HID kit. I see that it is plug and play, but for semantics did not receive any instructions nor can I find anything in the forums around installation. Some places are indicating that I have to cut the rubber gromit where the lowbeam is located. When it comes to wiring and harnesses my skill set is very rudimentary.
    Someone who has this conversion, can you please advise if its going to require any unforeseeable steps? Currently there is a plug with grease on it(lowbeam looks like electrical prongs), but I do not see how that ties into the HID conversion kit. Before taking the front off again, I wanted to see if you could provide any tips, tricks, and recommendations.
    Thanks! :help:
  2. Oct 27, 2017 at 5:13 PM
    Bogardian[OP] likes this.
  3. Oct 29, 2017 at 10:22 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Everything is plug and play. You will have to cut the gasket on the back of the headlight in order to get the HID plug through. I put a couple of dabs of silicone around mine once it was all connected and working.
  4. Nov 2, 2017 at 6:38 AM
    Bogardian
    Blake
    2017 SR5 CrewMax
    Thanks bud, I will get around to it soon. I may order the hood and bulge first, so I don't have to keep taking the front off LOL.
  5. Nov 2, 2017 at 7:44 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I don't remember cutting anything but if sean (the god of omniscience) says it's so, then it must be.....though it would be a simple move to capture the output it provides
    smslavin[QUOTED] likes this.
  6. Nov 2, 2017 at 7:46 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Taking the grill off only takes 30 seconds but make sure you're gentle on the tabs. I've already broken one, though it's not necessary anyway
  7. Nov 2, 2017 at 8:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    has anyone taken before/after of the spyders stock and with hid's?
  8. Nov 2, 2017 at 8:23 AM
    Eclipsed & Floating
    Voluptuous Whitey
    No
    We made the transition immediately when we saw the stock SPYDER was no better than ONE. Just trust us on this one
  9. Mar 25, 2020 at 12:48 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Probably a dumb question, but I see on the ToyTec website it states you may need two kits, one for high beams, one for low beams. I have Spyders. I don't recall two sets of bulbs - am I crazy?
