Check Engine limp mode everytime I start truck.
Discussion in 'General Tundra Discussion' started by SalsaTheTundra, Mar 23, 2020.
  1. Mar 23, 2020 at 10:03 PM
    SalsaTheTundra
    SalsaTheTundra [OP] New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    So truck was wrecked. Parked for a year and a half. I fixed wrecked parts and started driving. It drove fine first day, then next day and ever since, about 1 month it has put itself it limp mode everytime i get in to the truck. I have a computer to read and erase so i normally just erase it. It’s the one about the secondary aif pump stuck off and closed. Any one else have these issues.
    Fun Fact: Resetting the light after oil change can be quite difficult.
  2. Mar 23, 2020 at 10:45 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    If it’s a Hard code you need to check that circuit if it was parked for a long time rodents could had ate the wires so just follow that trouble code
    SalsaTheTundra[OP] likes this.
  3. Mar 23, 2020 at 10:46 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    okay. Will look into it and let y’all know.
  4. Mar 23, 2020 at 10:48 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Good if you need help with any trouble codes or wiring diagram let me know and I will send you info
  5. Mar 24, 2020 at 1:14 AM
    koditten
    Kirk
    Midland of the Mitten
    Why not install an AIP bypass? If you can rebuild a vehicle, I'd think you could handle the simple wiring required to make your own bypass system.
    I've had mine on for 7 years and it works fine.
  6. Mar 24, 2020 at 3:11 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    What codes are you pulling? I'm pulling P-2440 , which is bank 1 stuck open. I had my AIP'S replaced @ 62k. Coincidentally I'm going through it again @ 124k. In the beginning it would go into limp mode and I would disconnect the negative terminal, and it would go away for a good while. Now it's coming on after every start, no matter if I disconnected terminal or erased the code. The air pressure sensor is more than likely bad on bank 1, and that's why the code keeps coming back. At least that's what Hewitt Technologies is saying. Anyway I ordered Gen2 Bypass kit plus pressure sensor adapter and will install them when I travel back home from Charleston. If you do order kit get the updated Gen 2,
    NewImprovedRon likes this.
  7. Mar 24, 2020 at 3:32 AM
    timsp8
    NY
    I think you gave yourself the answer. Replace the aip or do the bypass.
    koditten likes this.
