TOYOTA STEERING WHEEL EMBLEM - BLACKOUT
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by GREENwithENVY, Mar 23, 2020.
  1. Mar 23, 2020 at 3:35 PM
    GREENwithENVY
    GREENwithENVY [OP] New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I thought I'd pass this one around - as many of you, I've been working on the interior blackout of my 2020 Tundra TRD Pro (especially the steering wheel). I wasn't a fan of dipping, painting, or wrapping (because I figured I'd jack it up). But, I found an eBay seller (link below) and took a chance the seller's product would be a good fit for the shiny-ass Toyota emblem on the airbag cover.
    I ordered on 07-MAR and received today (23-MAR) - shipped from Thailand. And, the finished product looks good. I'll post some more pictures when I get it installed.
    https://www.ebay.com/itm/MATT-BLACK...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
  2. Mar 23, 2020 at 3:41 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
  3. Mar 23, 2020 at 4:02 PM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Man I like the look of that. But I could never replace that one. I would constantly be worried if it met the same design features that Toyota had in mind, when that air bag goes off. Will it respond the same way, will I be eating it. Just too high risk for me.
    Looking forward to seeing it installed!!
  4. Mar 28, 2020 at 11:30 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Working on the steering wheel blackout this weekend - hit a snag, the metal airbag assembly has four rivets securing it to the plastic airbag cover which would have to be drilled out. I pulled the plug on the emblem change out because I am NOT drilling out rivets and replacing them with a different fastener. I'll come up with something else.
    On another subject, the steering wheel controls were pulled and disassembled. I decided to paint them after my second attempt at wrapping (I don't know if I suck at it or not patient enough), but I believe the painting looks good. I used Rustoleum Acrylic Enamel 2X Flat Black with a Clear Matte topcoat (see picture).
    The two pictures with the wheel in the background were after 4 coats of paint and the remaining 4 pictures were after 3 coats of topcoat. Not bad for a windy day.
    JoshuaA, Upgrayedd, Ostrich and 6 others like this.
  5. Mar 28, 2020 at 12:20 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  6. Mar 28, 2020 at 12:35 PM
    solidsnake
    solidsnake New Member
    Colorado Springs
    2017 Lexus RX 350
    Y0TA PR0 and Voyagermike like this.
  7. Mar 28, 2020 at 1:03 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Yep, I've seen that post (which made me think I could remove the Tundra's) - however, there are some steel clamps and 4 rivets which I didn't want to disturb, so I took a zero for the day.
  8. Mar 28, 2020 at 1:11 PM
    solidsnake
    Colorado Springs
    2017 Lexus RX 350
    Well that sucks.
  9. Mar 28, 2020 at 1:20 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    Scott I have a 2020 Pro and changed my Steering Wheel emblem without drilling out any rivets and I took the whole Airbag apart.
    BIGWYTE1794, Ely010606 and Flyinryank like this.
  10. Mar 28, 2020 at 3:03 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Okay, I'll bite...what am I missing?
  11. Mar 28, 2020 at 3:11 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Where did you get the steering wheel from, have a link?
  12. Mar 28, 2020 at 3:22 PM
    No Limit
    No Limit New Member
    Alberta
    I’m not sure what your missing. I found it not too difficult to remove it all.
    I’ll take a look for the thread that shows the DYI with pictures. The link for where I got the emblem is in there too.
  13. Mar 28, 2020 at 3:28 PM
    No Limit
    No Limit New Member
    Alberta
  14. Mar 28, 2020 at 3:44 PM
    No Limit
    No Limit New Member
    Alberta
  15. Mar 28, 2020 at 3:46 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
  16. Apr 1, 2020 at 2:06 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Here's the painted steering panel control plastic pieces. Word of advice - let the paint and topcoat dry well because the paint will blemish no matter how gentle handled, rags used as cushion between piece and steering wheel, etc. (I learned the hard way...had to remove and repaint one of them). So, I allowed the full 48 hours to dry. Hope it holds up.
  17. Apr 2, 2020 at 11:32 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    I just ordered mine
  18. Apr 2, 2020 at 11:58 AM
    Bigolbaddy
    Bigolbaddy New Member
    Ben
    Fort Worth
    2020 MGM 1794
    Those look fantastic. Wow, got me thinking now.
  19. Apr 2, 2020 at 12:11 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Damn that looks good to me, nicely done
  20. Apr 11, 2020 at 10:55 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Well, sunk a few dollars on JimmyRigged's black overlay - it is a perfect fit and tight. Changes the entire look of the wheel.
    TUNDRA375, JoshuaA, Ostrich and 9 others like this.
  21. Apr 11, 2020 at 10:58 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
  22. Apr 11, 2020 at 11:34 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Nice! Looks good!
  23. Apr 11, 2020 at 12:54 PM
    SinlesscityIzaak
    SinlesscityIzaak New Member
    2017 TRD PRO
    Gas and driver
    Looks sweet
  24. Apr 11, 2020 at 12:58 PM
    SinlesscityIzaak
    2017 TRD PRO
    Gas and driver
  25. Apr 11, 2020 at 12:58 PM
    SinlesscityIzaak
    2017 TRD PRO
    Gas and driver
    I can’t wait to see what it’s gonna look like
  26. Apr 12, 2020 at 9:51 AM
    owb2gp
    owb2gp New Member
    ID
    Hopefully AJT Design will make an overlay.
  27. Apr 12, 2020 at 11:45 AM
    owb2gp
    owb2gp New Member
    ID
    I emailed AJT and they said they will be making an overlay for the chrome Toyota logo on the steering wheel within 1-2 months.
    :spending:
    Alexstundra, Ely010606 and Flyinryank like this.
  28. Apr 12, 2020 at 12:27 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I was going to plasti dip the emblem last week but taping off steering wheel and putting up a back drop would of took forever IMO. I used MGM touch up paint. Turned out good.
  29. Apr 22, 2020 at 2:08 PM
    owb2gp
    owb2gp New Member
    ID
  30. Apr 22, 2020 at 2:10 PM
