LED Bulbs Blink at Rapid Rate
Discussion in 'General Tundra Discussion' started by weelittleman, Mar 4, 2020.
  1. Mar 4, 2020 at 8:33 AM
    weelittleman
    weelittleman [OP] New Member
    2014 Cobalt Blue Tundra TSS
    Sooooooo, on my 2014 TSS, my rear right blinker bulb went out. I took the opportunity to upgrade to LED. Now, both driver and passenger side blink like they are on speed. Usually, this is the indication that one is out. All of them come on - front and back, driver side and passenger side.
    Any idea of why they would blink so fast?
    Thanks
  2. Mar 4, 2020 at 8:38 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You need to add inline resistors for led blinkers. Leds do not pull enough power so the ecu still thinks the bulb is out. The resistors add resistance back into the circuit to trick the ecu.
  3. Mar 4, 2020 at 8:41 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
  4. Mar 4, 2020 at 8:42 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The Hyper-flash. Yes, resistor needed for blinkers, some better LEDs have them integrated into them. They are also s bit more pricey.
    weelittleman[OP] likes this.
  5. Mar 4, 2020 at 8:54 AM
    weelittleman
  6. Mar 4, 2020 at 9:17 AM
    weelittleman
    So, I am looking to change out my headlights with LED. Will I need resistors for those as well?
    Thanks
  7. Mar 4, 2020 at 9:29 AM
    Danman34
    Danman34 New Member
    Danny
    Headlights? No. Only needed for blinkers. Headlights are a simple off/on through monetary switch.
  8. Mar 4, 2020 at 10:00 AM
    weelittleman
    Thanks!!!
  9. Mar 4, 2020 at 10:20 AM
    Trooper2
    JR
    Many argue that LEDs in stock housing is not a good idea. They are not designed for them, the light does not reflect well, blinding oncoming traffic.
  10. Mar 4, 2020 at 10:35 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    Careful mentioning that around here. The headlight hallway monitors will come out in force.:evil:
  11. Mar 4, 2020 at 10:50 AM
    weelittleman
    Due to my ignorance, how are these different from the HID bulbs that come in most newer vehicles these days. Just simply trying to get educated.
    Thanks
  12. Mar 4, 2020 at 11:27 AM
    Trooper2
    JR
    Not an expert but would think those housings are designed for the HIDs. The Tundras are not, LEDs anyway.
    I really wanted LED headlights bulbs but have not because of issues; fearing less visibility or blinding others. There are some members on here that are using LEDs and claim good results. The Auxbeam brand comes to mind, but not 100%.
  13. Mar 17, 2020 at 1:04 PM
    AndyBoyea
    AndyBoyea New Member
    Andy
    2015 Tundra SR5 CrewMax
    So I have an odd situation here. Can't find anything on it so I am hoping this post will generate one! I have a 2015 Tundra SR5 Crewmax. All the bulbs have been changed to LED's. Everything is lighting up. The front directional bulbs were hyperflashing so I added resistors to each of the front directionals and that took care of the hyperflashing BUT ONLY when I do not have the running lights or headlights on! That's right, they blink just like they should until I turn on my running lights then they start hyperflashing again! What am I missing or do I need to do in addition to adding the resistors to the front directionals? Thanks, Andy
  14. Mar 21, 2020 at 10:03 AM
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2020 Midnight Black Metallic TRD Pro
    How and where did you connect your resistors?
  15. Mar 21, 2020 at 10:31 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    What ohm rating are the resistors you added? Six ohms is not enough impedance for two LEDs in the same turn signal circuit. If you replaced front and rear bulbs with LEDs, you will need a single six ohm resister at each LED location.
  16. Mar 21, 2020 at 10:56 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you want LED headlights, I'd look into replacing your entire headlights with 2018+ OEM and an iHacker harness.
    Wiring Harness for the 2018+ LED Headlights conversion on 2014-2020 models.
    https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/
    I was going to do it, but I like my amber DRLs.
  17. Mar 21, 2020 at 3:12 PM
    AndyBoyea
    Andy
    Thanks for the heads up on this issue. I put 6-ohm resistors only on the front blinkers. 1 for each of the front blinkers for a total of two. I attached the resistor to the ground wire and the blinker wire which I believe were the white black wire (ground) and the red wire (blinker) . Again they blink perfectly normal now when I'm not running my running lights or headlights. And to make things even crazier the other day I turned on my headlights and the left blinker will work now like normal but the right blinker will only work normal when I'm not using the headlights or running lights! :) looks like I need to put resistors on the rear blinkers as well which I did not do. I will try that and get back to you on the results afterwards. Thank you again for the information! Andy
  18. Mar 21, 2020 at 4:27 PM
    FrogmanTundra
    FrogmanTundra New Member
    Nashville
    2013 Rock Warrior DC
    Just wanted to clarify that headlights are not on a momentary switch. A momentary switch is only "made" when it is actuated, for example this is what a high beam flash switch would use. Headlights will be on a maintained two position switch either on or off.
  19. Mar 21, 2020 at 8:26 PM
    JohnLakeman
    Headlight Revolution has a video showing the resister installation for the rears. See the link below. Resistor installation starts about 11:00 minutes and ends about 15:00 minutes.
    I used a single 3 ohm resister for each side in the rear, and that worked great for front and rear. You'll have to use 6 ohm resisters in the rear since already have the 6 ohm resister in the front.
    https://www.youtube.com/watch?v=z4HlVYkceNo
  20. Mar 21, 2020 at 8:48 PM
    Rockanock
    Rockanock 21 Chevy 2500
    Did you change the blinker fluid?
    Tundra2 likes this.
  21. Mar 24, 2020 at 4:01 PM
    AndyBoyea
    Andy
    UPDATE: so I installed the 2 new Sylvania resistors on the back blinkers. I have 2 Sylvania resistors on the front blinkers as well. All 4 corners of the 2015 Tundra SR5 have Sylvania resistors on the blinkers. The hyperflashing has now disappeared... Even with my running lights and/or headlights in the on position the hyperflashing is not occurring! Thanks for the help!
    NOTE/HOWEVER: now I have another odd issue occurring. When I do NOT have the running lights or headlights on the front LED blinkers work as they should with a bright "on-off-on" with distinction between the "off and on" part of the blink. The rear blinkers work the same...perfectly. However, when I put on my running lights or headlights the front LED blinkers now work like the incandescent bulbs did....they glow "on-off-on" and are not as bright and don't have that distinct on-off-on. The rear LED blinkers work perfectly regardless of whether I have my running lights on or headlights on. thoughts?
  22. Apr 13, 2020 at 4:00 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    We’re the wires different colors in the headlights from driver side to passenger side
  23. Apr 13, 2020 at 5:08 PM
    AndyBoyea
    Andy
    the wires were the exact same colors on all corners of the vehicle.... left to right and front to back.... Toyota used the same colors for the ground and hot wires....
  24. Apr 13, 2020 at 5:13 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Ok thanks. I just sold my old set to someone and I wanted to help them install them. I thought I remembered someone a long time ago saying they were dif colors on dif sides. Thank you
