Hi/Low Diff Lubrication
Discussion in 'General Tundra Discussion' started by TILLY, Mar 20, 2020.
  1. Mar 20, 2020 at 5:49 PM
    TILLY
    TILLY [OP] Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    While i was out driving today, i realized i hadn't driven in 4WD for awhile as Toyota suggests to keep the front diff nice and lubricated. I had a nice long stretch of straight road so ran it in 4H for about ten minutes or so. My question is this, is just using 4H adequate, or should you try to get it into 4L occasionally too, which isn't always easy this time of year. :monocle:
  2. Mar 20, 2020 at 6:09 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    It's exercising the same major components, wouldn't worry about not getting it into 4lo. You're doing more than most....
    15whtrd likes this.
  3. Mar 20, 2020 at 6:24 PM
    TILLY
    Massachusetts
    Thanks, that's what i figured. :thumbsup: Wasn't sure if it was beneficial to have the transfer case actuator go through its full range of motion periodically to keep it working properly.
  4. Mar 20, 2020 at 8:48 PM
    Blue Thunder
    Washington
    Great question...I think the transfer case is pretty open gearing right? So all that gets lubricated with normal driving. Engaging 4wd just gets the front drive system spinning and moving fluids around. That should happen in Lo or Hi.
    Thinking out loud here...not an expert.
    TILLY[OP] likes this.
  5. Mar 20, 2020 at 10:57 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    You probably still need to engage 4LO. I think a big part of using them is making sure the electronic actuators keep moving. The Actuator for 4LO is different than the one for 4HI.
    15whtrd and TILLY[OP] like this.
  6. Mar 21, 2020 at 8:25 AM
    TILLY
    Massachusetts
    Thanks for your input. Maybe just engaging 4L and going a few feet in the driveway would be better than nothing.
    15whtrd likes this.
  7. Mar 21, 2020 at 8:57 AM
    Blue Thunder
    Washington
    No dirt parking lots near you? That's where I got to run my system every few months
  8. Mar 21, 2020 at 9:03 AM
    TILLY
    Massachusetts
    Great idea, I'll look around. :)
