Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Jan 9, 2017 at 4:49 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Since this is a very common question :deadhorse: @Bob made a solid suggestion of having a stickied thread. I stole @csuviper' s text from this thread.
    TIRE SIZE WITH AND WITHOUT LIFT KITS:
    Note: These recommendations are based on the factory wheels. Using an upgraded rim with different backspacing will allow you to increase to a wider tire.
    First Gen Tundra (2000-2006)
    No Lift Kit
    Max tire sizes are:
    • 16″ rims: 275/70 R16 – 4/10ths wider, half-inch taller than largest factory tire size
    • 17″ rims: 265/70 R17 – one inch taller but same width as factory
    • 17″ rims: 275/65 R17 – 4/10ths wider, half-inch taller than largest factory tire size
    1.5 – 2″ Leveling Kit (or less)
    When installing a leveling kit, you might be able to fit some wider tires than what we have listed. It may require some trimming though, but it is possible.
    Max tire sizes are:
    • 16″ rims: 265/75 R16 – one inch taller but same width as factory
    • 17″ rims: 275/70 R17 – 1.5 inches taller and 4/10ths wider than factory
    3″ Lift Kit
    With a 3″ lift kit, the options continue to get better. However, the wider the tire, the greater the likelihood of trimming.
    Max tire sizes are:
    • 16″ rims: 285/75 R16 – slightly more than 2″ taller than factory, this tire is 8/10ths wider than factory as well. This width may be problematic in tight turns and/or at full suspension compression.
    • 16″ rims: 265/80 R16 – an oddball size, this tire is the same width as the factory but more than 2″ taller
    • 17″ rims: 285/70 R17 – slightly more than 2″ taller than factory, this tire is 8/10ths wider than factory as well. This width may be problematic in tight turns and/or at full suspension compression.
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
    • 20″ rims: 275/60 R20 – one inch taller but same width as factory
    Max tire sizes are:
    • 18″ rims: 275/70 R18 – One inch taller but same width as factory.
    • 18″ rims: 285/70 R18 – 4/10ths wider and 1.7 inches taller than factory. Trimming may be necessary.
    • 18″ rims: 295/65 R18 – 1 inch taller, 8/10ths wider than factory. Trimming is probably needed due to width.
    • 20″ rims: 285/60 R20 – 4/10ths wider and 1.5 inches taller than factory.
    3″ Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/75 R18 – 4/10ths wider and 2.8″ taller than factory.
    • 18″ rims: 305/70 R18 – 1.2 inches wider and 2.8″ taller than factory. There are Tundra owners running this size, but trimming is required. Replacing the stock wheels with after-market 18′s that have less backspacing is recommended.
    • 20″ rims: 285/65 R20 – 4/10ths wider, 1.6″ taller than factory.
    • 20″ rims: 305/60 R20 – 1.2 inches wider and 2.4″ taller than factory. There are Tundra owners running this size, but trimming is required (it’s a tight fit).
  2. Jan 9, 2017 at 5:47 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Thats awesome. I've sworn off responding to 'will this fit' threads, but I may just chime in enough to post a link to this thread.
    Dgjman, jewsNbrews, Sunnier and 2 others like this.
  3. Jan 9, 2017 at 6:03 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
  4. Jan 9, 2017 at 6:39 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Welp, there goes 90% of all new posts.
  5. Jan 9, 2017 at 6:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nah. We'll always have a diesel tundra post to fill that gap :rofl:
  6. Jan 9, 2017 at 7:19 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Maybe some guys could chime in with the offsets and all they have so that can be added to the first post as well. I know a lot of folks swap out the wheels when they're looking for tires. So having different offset numbers up there might be helpful.
    I'm running 285/65/18 Nitto Trail Grapplers with a +30 offset and have no rubbing without any modifications. It's a tight fit, but they work. Brand of tire is important too when considering tires because the actual width depends on the tire. My trail grapplers are 285 so they should be an 11.5" tire, but they're actually just under 12"
  7. Jan 9, 2017 at 7:23 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I had 295/60/20 tires and +18 offset wheels on 2.5" lift. I had to remove all mud flaps and push the wheel well liner in to eliminate rubbing. I will be running the same wheel/tire specs on my new truck with 3" lift.
  8. Jan 9, 2017 at 7:31 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    :bananadead:
    Tundra2 likes this.
  9. Jan 9, 2017 at 7:56 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  10. Jan 9, 2017 at 9:54 PM
    Need another one for MPG's.
  11. Jan 9, 2017 at 10:08 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Lets not forget the ever popular what headlight bulbs should I use....
    Tundra2, flinky14, Jrocker and 2 others like this.
  12. Jan 10, 2017 at 3:47 AM
    Zharris
    Zharris Merica!
    Nahhh. That would be too scary to read. Haha
  13. Jan 10, 2017 at 4:36 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    where would a 295/55/20 fit into this table for a stock 3rd gen? think it would fit with no lift and a tad bit of trimming? its about 3/4" wider and 3/4" taller.
  14. Jan 10, 2017 at 5:42 AM
    Asking for a friend?
    :rofl::D
    flinky14 and Ardnut like this.
  15. Jan 10, 2017 at 5:45 AM
    Netmonkey
    Georgetown, TX
    no.... for me :)
    T-Rex266[QUOTED][OP] likes this.
  16. Jan 12, 2017 at 2:55 AM
    MrSmith89
    MrSmith89 New Member
    Allan
    Toyota Tundra 2014
    I just created account to say thanks for this information. I was looking for the largest tire size for my stock 2nd gen tundra and finally got it!
    Seto87, ToyoLife, RJtundra13 and 6 others like this.
  17. Jan 12, 2017 at 6:53 AM
    TXMiamiFan
    Jose
    And now you're gonna leaving us?? I feel so used :(
  18. Jan 12, 2017 at 7:51 AM
    MrSmith89
    Allan
    Toyota Tundra 2014
    Ha-ha)
    Tundra2 and TXMiamiFan like this.
  19. Jan 12, 2017 at 8:02 AM
    1of2000
    1of2000 New Member
    Long Island, NY
    2006 Tundra Darrell Waltrip
    I don't see 18 inch rims under 1st generation. Mine are stock on a Darrell Waltrip model. Looking to replace stock tires with 285/65/18's. Any issues with this size on a stock suspension?
    lionix likes this.
  20. Jan 12, 2017 at 8:08 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Damn. I must be doing something wrong with my 35x12.50x18's. They fit.
  21. Jan 12, 2017 at 8:26 AM
    jberry813
    Lake Tahoe
    LOL. Just don't have to be scared to cut shit. CMC, trimmed skid plate, remove front mud flap, remove front lower plastics, and proper offset and anyone is gold.
  22. Jan 23, 2017 at 7:08 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    So from what I've read, the pro has a factory lift/level of around 3 inches in front and 2 in the rear. Which means I should be able to run 285/75r18s if I wanted?
    Hacksaw likes this.
  23. Jan 23, 2017 at 7:12 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I don't own a pro but believe they are only 2" higher in front and the same in the rear. I am running a 285/75R-18 on OEM wheels, but have a few mods.
    OR18TRD and T-Rex266[OP] like this.
  24. Jan 24, 2017 at 10:27 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think there needs to be a sticky on how to use the search function.. I feel like I see the same grill and spyder headlight/bulb questions every time I log in lol :frusty:.
    Or a prompt when users first login:
    "What would you like to ask today?"
    o What grill do you have
    o What lift should I go with
    o Anyone have Spyder headlights
  25. Jan 24, 2017 at 10:34 AM
    Thought about that too, but will it actually be used?
    boardude likes this.
  26. Jan 24, 2017 at 10:43 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    CM-LENNY is correct. ~2" in the front, same in the rear for the Pro. I had a chance to measure one and compare to mine.
    joonbug likes this.
  27. Jan 24, 2017 at 10:45 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    What size is considered factory? I have 285/55R20, which is an upgrade with the TSS package. I think the "factory" tire is slightly smaller, correct?
    Cat3ILS likes this.
  28. Jan 24, 2017 at 11:11 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Add fenders to that list and sky is the limit
    FREEK, ACDC2ZZTop, OHwendTrd and 8 others like this.
  29. Feb 26, 2017 at 7:56 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I've been searching for a search button since I joined this community. If there was one then a ton of my questions would never have been asked publicly.... forget that, I still have more questions! But, it certainly would be a great function.
  30. Feb 26, 2017 at 8:00 AM
    Top right hand corner...
    bulldog93, Motor71, mdavis and 4 others like this.
