Shackles or blocks to get an extra 0.75" of rake
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ssls6, Feb 12, 2020.
  1. Feb 12, 2020 at 8:54 AM
    ssls6
    ssls6 [OP] Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    My 2020 Pro is very level (maybe 1/2" higher in rear). I'd like another 0.75" of rake for functionality reasons. All the shackle manufacturers I've looked at say "not for use in Pro due to dual exhaust". Blocks would seem a better answer (doesn't change pinion tilt) but I can't find anything around 0.75". Has anyone faced this issue, if so then how did you solve it?
  2. Feb 12, 2020 at 9:01 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    I believe you can get away with the +1 Coachbuilder shackle without hitting the exhaust...keep in mind the exhaust clearance would really come into play at full droop IIRC...but I'm sure someone more knowledgeable will chime in
  3. Feb 12, 2020 at 9:31 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I think more folks on here lean replacing the shackles.
  4. Feb 12, 2020 at 9:36 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I would give David @Coachbuilder1 a call or pm him and he can walk you through what you would need to achieve that.
  5. Feb 12, 2020 at 9:46 AM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Shackles 100%. They actually help the ride dynamics than hurt it, as blocks would.
  6. Feb 12, 2020 at 9:49 AM
    OV-1794
    OV-1794 New Member
    Shackles
  7. Feb 12, 2020 at 9:50 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  8. Feb 12, 2020 at 9:53 AM
    LogCabins
    'Merica
    2017 TRD Pro
  9. Feb 12, 2020 at 9:55 AM
    OV-1794
    OV-1794 New Member
  10. Feb 12, 2020 at 10:01 AM
    ssls6
    Richard
    South Park, CO
    2020 TRD Pro CM
    Does everyone switch out the rear rubber bushings for the included poly bushings?
    15whtrd likes this.
  11. Feb 12, 2020 at 10:04 AM
    15whtrd
    15whtrd Mr. Blonde
    Definitely! That really completes the package. Even if you were going to keep the stock shackles, poly bushings really clean everything up. Your stock bushings are splined, so when you tighten the shackle against them they are bound in that spot. The poly bushings allow the shackle to do its job.
  12. Feb 12, 2020 at 10:09 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I have +1 coachbuilder shackles in combination with Alcan leaf pack on my 17 Pro. Setup works great. +1 shim will not hit dual exhaust.
  13. Feb 12, 2020 at 10:27 AM
    ssls6
    Richard
    South Park, CO
    2020 TRD Pro CM
    I appreciate all the inputs, sounds like 1" shackles should do the trick. Are new bolts includes or do you reuse your old ones.
  14. Feb 12, 2020 at 10:37 AM
    LogCabins
    'Merica
    2017 TRD Pro
    They come with new hardware (aka bolts) you will be all set....it will be a little bit of work to pull the stock bushings from your leafs….if you click the link I posted above it shows you everything they come with and even has instructions on changing them
    15whtrd likes this.
  15. Feb 12, 2020 at 10:45 AM
    15whtrd
    15whtrd Mr. Blonde
    Start hitting those bushings in the leafspring with some PB blaster now. I rented a balljoint press. The cups weren’t quite deep enough to push it all the way out but once they got started it was easy to push them out the rest of the way. You can get creative.
  16. Feb 12, 2020 at 10:47 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Second what Sean said....if you get the 4x4 balljoint press adapter from wherever you rent the balljoint press from it should be deep enough to press them all the way out.
    15whtrd[QUOTED] likes this.
  17. Feb 12, 2020 at 2:03 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I would love to gain about an inch more rake in the rear. Still not sure how I'm going to go about that yet. For the time being I will let that sleeping dog lay.
  18. Feb 12, 2020 at 2:19 PM
    ssls6
    Richard
    South Park, CO
    2020 TRD Pro CM
    My headlights have electric motors to tilt them down, are there also manual adjustments to tilt them back up (after adding more rake)?
  19. Feb 12, 2020 at 2:30 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes. I marked the gear with paint pen and tried one turn on both sides. Ended up trying three turns and backing it off down to two full turns. I figured I’d liked the level they were at stock and typically run it at around 2 on the dial inside the truck. So I tried to get it back into that same zone after the lift. I’m sure there is a better way to do it bye marking it on your garage door etc. etc. but this was my simple man’s way of doing it.
    nvrgvup444 likes this.
  20. Feb 14, 2020 at 4:15 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Definitely get the shackles. I have #3’s with no issues
  21. Feb 15, 2020 at 3:59 AM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    If you are looking for 3/4" to 1" of rake on a PRO, go with the +2 shackle from Coachbuilder.
  22. Feb 15, 2020 at 4:48 AM
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    I am running CB +2 shackles but i have the SR5, not the pro
  23. Feb 15, 2020 at 4:59 AM
    Hhtundra
    Hhtundra New Member
    Running toytec at 1.5, most shackles will come with grade 8 hardware, blocks are not that great, coachbuilder will last forever, on the cheaper end you have max trac and proform fabrication, keep in mind also if u ever want to add deavers in the rear youll need a certain type of shackle, i believe either total chaos or camburg
  24. Feb 19, 2020 at 1:02 PM
    ssls6
    Richard
    South Park, CO
    2020 TRD Pro CM
    Did the CB 1" kit today (and rear sway bar since I was under the truck). Appreciate all the comments.
    Was at 0.4" of rake (I measured when new and was at 0.6" as I recall but have since added a hard tonneau cover or maybe it settled) and now I'm at 1" of rake. I can live with 1" and I did not see any danger to the exhaust. I will say the brake lines get pretty tight at full droop.
  25. Feb 19, 2020 at 1:22 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Shackles for sure. I went from 1" block to 1.5" shackles (Toytec), and it does help the ride.
  26. Feb 19, 2020 at 1:26 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I run the CB+2s with the pro suspension and exhaust. I’ve hit quite a few trails and have yet to rip anything off. That being said, I’m not putting it on full flex on a daily/weekend basis. I’d say weigh the benefits of each set up compared with what you’ll be using the truck for. Regardless, I’ll echo what others have said about the CB shackles and poly bushings. Completely worth it!
    Huckwheat likes this.
  27. Mar 16, 2020 at 5:21 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    I’d agree with everyone else. Grab some shackles. I have a 1” block and it’s fine for. Now. I’ll eventually get shackles when I redo my suspension.
  28. Mar 19, 2020 at 11:16 AM
    19TundraPRO
    19TundraPRO New Member
    AZ
    I have a 2019 Pro and put the CB +1s on. The rake is now 1 1/4" which I think looks good. When I put a dirt bike in the back or hook up a light trailer the rake is slightly higher than level. I bought the ball joint press from Harbor Freight and it worked great.
