Highest mileage 1st Gen. Thread?
Discussion in '1st Gen Tundras (2000-2006)' started by donaldp83, Feb 28, 2017.
How many miles are on your 1st gen?
  1. 0-99k
    51 vote(s)
    9.0%
  2. 100k-199k
    211 vote(s)
    37.3%
  3. 200k-299k
    199 vote(s)
    35.2%
  4. 300k +
    105 vote(s)
    18.6%
  1. Mar 8, 2020 at 5:48 PM
    #301
    bmf4069 Captain wtf
    It's not that it causes failure, it causes the already bad clutches to slip with the new fluid. It washes out all the old friction material in the old fluid thats keeping the bad clutches working.
  2. Mar 9, 2020 at 1:20 AM
    #302
    Josh.martin
    Josh.martin New Member
    Josh
    2004 Burgundy Tundra limited
    266,xxx on my 04 limited double cab. Runs great and will hopefully last me another 10 years, if rust doesn’t take over by then...
  3. Mar 19, 2020 at 5:44 AM
    #303
    tyler17b_
    tyler17b_ New Member
    Tyler
    2002 tundra sr5
    Original starter and trans in mine, 410,000 miles.
  4. Mar 20, 2020 at 8:54 PM
    #304
    GinoXL
    GinoXL New Member
    2004 Double Cab SR5
    Just bought mine for $1400 in the same condition.
  5. Apr 29, 2020 at 9:02 PM
    #305
    FLJ23
    FLJ23 New Member
    2004 DC 4x4
    Stock for now
    Hi fellas I’m thinking of picking up a 2002 Tundra AC 4x4, it has 250k but person just got it a couple months ago and isn’t aware of the timing belt being done.
    I checked the Carfax app and there’s no record of it ever being done by a shop.
    If the person had the truck for several years I would go for it but I’m Hessitant with those miles and seller just picking up and selling truck right away.
    I have almost 200k on my LX470, and 201k on my ES350.
    I’m not afraid of them but don’t want to pick up the truck and have to dump in steering rack which is common, timing belt, water pump.
    What do you guys think? It’s very clean outside, decent inside.
  6. Apr 30, 2020 at 5:31 AM
    #306
    Is steering rack that common? Mine's on 250k miles. Could be what I hear whining occasionally, but works great and doesn't leak. If you need a truck and that one is less than $3500 in great shape I would consider it. Obviously inspect the frame. The timing belt is a catastrophic failure item. I would pull the cover on one of the cam sprockets and at least inspect it. If it looks good, replace at your convenience. Pretty sure mine went 212k miles before it was replaced by the second owner, me.
    Josh.martin likes this.
  7. May 13, 2020 at 4:01 PM
    #307
    Professional Hand Model
    Fred
    Hand Protectors
    I’ve had my 2002 since brand new and the timing belt was done at 110k miles in 2014. She is sitting at 169k miles now. Pretty sure my local garage didn’t register the belt redo at CarFax (dealer scam site). If someone questioned me and said, ‘Well the TB is not on registered on CarFaux’ then I’d laugh right in their face.
    Go and look and buy it if it looks good. Otherwise move on and find another.
    Nothing beats eyes/hands on.
  8. May 13, 2020 at 4:38 PM
    #308
    Fred
    Hand Protectors
    Long story and nothing personal against you. I wear a tin foil hat to hold things down at night. Tomorrow morning after my second cup of Dark Italian Roast all things will become parallel.
  9. May 13, 2020 at 7:40 PM
    #309
    ThundaTundra
    ThundaTundra New Member
    Dude
    2001 Green Tundra SR5
    None
    Rear brakes was my issue
  10. Dec 13, 2020 at 3:05 AM
    #310
    school teacher
    school teacher New Member
    Edward
    Louisville Ky
    2002 Tundra Limited
    Leer Cap RAV/4 V-6
    I drive my truck about 60 miles a day. It is a 2002 4.7 Limited Access Cab with 273,000 on the clock. New Toyota rebuilt transmission at 250,000 miles. Excellent condition and well worth the $31,500 sticker price when I bought it new in Oct, 2001. Before the Tundra, I had a 1983 Ford E150 Club Wagon with a 300 CID inline 6 and a 4 speed manual transmission. It went 331.000 miles and my goal is to st least beat that with this Tundra. I have had my non-Toyota shop replace all 8 coil units when 2 units failed at about 240,000 miles. I have replaced the timing belt 3 times.
    I replaced the front section of the 2 piece drive shaft at 190,000 along with 3 universal joints and the center support. I had vibration in the drive line between 35 and 70 mph. The Toyota tech wanted to replace the rear end at an estimated cost of $6000. My independent shop rebuilt the drive line for under $800.
  11. Dec 13, 2020 at 3:06 AM
    #311
    school teacher
    Edward
    Louisville Ky
    2002 Tundra Limited
    Leer Cap RAV/4 V-6
  12. Jun 10, 2021 at 7:10 PM
    #312
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    How many 400k trucks do we have on here? Those trucks would definitely be legendary.
    Tundra2 likes this.
  13. Jun 10, 2021 at 7:28 PM
    #313
    Jack McCarthy The jackass who owes me for a stripper tab
    I would be more interested in seeing a chart of mileage vs 1st, 2nd and 3rd+ owners.
  14. Jun 10, 2021 at 7:38 PM
    #314
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    A lot of 2nd gens have well over 200k as well.
  15. Jun 11, 2021 at 12:13 PM
    #315
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Interesteing. I've heard of new fluid causing a trans failure, but I've never considered this as the mechanism. Seems reasonable.
  16. Jul 1, 2021 at 9:52 AM
    #316
    tyler17b_
    Tyler
    2002 tundra sr5
    Up to 441,000 now. I know it’s filthy, she’s just a work truck :muscleflexing:
  17. Jul 1, 2021 at 10:16 AM
    #317
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Life goals.
    Are most of those your miles? What does your maintenance schedule look like?
    Filthyphil likes this.
  18. Jul 1, 2021 at 12:01 PM
    #318
    Filthyphil
    Phil
    That’s beautiful original engine and tranny?
    MS22 and onesojourner like this.
  19. Jul 1, 2021 at 12:29 PM
    #319
    tyler17b_
    Tyler
    2002 tundra sr5
    actually only about 50k of them are mine, it was bought new by a close family member and I’m the second owner. uncle drove coast to coast chasing hail storms (he’s in the paintless dent repair buisness). He’s claimed multiple times he’d go 10k+ miles between oil changes and only serviced the transmission a couple times. Which I believe because the trans fluid looks like mud lol but I’m too scared to change it. He’s for sure had one timing belt installed but can’t recall if he had a second one. I just drive it now for work and just give it a little tlc and drive the wheels off of it. Has never let him nor me down!
    Yessir original engine and trans. Engine has plenty of power, no smoke, no noises, purrs like a kitty. Trans has a little slop between first and second but everything else shifts nice and firm.
  20. Jul 1, 2021 at 12:51 PM
    #320
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Legendary.
    Do you plan to do the timing belt?
    I understand the transmission fear. Have you considered just one drain and fill to see if that improves the shift issue?
  21. Jul 1, 2021 at 9:34 PM
    #321
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm in the same boat with the trans. Way fewer miles (176k) but has the slop between 1st and 2nd (unless you put it in "2" then no slop between 1st and 2nd, unsure how that works) and sometimes relatively rough shifts nothing too terrible. Fluid is dark-ish doesn't smell too bad. I'm considering just a drain and fill once or maybe twice to see if it does anything good. I don't think the trans has ever been serviced. I know the previous owner hauled a camper some so hoping I'll never have to do a trans. At 441k and maybe only having done 1 timing belt on yours, it might be worth taking off a few bolts for the drivers side timing cover and at least take a look at the belt.
    onesojourner likes this.
  22. Jul 1, 2021 at 9:38 PM
    #322
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
  23. Jul 2, 2021 at 12:19 PM
    #323
    tyler17b_
    Tyler
    2002 tundra sr5
    :thumbsup::thumbsup:
    i plan on doing a timing belt/water pump in the fall. As far as the trans goes, it was about a quart low when I checked it about 25k ago so I added a quart of Lucas. It did noticeably improve the slip bang shift but it’s still there. We’re just going to see how long this fluid really lasts :thumbsup:
    When I first bought it I had to replace the fan pulley bracket/faux water pump and was able to see most of the belt. I was very surprised by the shape it was in, it looked almost like a brand new belt. I checked both sides of the belt and could not find any cracking or fraying. Either way it won’t hurt to get a new one on here soon.
    onesojourner[QUOTED] likes this.
  24. Jul 2, 2021 at 12:49 PM
    #324
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'm amazed the "D" light still functions. I'm getting close to 400K also. Well done sir. :hattip:
    onesojourner, KNABORES and Filthyphil like this.
  25. Jul 2, 2021 at 7:18 PM
    #325
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Mine doesnt work :/
  26. Jul 2, 2021 at 9:40 PM
    #326
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Are you thinking of doing your timing belt since you are at 7-years, although way below the 90k miles? Mine is similar and wondering if we really need to do that. Thoughts?
  27. Jul 3, 2021 at 3:28 AM
    #327
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to Toyota Maintenance Guide, it's 90K or 108mo(9yr). Personally, unless I had coolant issues(WP, radiator), seal issues, I would simply be planning to change the TB as it approaches the yr or miles parameter.
    KNABORES likes this.
  28. Jul 3, 2021 at 6:30 AM
    #328
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My first belt change was at 12 years old and 72,000 miles. Now I'm at 8 years and about 24,000 miles since the last and only belt replacement. I did do a H2o pump last time. I've been pondering this off and on for a while, whether to replace the belt and maybe pump again next year. Seems a bit silly with such low miles since the last change. It's a big job and FWIW, the original belt looked fine after 70k plus miles. I guess I will think on it since I still have time according to official Toyota's guidelines.
  29. Jul 3, 2021 at 12:10 PM
    #329
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    2000 SR5 4wd
    Purchased new. Other than standard maintenance it has rarely needed anything over the past 21 years, and I've left everything stock. Replaced cracked exhaust manifold and two O2 sensors, right side brake caliper and new valve cover gaskets. Recently replaced the radiator but that was elective because I had read enough stories about radiator fluid getting into the transmission. I think that's about it. It drives as smooth and quiet as new. Remarkable.
    Took pics today.
  30. Dec 22, 2021 at 7:36 PM
    #330
    Averyklinnnn
    Averyklinnnn New Member
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    I've got an 02 tundra that was given to me by my grandma she used it as a pilot car for hotshotting anyways it's got 652,000 miles original motor religious oil changes small things have been replaced but it's still running strong now time for a 17 year old to take it over. Sounds like I got you guys beat on highest miles
    abcinv, bmf4069, FirstGenVol and 2 others like this.
