Power inverters - good bad the ugly?
Discussion in '2.5 Gen Tundras (2014-2021)' started by too tall, Jan 23, 2017.
  1. Jan 23, 2017 at 6:01 PM
    too tall
    too tall [OP] New Member
    I've got some truck camping dates upcoming and want to be able to boil water with a electric kettle. Is that a reasonable thing to do using a power inverter or asking too much?
  2. Jan 23, 2017 at 6:09 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Depends on the inverter. Do you already have on or are you looking to buy one?
  3. Jan 23, 2017 at 6:10 PM
    too tall
    Looking to buy. My wife's 4Runner has this ability built in, pretty nice thing to have.
  4. Jan 23, 2017 at 6:14 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  5. Jan 23, 2017 at 6:46 PM
    There are a lot a cheap power inverters out there. It's not only about wattage output. Of course you want your inverter to handle the current draw for everything that is going to load it down. Things to consider: Duty cycle factor, distortion= "how "clean" is the AC volts out"??, how good is your battery. I like Bestek inverters, although Whistler, Wagan , and Cobra's are OK. It's better to pay some extra $ for something reliable. Make sure you read the mfr specs. Do a comparison between the different brands. (Think Prepping)
    csuviper, TruckyTruck and D1227 like this.
  6. Jan 23, 2017 at 7:11 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    I think the inverter is the only thing I miss about my Tacoma. I have been wanting to wire one up in the tool box of my tundra though.
    TruckyTruck likes this.
  7. Jan 23, 2017 at 7:17 PM
    Fool proof vegan inverter:
    AnonVet, landphil, ColoradoTJ and 4 others like this.
  8. Jan 23, 2017 at 7:22 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    ROTF!!!
  9. Jan 23, 2017 at 7:46 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
  10. Jan 23, 2017 at 8:01 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Thanks but I don't think it will power my camper lol
  11. Jan 23, 2017 at 8:02 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Big problem is the amps inverters pull. Higher the wattage the bigger the pull on amps. In turn the alternator has to keep up with battery discharge , vehicle power and now inverter draw.
    Like matluth said you run into how clean the sign wave is coming out and everything else. I could write a 3 page report for you but on Tapatalk no thanks.
    If you want to use a kettle for hot water they make 12v kettles last time I checked.
    too tall[OP] and D1227 like this.
  12. Jan 23, 2017 at 8:21 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    I was thinking of a deep cycle battery with an isolation switch + inverter in my tool box..wired to the main battery? But don't know shit about distortion or clean waves. Hmmm
  13. Jan 23, 2017 at 8:29 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I agree with Bob and Matt. Taxing your electrical system for boiled water isn't my cup of tea (pun not intended).
  14. Jan 23, 2017 at 8:33 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Just so everyone is on the same page I'm not the op...just chimed in to hopes seem some info on the subject i can boil water without fancy gadgets...I'm interested in an inverter set up for a multitude of reasons...:thumbsup:
  15. Jan 23, 2017 at 8:39 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    2nd'ing
    I have numerous Jet boils. They are far superior to electrical as far as cost, time, and consumption go. When I'm in the field I have the Jetboil Sumo, but I also bring the Optimus Crux for cooking. Both tend to last me a few days and get hot as hell.
    https://www.amazon.com/Optimus-Crux...F8&qid=1485232603&sr=1-13&keywords=boil+stove
    I teach survival skills year round in Utah (colds as low as -10 and highs as hot as 110) and haven't gotten let down by either since my purchase.
    Bob, ColoradoTJ, TruckyTruck and 2 others like this.
  16. Jan 23, 2017 at 8:42 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    MSR also makes really reliable backpacking versions if you're looking for something compact. I use the Whisperlite International for long trips backpacking.
    D1227 likes this.
  17. Jan 23, 2017 at 8:46 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    We gotcha. There are certainly good reasons for an inverter. I just don't think boiling water is one of them. Right tool for the job and all that.
    One thing to take with a grain of salt is advertised inverter power ratings. You can spend $100 on a so-called 2000W inverter, or $300 on a 300 watt inverter. The key here, is realistic expectations. Actually pulling 2000W from an automotive electrical system is not realistic. Pulling 2000W would equate to roughly 200 Amps of current draw assuming an inverter with ~80% efficiency and wires the size of arc welding cables. Try plugging that into your cigarette lighter!
  18. Jan 23, 2017 at 9:00 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    I would mind something that was similar to what I had in the Tacoma I just want it hooked to deep cycle with an isolator so I can use it with out running my truck.
  19. Jan 23, 2017 at 9:02 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    What is realistic from an automotive system?
    D1227 likes this.
  20. Jan 23, 2017 at 9:12 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    I'm not sure about the Taco, but with the factory inverter option on the Tundra (2nd gen) I seem to recall it being rated at 150W. I'm guessing the Taco used the same parts. Now with a dedicated Deep-cycle battery and a very short cable run from the battery to the inverter it seems to me that 5 - 800 watts would be more than realistic.
    Just plug the expected draw into this off-the-hip formula. Watts / 12 * 1.2 will give you a good ballpark as to expected current draw. So at 500 watts, you're looking at around 50 Amps. You'd want to fuse it at about +20%, so a 60A breaker would keep you safe. Also note that most inverters are rated for max draw. So don't expect to pull 500 sustained watts out of an inverter rated at 500 watts. (i.e. read the fine print)
    With a stock battery/charge system, I wouldn't try pulling more than 300 watts for any length of time.
    Plug your numbers into this wire size calculator to determine what size wires you should run.
  21. Jan 23, 2017 at 9:26 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Nice...that's the info I was hoping to get thank man.
    Now let's say some jackass wanted the battery and inverter in their tool box any chance of explosion. Hypothetical of coarse:spy:
  22. Jan 23, 2017 at 9:26 PM
    TruckyTruck
    Gary
    Thanks Bob
    D1227 likes this.
  23. Jan 23, 2017 at 9:28 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Well. as long as the hypothetical jackass had some ventilation in the toolbox, and wasn't using LiPo batteries, prolly not :)
    D1227[QUOTED] likes this.
  24. Jan 23, 2017 at 9:31 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Good to know thank you.
    Oh yeah on other thing lipo batt?
  25. Jan 23, 2017 at 9:34 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Lithium Polymer - Think Samsung, Hover-boards, FedEx planes and other things that go boom.
    tat2ude39 and D1227 like this.
  26. Jan 23, 2017 at 9:37 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Got it
  27. Jan 23, 2017 at 10:04 PM
    My 14 Taco has a 400W inverter, FYI.
    For boiling water, I would not be using anything electric.
    D1227 likes this.
  28. Jan 23, 2017 at 10:17 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  29. Jan 24, 2017 at 4:31 AM
    too tall
    Thanks y'all set me straight.
    D1227 likes this.
  30. Jan 24, 2017 at 7:29 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    I'm what you call a glamperaholic
    i carry a full sized stove, a full sized bbq, a fridge, on board hot water, a coffee maker and a microwave.
    to power the last two i have a 3000w cobra inverter. i have double 0 gauge cable running to it and it is able to run my devices easily.
    D1227 likes this.
