Bluetooth syncing issue
Discussion in 'Audio & Video' started by aiceeslater, Mar 15, 2020.
  1. Mar 15, 2020 at 12:50 PM
    aiceeslater
    aiceeslater [OP] New Member
    Alberta
    2019 TRD Pro
    Sorry if this is a heavily discussed issue. I searched the forums a bit and couldn’t find anyone with this problem.
    Basically, my phone only automatically syncs with the truck about 75% of the time and then when I try to manually do it, it won’t sync.
    If I’m at a stop sign or something and shut the truck off, then start again, it connects and off I go. Is there a reason this is intermittent? Obviously having to turn the truck on and off while out and about is not ideal. I’ve owned other trucks that did this so I know it’s not unique but if there’s a solution to the problem, I’d love to know.
    thanks
  2. Mar 15, 2020 at 1:33 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Any other issues with other bluetooth devices you use with your phone?
    You might try deleting the phone from the truck system and then adding it back new.
