BDS LIFT ISSUES (please read)
Discussion in 'Suspension' started by sargebt, Dec 18, 2018.
  1. Dec 18, 2018 at 5:22 AM
    sargebt
    sargebt [OP] New Member
    Brandon
    2016 Platinum Tundra
    7 inch BDS, running 35’s
    I have a 16 with the 7 inch BDS lift. I noticed I have perfect tire wear so I’m not experiencing the bump steering BUT I do have this chirping or skipping of the tires at full lock left and right turns. Anyone have a solution to this or experienced this.
    Thanks
    Jsena likes this.
  2. Dec 18, 2018 at 5:39 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I believe 99.9% of our lifted trucks do this. when they are lifted the ackermann angle changes
  3. Dec 18, 2018 at 1:38 PM
    sargebt
    Brandon
    Yeah but I’ve heard it’s an issue with BDS so I wanna know if anyone else has this problem or did. Or if a readylift tundra has it as well.
    Anyone?
  4. Dec 18, 2018 at 2:01 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What exactly is happening ??
  5. Dec 18, 2018 at 2:05 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    It’s happens when your turning slow at full lock? I’f so it’s pretty normal when it’s lifted
  6. Dec 18, 2018 at 2:10 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Same here I think it's normal
  7. Dec 18, 2018 at 4:51 PM
    sargebt
    Brandon
    Really? Okay well I’ve heard it can fixed so I was wondering if anyone had it corrected
  8. Dec 18, 2018 at 5:03 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I think it contributed to body roll. Like the tire is leaning in amd the sidewall of the tire is grabbing the road. What kind of tires you have?
    Jsena likes this.
  9. Dec 18, 2018 at 7:18 PM
    sargebt
    Brandon
    I know the theory around the Ackerman steering but how to we correct the issue or is there one
  10. Dec 18, 2018 at 7:52 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    I think Ackerman is only affected if you replaced spindles and the BDS spindles don’t have the same position of the tie rod. I doubt this is the case, since BDS generally know their stuff, but if it is Ackerman, then the only way to fix it is to go back to stock spindles.
    I think what you’re experiencing is an issue with scrub radius. What offset wheels are you running? Offset has a large effect on scrub that most overlook to fit bigger/wider tires, but has a large effect on turning radius and effect of said turn.
    Jsena likes this.
  11. Dec 18, 2018 at 7:55 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So is everyone talking about when you turn slowly almost full lock , it feels like your tire just skipped or slid from under something??
  12. Dec 18, 2018 at 8:02 PM
    sargebt
    Brandon
    Yep that’s it!! My wheels are not that offset at all!!
    Jsena likes this.
  13. Dec 18, 2018 at 8:04 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That happens to me every once in a while. Always wondered what it was but don’t care anymore. I still don’t know what it is. My offset is -25 tho so that’s a lot I guess . 7 inch BDS Lift as well
  14. Dec 18, 2018 at 8:11 PM
    the_midwesterner
    Luis
    None, yet....
    This is very much scrub radius. Mcpherson struts vehicles tend to be slightly negative scrub, meaning the centerline of the wheel is on the inside of where the SAI meets Scrub vertical line on the road. By going with negative offset wheels, this pushes the centerline of the wheel outward, which puts you into a positive scrub. This then cause the wheel not to spin in its center line, so it kind of pushes while rotating since it’s centerline arc has now changed. If that makes sense...
    Jsena[QUOTED] likes this.
  15. Dec 18, 2018 at 8:13 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Not sure how much I understand it, BUT!!!! Thanx for letting me know it’s kinda normal with this offset lol.. thanx bros :cheers:
  16. Dec 18, 2018 at 9:02 PM
    Vizsla
    Vizsla 2 = 2.5
    It is the ackerman angle with the BDS spindles, tie rod is moved.
    14burrito and Jsena like this.
  17. Dec 19, 2018 at 12:03 AM
    tmart
    tmart New Member
    Travis
    I have same lift and negative offset wheels and mine does it. On 2 different sets of tires 35s and 37s. Perfectly aligned too, it’s normal
    Jsena likes this.
  18. Dec 19, 2018 at 12:03 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    It doesn’t bother me anyways. Only does it every once in a while. I don’t csre
  19. Dec 19, 2018 at 12:05 AM
    tmart
    tmart New Member
    Travis
    Yeah and it’s only at full lock on something smooth like concrete or real smooth asphalt. It makes people get the hell out of the way quicker too so I like it lol
  20. Dec 19, 2018 at 4:19 AM
    sargebt
    Brandon
    Hahaha true true guys. So a posture offset wheel wouldn’t do it you leave?
  21. Dec 19, 2018 at 5:28 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    I have 7" BDS, too. I don't hear tires slipping at full lock, but I do hear a noise. Once in a blue moon - it doesn't happen often at all - at full lock, it sounds like someone is under my front end and whacks something with a hammer. Real loud metal thud sound. Is this maybe the same thing?
  22. Dec 19, 2018 at 8:01 AM
    the_midwesterner
    Luis
    None, yet....
    Good to know. I would have assumed they would have tried to keep the same Ackerman since they cast their own spindles.
  23. Dec 19, 2018 at 8:22 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Thanks for confirming :)
  24. Mar 13, 2020 at 4:10 PM
    Myhobbes25
    Myhobbes25 New Member
    Jeffery
    Western Washington
    2014 Toyota Tundra Platinum
    Rigid fog Lights, 35x12.50x20 BF Goodrich KO2 Tires, 20x9 Fuel Trophy Wheels, Pro Comp Stage 2 Full Suspension Lift 6 inches, K&N Intake, Magnaflow Muffler, Husky X Contour Floor mats, Pina Colada Scented Tree
    Is there a solution to this? I have the same problem on the Procomp stage 2 6inch lift. My wheels are Fuel Trophy D552 20x9 Offset 1 BS 5in. Do I need different tie rod ends like coachbuilder with heim joints? TIA!
  25. Mar 13, 2020 at 5:16 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Glad i read this. Mines has been doing this since i lifted it. Usually hear it in parking lots, especially when my tires go over the painted lines. Im running -76 offset so what can i say lol.
