2020 Tundra Plat Crew - bed cover
Discussion in '2.5 Gen Tundras (2014-2021)' started by Iamseaza, Mar 12, 2020.
  1. Mar 12, 2020 at 9:10 AM
    Iamseaza
    Iamseaza [OP] New Member
    I am new to owning a Tundra - just bought one last night, upgraded from a Nissan Juke..never owned a truck before.
    I am looking for a bed cover (tri fold)
    Looking for recommendations on one that doesn't leak .
  2. Mar 12, 2020 at 9:23 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    My Extang Trifecta tonneau cover doesn't leak. This is the second one I have owned.
  3. Mar 12, 2020 at 10:09 AM
    Iamseaza
    Thanks! Is yours a 2020 do you know the model #
  4. Mar 12, 2020 at 10:41 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Do yourself a favor and just get a Diamondback. SD can hold 400lbs on top HD can hold 1600 lbs. Completely weathertight, locks so your entire bed area is secure. I've had my HD on for about 5 months now and couldn't be happier. Not a drop of water has gotten into my bed.
    Also, made in America and if you or anyone in your family was or is in the military, you receive a nice discount!
  5. Mar 12, 2020 at 10:43 AM
    plumber802
    Andy
    Vermont
  6. Mar 12, 2020 at 11:35 AM
    Iamseaza
    That's nice - is it on Amazon or did you go through them directly?
  7. Mar 12, 2020 at 11:41 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    TheHutchTTU likes this.
  8. Mar 12, 2020 at 11:55 AM
    Iamseaza
  9. Mar 12, 2020 at 11:57 AM
    Iamseaza
  10. Mar 12, 2020 at 12:24 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Im on my second because new truck Extang Encore, give it a look before you buy anything else
  11. Mar 12, 2020 at 9:02 PM
    Iamseaza
    Do you have the Amazon link to the right one? I see one on amazon but it says it doesnt fit the tundra
  12. Mar 12, 2020 at 11:38 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    I was in the same spot as you a few weeks ago. Just bought my 2020 tundra plat and was shopping around for a cover. From my research, diamondback are the best, but at a steep steep 1.5k~ price tag. I ended up going with an undercover flex and I love it, price was reasonable and its a trifold. And it’s sealed nicely through one rainy day so far. You can shop around and places will give you discounts on them. Install fairly simple and has drain tubes in case water goes in. Good luck!
  13. Mar 13, 2020 at 4:06 AM
    Iamseaza
    Thanks!
    Yeah I was looking at the diamonds and they seem nice - but I feel it would limit access to the bed. I want something that is able to be more compact -
    I am was looking at the undercover last night and also the Bak BAKflip MX4 Hardflip - Bak has decent reviews on Amazon.
  14. Mar 13, 2020 at 1:17 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Yes I was going to buy the bakflip mx4 as well cause it’s very popular and has good reviews. The undercover flex was about $150-170 cheaper so I went with that. The bakflip is a quadfold which is cool but I was fine with the trifold and it performs the exact same.
  15. Mar 16, 2020 at 6:52 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    I love my bakflip mx4...does everything you need and no issues.
  16. Mar 16, 2020 at 7:48 AM
    Iamseaza
    Thanks all - ended up getting the Bakflip - it's a good price and has some good reviews
  17. Mar 17, 2020 at 12:30 PM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    I have the bakflip mx4 as well.. I do occasionally get a little leakage in the corners near the tailgate. Use locktite on the fasteners up front as well on the little struts that hold up the cover, the vibration will shake things loose and the cover will start to slide..
  18. Mar 17, 2020 at 7:11 PM
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2020 Midnight Black Metallic TRD Pro
    Can the bakflip be locked? Also, does it hit the back window when folded all the way?
  19. Mar 17, 2020 at 7:36 PM
    daven
    daven New Member
    When the backflip is down and you lock the tail gate, the backflip can't be opened (at least not with force). When it is all the way folded up, it does rest against the back of the cab.
  20. Mar 18, 2020 at 2:37 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    thats also what i liked about the undercover flex, folded up it doesnt touch the back of the cab. So no scratches or any marks at all. After heavy rain for a few days, it does leak into the bed around the rear corners but not insane amount.
  21. Mar 18, 2020 at 2:55 PM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    I chose an Extang Solidfold 2.0 for several reasons. Here are a couple:
    I wanted a cover that did not require me to bolt another rail inside the bed as most (all?) of the 'lay flat' type covers require. This was also important to me because I also installed a BedRug and the addition of a second rail would have required some cutting of that. Also, I didn't want a lay-flat tonneau rail intruding into the truck bed box.
    Thirdly, I did not like the cable release on many other tonneaus that are vulnerable to someone using a coat hanger to snag the release it even if the tailgate is locked.
    The installation was quick and simple, but I was very careful to align the tonneau so that it was perfectly centered on the top of the bed box. I have had *zero* problems with water leaks even in heavy rain or after truck washing with the garden hose. Don't use a car wash, so I can't speak to that, but I don't expect a different result.
    Good luck.
