Weak Brakes or too Much Torque?
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Mar 8, 2020.
  1. Mar 8, 2020 at 5:21 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I recall about a year ago someone asking if anyone had issues with the brakes holding strong while at a stop light. I didnt think much of it until recently. Ive had several times where I have crept up on the vehicle in front of me unknowingly, only until I was close enough to apply significant pressure on the brake pedal to keep the truck stopped.
    A few days ago I was sitting at a stop light, as I've done hundreds of times before, and I thought the car in front of me was backing up all of a sudden. I smashed the brake pedal hard, only to discover that I was moving forward, and the vehicle in front of me was stationary. I was only inches away from the car in front of me.
    Do y'all think this is due to the lack of pressure from the brake fluid to the calipers, a lack of brake pedal leverage, or due to the amount of low end torque due to the 4.30 rear end?
  2. Mar 8, 2020 at 5:27 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    When was the last time you bled your brakes?
    I was having this issue only to find out that the yahoos that touched my truck last improperly bled my rear calipers. After 30 mins under the truck and a bunch of air coming out of the lines, I had strong brakes again. I haven’t had the creeping issue since.
    GODZILLA likes this.
  3. Mar 8, 2020 at 5:29 PM
    awq735
    Anthony
    Ohio
    Never. My truck has 11500 miles on it and has only had 2 oil changes from the dealership. I cant imagine it could have that much air in the lines from the factory.
  4. Mar 8, 2020 at 5:32 PM
    Dirt Dawg
    Connor
    Denver, CO
    If it’s that new then maybe you just aren’t used to it?
    The tundra definitely requires more pedal pressure than the Audi in my garage. But I never felt like I’ve had to press extra hard at stops.
  5. Mar 8, 2020 at 5:40 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I don’t know the answer, but experience the exact same thing. It requires much more hold brake pedal pressure than any other vehicle I have owned.
    Tundyfundy, BENWALES and Hoff like this.
  6. Mar 8, 2020 at 5:41 PM
    What's your idle rpm in neutral? Just curious..
  7. Mar 8, 2020 at 5:42 PM
    My 07 didn't have this issue and my 14 doesn't either...
  8. Mar 8, 2020 at 5:45 PM
    mountainpete
    Didn’t have the issue on my Tacoma, Land Cruisers, etc, either. I’ve routinely found myself coming close to cars at stop lights because I didn’t apply enough pressure.
    After a year and a half I’m just starting to get used to it.
  9. Mar 8, 2020 at 6:06 PM
    1FSTREX
    1FSTREX New Member
    Will
    Northern California
    2023 Limited OR
    I have this same exact issue
    MGM2018OR likes this.
  10. Mar 8, 2020 at 6:14 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Never noticed. Maybe you could adjust your seat position so that your foot naturally is applying enough pressure. I’ve found if you’re too far away, you may feel like you need to push harder due to the position your heel is in in the driving position.
    xJuice and Black Wolf like this.
  11. Mar 8, 2020 at 6:39 PM
  12. Mar 8, 2020 at 6:42 PM
    Our front rotors are quite substantial, not to mention our oversized front calipers compared to the competition. No reason for creep at a stop. Once again................
  13. Mar 9, 2020 at 9:52 AM
    awq735
    Anthony
    Ohio
    In drive, while stopped it is sitting at 550 rpm according to my scan gauge. When in neutral its sitting at 770 rpm.
  14. Mar 9, 2020 at 9:53 AM
    awq735
    Anthony
    Ohio
    I sit pretty close to the steering wheel. I dony have to stretch my leg for either pedal.
    Tundyfundy likes this.
  15. Mar 9, 2020 at 9:54 AM
    15whtrd
    15whtrd Mr. Blonde
    Have you been skipping leg day? JK LOL
    Trooper2, MGM2018OR, GODZILLA and 2 others like this.
  16. Mar 9, 2020 at 10:08 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I too have noticed this, over the last 9k miles, I have had to readjust how much pressure I use while at a stop light. Way more pressure needed then my 09 I traded in on the 19.
    Freaked me out a few times to be honest!!
  17. Mar 9, 2020 at 10:23 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Same here. Both of my Tundras. It's annoying.
  18. Mar 9, 2020 at 10:24 AM
    mountainpete
    I feel like we need a support group for creepy Tundras. :turtleride:
    Trooper2 and awq735[OP] like this.
  19. Mar 9, 2020 at 11:33 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Sounds like you need "Heavier Shoes" to hold the pedal down. Disclaimer: (1) "Heavier Shoes" will decrease fuel economy. (2) "Heaver Shoes" will increase smiles per gallon. (3) "Heavier Shoes" will not be held liable for increased encounters with local and state Law Enforcement or that annoying noise you refer to as your spouse in the passenger seat screaming "STOP IT BEN, WHEN ARE YOU GONNA GROW UP!!!".
    I've seen this in my and my buddies truck (both Tundras), big engine+low gear ratio makes it want to creep, even worse when the a/c cycles on.
    GODZILLA, Jaypown and 15whtrd like this.
  20. Mar 9, 2020 at 12:08 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I've noticed this in my Tacoma. Exactly as @BENWALES says, worse with A/C. But if i'm not paying attention and get lazy with my foot, i'll notice i start creeping forward. I've just learned to be cognitive. Also, not being distracted when at a light or at a stop while in Drive.
    BENWALES likes this.
  21. Mar 9, 2020 at 12:24 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    I have the same experience with my tundra.
  22. Mar 9, 2020 at 12:48 PM
    awq735
    Anthony
    Ohio
    Is it considered skipping if you never do leg day?
  23. Mar 9, 2020 at 12:53 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl:I haven’t been to the gym in a while myself. And I always hate leg day. So I guess if you never go, you never skipped it LOL.
    GODZILLA and awq735[QUOTED][OP] like this.
  24. Mar 9, 2020 at 1:35 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I have The Tundra Creep. Leg day?
  25. Mar 9, 2020 at 5:07 PM
    15whtrd
    15whtrd Mr. Blonde
    So you can push harder on the brake.:D
  26. Mar 13, 2020 at 8:33 PM
    Taofouajarodeve
    Taofouajarodeve New Member
    Tao
    2021 Voo Doo Blue Crewmax
    None
    I’m a ex-soccer player and hunter. It does take more pressure on brakes than any other vehicle I’ve owned. We’re holding back 380 horses.
  27. Mar 14, 2020 at 2:51 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I do the same thing just more play in the pedal than my wife’s car which I drive 50 percent of the time.
  28. Mar 14, 2020 at 3:07 AM
    18" TRD Off Road Wheels
    Thank you for this. I needed the laugh, and this is gold.
    BENWALES[QUOTED] likes this.
  29. Mar 14, 2020 at 7:40 AM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    OK it’s funny you guys mentioned this. In my tundra I find that when I get to the stoplight I automatically put it in neutral and then pop it back in gear when the light turns green because of this. I never realized I consciously did this until I read this post and started thinking about it. Funny I don’t have to do this on my wife’s pilot! LOL
  30. Mar 14, 2020 at 7:40 AM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Brake fluid does wear out. It gets contaminated with copper. If you have never did a brake flush after that many miles. You might consider that one. But if anything. The brakes are overbuilt for these trucks. Deff not the torque of the truck in 1st at an idle. You have something going on with the brake system
