Radiator Overflow
Discussion in 'General Tundra Discussion' started by Rex Kramer, Mar 8, 2020.
  1. Mar 8, 2020 at 4:31 PM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    I enjoyed a few high RPM blasts down the highway while driving the '07 5.7L back from a friends house today, I stopped to top of the gas tank and thought I smelled anti-freeze. Nothing strong, just a hint of it in the air.
    I popped open the hood after parking in the driveway and I could see where fluid had spewed out of the overflow tank sometime during the trip, I also noticed that the overflow tank was about 1/2 full.
    I let it cool off for 2 hours and checked it again, the overflow tank is almost empty and the radiator is full. The coolant left in the overflow has returned to the radiator.
    The radiator was flushed when I purchased the truck, and I've put about 20,000 miles on it since then. I believe the radiator is original, and I have no idea how old the water pump or thermostat are.
    What could be going on here?
  2. Mar 9, 2020 at 5:12 AM
    Rex Kramer
    Georgia
    Anyone?
  3. Mar 9, 2020 at 5:27 AM
    15whtrd
    15whtrd Mr. Blonde
    Could be that it’s time for a radiator or water pump or thermostat. But I would probably try a radiator cap first.
    I put a TRD one on. Just for the hell of it. It had a few more psi threshold than stock. I want to say it was 18 psi instead of 15.
    TTund16, Wynnded, ColoradoTJ and 2 others like this.
  4. Mar 9, 2020 at 5:57 AM
    Is this your Tundra with 275k miles?
    Rex Kramer[OP] likes this.
  5. Mar 9, 2020 at 6:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    This^^^^.
    I've had cooling problems eat my lunch before, and never found the problem. The one thing I didn't do, and I should have done, was change the freakin' radiator after everything else had failed. I relied on flushing and chemical cleaners to get the job done, and it just didn't. If a new radiator cap, then a new thermostat, doesn't work, then I would try replacing the radiator before tackling a water pump having no external signs of leakage. I have never seen a water pump failure from lack of pumping (worn or broken impeller), but my experience is not totally complete.
    15whtrd[QUOTED] likes this.
  6. Mar 9, 2020 at 6:15 AM
    15whtrd
    15whtrd Mr. Blonde
    I feel the same way about the water pump, but I have seen them rotten on the inside without leaking. Like it was still doing its job just not well.
    JohnLakeman[QUOTED] likes this.
  7. Mar 9, 2020 at 6:25 AM
    Rex Kramer
    Georgia
    I ordered the TRD cap, and I have a new water pump sitting in a box ready to go. Since the factory radiator has 291k on it, replacing it with another OEM radiator seems like the most cost effective solution... and I guess an OEM thermostat is another good choice.
    Neither of my temperature gauges indicated a problem.
    YardBird likes this.
  8. Mar 9, 2020 at 6:27 AM
    Vizsla
    Vizsla 2 = 2.5
  9. Mar 9, 2020 at 6:27 AM
    JohnLakeman
    Ah, yes...Your comment about "rotten on the inside" restores my memory of 50K mile SBC water pumps after GM changed to sheet metal impellers from cast iron. Yep, poor coolant maintenance could lead to "rotten on the inside" water pumps. I'm guessing Toyota, and everybody else, is probably using erosion-prone plastic impellers now? :D
  10. Mar 9, 2020 at 6:36 AM
    15whtrd
    15whtrd Mr. Blonde
    Yep! It was a SBC! Unsure of Toyota materials. Also a buddy of mine has a Dakota with the 4.7. The aluminum of the water pump had eaten away enough around the impeller pocket, that it looked like it wasn’t flowing properly anymore. The truck had over 200 K on it. We were in the engine doing the heads and upon removal of the water pump, which is huge on the truck, after inspection we decided to change it out. I laughed at my friend and said you should’ve planned on it anyways.
  11. Mar 9, 2020 at 6:42 AM
    Rex Kramer
    Georgia
  12. Mar 9, 2020 at 7:21 AM
    Rex Kramer
    Georgia
    Indeed.
    JohnLakeman and Bucktail like this.
  13. Mar 9, 2020 at 7:28 AM
    thrustmaster
    thrustmaster New Member
    Joel
    dallas
    2016 Tundra Crewmax MGM 2WD
    Could be that the radiator is gunked up. This happened to me on an s10 years ago after flushing the cullant system.
  14. Mar 9, 2020 at 8:12 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    How soon did you stop for gas after the few high rpm pulls on the highway ?
  15. Mar 9, 2020 at 8:13 AM
    Rex Kramer
    Georgia
    About 5 minutes after the last blast.
  16. Mar 9, 2020 at 8:17 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    it could just be that the coolant heated up enough to go into the overflow but didn’t get a chance to cool down enough to go back into the rad .
    I would put some coolant in the overflow and drive it on the highway without doing any high rpm pulls and then check it again after that .
  17. Mar 9, 2020 at 9:27 AM
    Rex Kramer
    Georgia
    But wait, there's more.
    Whenever I cold start this truck on a really damp & foggy morning I hear a loud screeching sound that I assumed was fan belt noise because it would fade after about 90 seconds, so a new belt was placed on my list of things to do.
    Today's cold start (60 degrees and low humidity) I hear a high pitched whine that sounds more like a bearing, it faded after about 2 minutes. This is the first time I have heard this sound, and I am thinking it's water pump related.
    What are your thoughts after reading this new information?
  18. Mar 9, 2020 at 9:30 AM
    JohnLakeman
    Quite possible imo, but it wouldn't make sense as cause for overheating. UNLESS...the bearing is actually seizing and stopping pump rotation leaving the belt to slip on the pulley. :eek: If it's a water pump bearing, that problem will manifest quickly as visible leakage due to shaft vibration, which destroys the mechanical seal.
  19. Mar 9, 2020 at 9:37 AM
    15whtrd
    15whtrd Mr. Blonde
    Do you think it’s possible you got coolant all over the pulleys and belt, and caused a squealing this morning.
    JohnLakeman likes this.
  20. Mar 9, 2020 at 9:43 AM
    Rex Kramer
    Georgia
    Okay it's probably not the bearing... I am not experiencing an overheating problem in the typical sense, just this little bit of fluid escaping via the overflow tube.
    Yes, but there really isn't much coolant loss. There was actually more coolant in the reservoir this morning.
    YardBird and 15whtrd[QUOTED] like this.
  21. Mar 9, 2020 at 9:44 AM
    BigRedFireEngine
    BigRedFireEngine New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    Okay, before we start replacing water pumps and rads I will tell you that I was alarmed a few weeks ago when I noticed my coolant overflow near empty a few hours after a short drive. I panicked. But no signs of coolant loss.
    Right after the next drive I noticed the coolant back up to half full in the overflow. It obviously varies based on heat, load etc.
    My point is, you said you had the rad flushed. Any chance the tech just overfilled it, and you're heavy pedal just sent the excess our the overflow hose?
    May be no issue here other than a tech being a little too liberal with the coolant.
  22. Mar 9, 2020 at 9:46 AM
    15whtrd
    15whtrd Mr. Blonde
    He’s pretty meticulous about his truck. I can guarantee you his coolant overflow was probably at a perfect level LOL.
    my suggestion would be start with the radiator cap.
  23. Mar 9, 2020 at 9:48 AM
    Rex Kramer
    Georgia
    The new TRD cap will arrive before week's end.
  24. Mar 9, 2020 at 12:09 PM
    Rex Kramer
    Georgia
    Update:
    I cleaned all of the coolant off with Simple Green, and the belt squeak went away - good call Mr. Blonde. I talked with my tech while picking up a gallon of the pink stuff, he said that it sounds as though everything is functioning as it should considering the driving circumstances I described. The overflow tank is half way to the Max line, and I haven't added a drop.
    YardBird, 15whtrd and JohnLakeman like this.
  25. Mar 9, 2020 at 12:33 PM
    15whtrd
    15whtrd Mr. Blonde
    I had a truck that did not like the max hot full line of the overflow tank. every time I would top it off it would spit a little out after a hot drive. Finally I quit touching it and it leveled off to a happy place. Never got any lower.
  26. Mar 9, 2020 at 1:16 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Looks like you might have resolved the squeak but through it this out there. I recently had a belt squeak during cold mornings for like a minute and it would go away. Ended up replacing my belt, tensioner and idler pulley. All was good after that.
    YardBird and Rex Kramer[OP] like this.
  27. Mar 9, 2020 at 1:21 PM
    Rex Kramer
    Georgia
    It's on my list.
    YardBird and vhstejskal[QUOTED] like this.
  28. Mar 9, 2020 at 6:35 PM
    Tundra_power
    Tundra_power New Member
    Correct i had mine always at full mark i checked one morning and most of the coolant was gone. I freaked out because i didnt smell or see any leak i thought i had a blow head gasket. I let the truck get to opreating temp and coolant is now at full mark. Remember coolant will decrease in volume when cold. Only thing i can think of is either it got to hot and overflow and got on the belts and bearing and thats the noise your hearing. Please dont replace parts if you have to only replace the broken one. I know you have a s*** ton of miles but its a Toyota not a ford lol. But if i was you i would get a pressure tester and test the coolant system and see if you have any leaks in the radiator or water pump.
    YardBird, 15whtrd and Rex Kramer[OP] like this.
  29. Mar 30, 2020 at 5:49 AM
    Rex Kramer
    Georgia
    Functional TRD bling under the hood.
    15whtrd likes this.
  30. Mar 30, 2020 at 5:09 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    I noticed in the first post that the foam strip that seals the frame and the top of the radiator was missing. I always wondered what that was for and why it was there. Does that help more air not escape over the radiator and force it to go through the radiator? I highly doubt that's your issue, but just saw that foam missing and wondering?
