Anyone Rebuilt a Subwoofer?
Discussion in 'Audio & Video' started by Danimal86, Mar 6, 2020.
  1. Mar 6, 2020 at 7:01 AM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    So on my way home the other day (this was in my commuter car, a toyota matrix), it was great weather and with the long drive ahead of me, i rolled down the windows and cranked on some music. I noticed that my bass sounded really bad. It sounded like it was producing a higher frequency of sound than it should. Ahh SHIT.....I turn off the sub on the head unit and make the drive home without the slap.
    I get home, start to trouble shoot by checking the resistance across the terminals on the box...checks out at what it should be (2ohms). Check everything around the amp, and the back of the head unit thinking maybe one of the two rca's had come out....nope.
    Next on the list was to check the sub itself. Now mind you, its got a mesh grill on it that's a pain to remove so i waited for last.
    l-Fv6rDzqdDdemo_S7EFewzPY2_Dfv99P2AJGUT6_c07d9216ff41136cf4fe366077bc0119740260c3.jpg
    well, found the problem....blew out the foam surround. I'm fairly surprised at this. the amp i'm running is rated at 500w rms and this JL 10w6v2-d4 is rated to 600w rms, 1200 max.
    I have been working this guy hard for the last 8 or so years and it has always sounded amazing, the foam ring must have dried out and given up the ghost.
    After looking around to see if there was anything that caught my attention as far as replacing the box and sub, i found a foam ring repair kit for cheap.
    I ordered it, and its on its way to me. Has anyone ever repaired a subwoofer's foam ring? Either way, i'll post some pictures of the repair process.
  2. Mar 6, 2020 at 7:04 AM
    Elduder
    Elduder New Member
    8 years is a good amount of service. Good luck. :thumbsup:
  3. Mar 6, 2020 at 7:05 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    8 years? You got your use out of it haha. Good luck with the repair kit though. Just take your time and clean the mating surfaces off really well and should be ok.
  4. Mar 6, 2020 at 7:07 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  5. Mar 6, 2020 at 7:18 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Don’t worry about the repair - buy a new sub and get one with a rubber surround.
  6. Mar 6, 2020 at 7:23 AM
    Danimal86
    Daniel
    Sacramento, CA
    Looks painless.....except for the sound when he was scraping the basket.
  7. Mar 6, 2020 at 7:27 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  8. Mar 6, 2020 at 7:29 AM
    GravityGear
    Aurora, CO
    I did a couple in my day. Not sure I'd do it again. I'll send one out next time i need a recone. It's a lot of prep. Cleaning the basket is key. Make sure you don't glue the VC to the magnet... That's the worst.
    Fixmyspeaker has drop-in recone kits. Give them a call. It's easier than a ground up rebuild.
  9. Mar 6, 2020 at 8:21 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    just rebuild it, piece of cake.
  10. Mar 6, 2020 at 9:42 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I replace the foam surround in a pair of these with rubber about 20 years ago. They're still going strong. It's not hard, just tedious.
    Darkness likes this.
  11. Mar 7, 2020 at 9:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    The new poly ring will be here on monday, so i thought i'd start picking away at it today. Got the factory ring cut out and started peeling back the glue. So far i've done one pass around the cone with a chisel and it took off most of the glue. I'm not sure i'll be able to get it down to bare plastic, but i'm hoping a little residual glue wont hurt anything.
    gwVyPW5Z0b33pwSd06Hq1cjYYyEj2mM6BuAlUS4__19eb35cb6b644ba3a21fb829d63bde0a09bd8a59.jpg
    Darkness, JMB and Elduder like this.
  12. Mar 7, 2020 at 9:30 AM
    Elduder
    Elduder New Member
    Heat gun and plastic chisel. Or maybe some orange solvent.
  13. Mar 7, 2020 at 11:19 AM
    Danimal86
    Daniel
    Sacramento, CA
    I thought about goo gone.....didn't think about a heat gun
  14. Mar 7, 2020 at 11:41 AM
    shawn474
    MoCo, Maryland
    Be very careful using a heat gun; you can easily compromise the other connections using one of those
  15. Mar 7, 2020 at 11:54 AM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    I e been able to repair the current foam with the clear gorilla glue...
    JL has great customer service and can repair it for cheap if the repair doesn’t take just FYI.
    take your time and make sure everything lines up and you’ll be GTG!
  16. Mar 7, 2020 at 1:53 PM
    Elduder
    Elduder New Member
    True, maybe a hair dryer. Either way, orange solvent will do it with a bit more elbow grease.
  17. Mar 7, 2020 at 1:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    Had a surprise in the mail.....a couple days earlier than it was supposed toIMG_20200307_135257.jpg
  18. Mar 7, 2020 at 3:52 PM
    Danimal86
    Daniel
    Sacramento, CA
    Just finished it up. Got some glue around the cone and around the edge of the basket. Not worried because there is a grill covering it.
    I'll let the glue sit over night and re mount it tomorrow.
  19. Mar 7, 2020 at 4:21 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Looks good :thumbsup: maybe u’ll get another 8 years out of it :fingerscrossed:
  20. Mar 8, 2020 at 2:03 PM
    Danimal86
    Daniel
    Sacramento, CA
    I let the glue sit overnight and just threw it back in the box. Gave it a little bit of power and sounds great again. I'll go easy on it for a while before i give her hell!
    Jbehredt likes this.
  21. May 1, 2020 at 4:39 AM
    R3MY
    R3MY New Member
    2020 Tundra Sport
    Did you fit this sub in your Tundra? I'm looking at upgrading my audio and was wanting to see if I can put in 2 12's at the back of the seat? If 2 12" JL Audio W6's could fit back there, because I am really into BASS and want the system to be loud and booming.
  22. May 1, 2020 at 5:29 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    This was not in his tundra. Behind the seat options are limited. A pair of 12TW3s would fit, W6s would require heavy modification.
  23. May 1, 2020 at 6:13 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Do it, a lot cheaper than new speakers. I've re-foamed by Cerwin-Vegas twice in the 40 years I've had them but they do reside inside the house.
