Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Feb 16, 2020 at 6:48 AM
    #1951
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have those tires and love them !
  2. Feb 18, 2020 at 6:59 PM
    #1952
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Heck yeah! I sell tons of Ridge grapplers at work but up until now I’ve had no first hand experience of noise or ride quality. In all honesty I am very happy with them. Noise is about the same as the BFG KO2 (I couldn’t care less about noise though, LOL) and ride quality is a ton better. I won’t know if it’s because I went from a 20 to an 18 or exactly why the ride is better but, I wouldn’t ever want to go back to what I had.
    Happy to hear that you like yours!
  3. Feb 18, 2020 at 7:36 PM
    #1953
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    What load range are the grapplers?
  4. Feb 18, 2020 at 10:08 PM
    #1954
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Hell yea, looks good man
  5. Feb 19, 2020 at 4:09 AM
    #1955
    Scuba
    Scuba Sober member
    Austin, Tx.
    Load range E.
    Thank you! It’s a pretty basic set up but the first setup on this truck that I really like.
    easleycrawler[QUOTED] likes this.
  6. Feb 19, 2020 at 4:38 AM
    #1956
    easleycrawler
    Travis
    I've been running BFG'S for 99% of my adult life, just put a set of 275/65 18's on my truck, e rated. I wish BFG made that size is a different rating. I'm seriously considering selling them and trying the ridge grapplers in the XL load range. They are 10lbs lighter than my BFG'S per tire and probably will ride alot better.
  7. Feb 19, 2020 at 6:42 AM
    #1957
    jordan0317
    Jordan
    Martin, TN
    Its definitely sharp, and I actually like those stock wheels alot. Was looking for a set of those on Facebook when I got a deal kn the ones I have or that was the route that I was going to go too
  8. Feb 20, 2020 at 5:14 PM
    #1958
    Scuba
    Scuba Sober member
    Austin, Tx.
    I would check and possibly lower the air pressure before doing much else. An E load range tire can ride just fine on a half ton but proper air pressure is a must.
    What do you have them set at?
  9. Feb 20, 2020 at 5:19 PM
    #1959
    easleycrawler
    Travis
    I checked the other day, it was 40 all the way around. Dropped the front to 38 and the rear down to 36. Made a helluva difference, much better. It's crazy what 2&4 lbs will do.
  10. Feb 22, 2020 at 7:35 AM
    #1960
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Nice looking truck. Looking to do almost the same setup. If you could change anything from your setup what would it be?
    Tundra$[QUOTED] likes this.
  11. Feb 22, 2020 at 5:36 PM
    #1961
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Would go 35x12.5 now and just grit my teeth and cut the cab mount. That’s it though. If I felt like spending more money I woulda got a real lift instead of a level
    YotaTruckLtd[QUOTED] likes this.
  12. Feb 23, 2020 at 5:20 AM
    #1962
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    me too ! I plan on getting a 4-6" lift anyways and get rid of my leveling kit soon !
  13. Feb 23, 2020 at 5:57 PM
    #1963
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    2012 with Bilstein 5100s on middle setting on the front. Added TRD Pro wheels and 275/70/18 Cooper AT3s. I found out I get a little rub at full lock I think on the skid plate but haven't confirmed yet. I'm happy with the look.20200222_075816.jpg 20200222_080353.jpg
  14. Feb 24, 2020 at 10:43 PM
    #1964
    daays
    daays New Member
    Ordered some matte black 18x9 Method Grids today, and I’ve seen people mentioning ET lugs. Do I need ET lugs with Methods, and does anyone have any recommendations on a set of black ones? Thanks guys!
  15. Feb 25, 2020 at 7:26 PM
    #1965
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Going to be doing a 3 inch lift with 33x12.5 tires. Wheels are going 18x9 with a +30mm offset, will that offset cause any rubbing or require trimming. Thanks in advance for the help.
    tumaro likes this.
  16. Feb 27, 2020 at 9:23 AM
    #1966
    Gasparr597
    Gasparr597 New Member
    mike
    2017 SR5 double cab Quick Sand
    Rough Country 3/1.5 level lift
    looking to run this exact same setup any rubbing and if so what did you have to modify worried to run this setup and have to do serious metal trimming.
  17. Feb 29, 2020 at 3:45 PM
    #1967
    Skyride56
    Skyride56 New Member
    Joe
    Franklin, TN
    2005 Black Tundra Limited DC
    Leveled w/ Bilsteins 5100, 285 70R17 Nitto Ridge Grapplers, 17x9 +01 Fuel Vapor wheels
    2005 Limited DC: Leveled with Bilstein 5100 #4 setting I believe. 285 70R17 Nitto Ridge Grapplers, 17x9 +01 Fuel Vapor Matte Black wheels. No rubbing after install.
    silverstreak16 and Sleeper16plat like this.
  18. Mar 1, 2020 at 5:46 AM
    #1968
    Scuba
    Scuba Sober member
    Austin, Tx.
    More than likely, yes. I would plan to use ET lugs but test fit one in the lug holes before mounting anything. Make sure a. the ET portion doesn’t extend past the back mounting face of the wheel and b. the hole is large enough to accept the ET lugs. Icon wheels are the only ones that I know of that are designed to not require ET lugs. Your mileage may vary. ;)
    equin likes this.
  19. Mar 1, 2020 at 2:49 PM
    #1969
    TONKA TUNDRA
    TONKA TUNDRA HULK SMASH!!
    KY
    2014 DC Magnetic Grey
    Scuba trucks looks awesome. Thanks for the pics. This is the setup I've been looking for. I have a 2014 DC with these wheels and have been wondering if I'm going to need spacers or not. I'm looking at 295/70/18 so slightly shorter and slightly wider but should be close to what you're running. Sounds like I may get away without the spacers but its gonna be tight.
    Can anyone tell me if the body mount will have less or more clearance with the Spidertraxx spacers? I'm fine with manipulating the inner fender as I've done that on my previous Tundra but want to avoid doing a BMC.
  20. Mar 1, 2020 at 7:30 PM
    #1970
    Scuba
    Scuba Sober member
    Austin, Tx.
    Thanks man! I dig the look of the 285’s and the stock wheels make the truck look more high class. They are super close to the UCA. I honestly don’t think a 295 would work but I could be wrong. I think I may still add a 1” or 1.25” spacer. Having the 285’s tucked completely in the fender looks a little odd from the front.
  21. Mar 5, 2020 at 1:32 PM
    #1971
    ibclark
    ibclark New Member
    How far out do those poke?
    drobb likes this.
  22. Mar 5, 2020 at 1:56 PM
    #1972
    Misr2
    Misr2 AT2
    Beaty
    2015 Tundra SR5 TRD 4x4
    3/2 rough country 1.5inch spacers and 285/75r18 toyo rts. No BMC and light cutting up front, rub free.
    superdenk, J&ATundra, Skey44 and 8 others like this.
  23. Mar 5, 2020 at 7:20 PM
    #1973
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    I have run KO2s (35’s) on a couple of trucks and they are a bear to balance. If you can get them right they do well in ice and snow.
  24. Mar 6, 2020 at 6:30 AM
    #1974
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Thanks.
    I saw the New Toyo Open Country AT3 just came out. I may go that route. I really want to just step up to a 35x12 but i fear i may be into the body chop mod and upper control arm swap at that tire size
  25. Mar 10, 2020 at 1:13 PM
    #1975
    liquid_g
    liquid_g New Member
    Grantham, New Hampshire
    2018 Tundra Platinum
    Figured I'd share this here as it took some searching, only found 1 or 2 people that have done this. Nitto Ridge Grapplers 295/55/R20 on stock Platinum wheels and stock suspension. Fits just fine. No trimming rubbing anything like that. Not a fan of most wheel options out there and especially not crazy about wheel poke past the fenders. Happy with the outcome.
  26. Mar 10, 2020 at 5:10 PM
    #1976
    Maddog94
    Maddog94 New Member
    Okay guys does anyone know if the following is G2G without rubbing?
    20x9 +35mm offset wheels and 285/60/20 tires? Leveled.
  27. Mar 17, 2020 at 3:02 AM
    #1977
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    33A439C2-1803-42A9-A1F5-28A4018FD7D2.jpg F3986F26-653E-417A-BC17-F1486252F1E8.jpg 3264323B-BE04-40AE-A0DC-F30881BC4F44.jpg 2017 Limited Crewmax: 3/2” leveling kit; Ridge Grapplers 285/70/r18 w/ KMC Mesa Gray Tint 18/9/+25
  28. Mar 20, 2020 at 2:37 AM
    #1978
    fiveduece
    fiveduece I like to party.
    Brandon
    2020 TRD sport MGM crewmax
    tint, N-Fabs, trifold cover, bilstein 5100 w/spacers, +2 shackles, MT deegan wheels
    You have no rubbing issues? Did you have to modify anything so they wouldn't rub. You have same tire size that I'm leaning towards. Truck looks great.
  29. Mar 20, 2020 at 6:24 AM
    #1979
    OPSteel
    OPSteel New Member
    A tiny bit when wheel cranked all the way to the left, then when I pit on my new +25’s, I had to remove the small front mud flap attached to the bumper.
    fiveduece likes this.
  30. Mar 22, 2020 at 12:41 PM
    #1980
    Tundranater
    Tundranater New Member
    Will
    Japan made beast!
    Exhaust, intake, headlights, clear corners
    What's everyone's thoughts on plasti-dip these days?
